The "Official" Denon AVR-2808CI Owners Thread - Page 10 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #271 of 3951 Old 11-02-2007, 08:15 AM
wabkab's Avatar
Originally Posted by Bob0115 View Post
I'm having the same issue. Right now, only running composite into 2808 and HDMI out to the TV. Thought it might be an analogue to digital conversion lag. Are you running HDMI into the receiver?
Yes I am(HDMI), but I also have analog ins from the same STB so as to have video record in/out and zone 2 capabilities(HDMI can't downconvert to 480i).
These extra inputs may be making the Denon hiccup while it processes the signal? I never tried it without the alalog ins. The one advantage with analog ins simultaneously is that when you switch to menu funtion, it displays the menu over active picture(although downrezzed to analog and I guess re digitized to pass thru HDMI. With HDMI in and out only, it displays the menu over a black screen.
Ps. Despite my harping on the BluRay DVD fiasco, I succumbed to the walmart secret sale this morning and bought a Toshiba HDA2 for a price that once I get the 5 rebate movies will be free for all practical purposes. With this as my second HDMI input to the Denon, I'll be able to compare and see if any sync issues happen. I'm thinking its the analog to digital changes.
Tony B
wabkab is offline
post #272 of 3951 Old 11-02-2007, 08:23 AM
wabkab's Avatar
Recently purchased the 2808 and am kinda second guessing myself. I had an 1803 previously and pretty much just went and got the 2808 without doing a lot of listening to other receivers. Don't know if I'm confusing clean/clear sound with bright but it is as though the sound seems a little bright to me. Anyone do a lot of sound comparisons with the 2808 against Yamaha V1800, Onkyo 805 or Pioneer 91THX? If so, I would like to hear your impressions. Don't want to open up a debate on which one is best or anything, just looking for some past experience. Thanks.
Are you using it as 5.1 or 7.1, and have you done the Audessy setup from at least 6 positions? I went from 3 to 6 and it made a big difference."warmer"
From old debates, it seems the concensus is that Denon has a more neutral sound(which can easily be manipulated any way you want via all kinds of menu options) and Yamaha and Pioneer have a "warmer" sound. Bottom line-I wouldn't sweat it, but that's what we do!
Tony B
wabkab is offline
post #273 of 3951 Old 11-02-2007, 10:20 AM
Aenima99x's Avatar
Hey guys I'm looking at buying one of these today, but I've got a couple questions before I do. My system is as follows -
Panasonic TH-50PHD7UY 50" Plasma (720p/1080i only through Component - HDMI board only support 576p )
Panasonic S-97S DVD (720p/1080i upconversion via HDMI only)
TiVo HD (set to fixed 1080i)
Now my questions -
1. Would I have any issues connecting the TiVo HD and Panny DVD to the 2808 with HDMI and then outputting from the 2808 to the TV with Component?
2. Should I just ditch the HDMI altogether and use component & optical connections for everything? (This would limit my current DVD to 480i/480p)
3. A little off-topic - In the event that I upgrade my DVD to an HD or Blu-Ray, would I get the same features and quality using component/optical as I would using HDMI (TrueHD, etc)?
Sorry I'm still a newb when it comes to some of the areas. Thanks!
Aenima99x is offline
post #274 of 3951 Old 11-02-2007, 10:57 AM
paulsen's Avatar
1. For HDMI in there is only HDMI out.
2. You can mix and match. For your DVD I think you can have HDMI directly from DVD to TV (to get your 720p/1080i upconversion) and also have Optical-digital audio go to the 2808CI (to get best audio). Depends on flexibility of your DVD player. Then stick with all HDMI for the TiVo.
3. There are things that work via HDMI that you won't get via component. I won't try to list them all because I am fuzzy on it myself. Some of this is the ability of components to cooperate with each other (like recognizing each others' capabilities and making sure formats/decoders, etc. match up). There are some higher-end video capabilities (Deep Color, xvYCC color) and perhaps also audio capabilities that may not come through component or optical cables (not sure of this).
paulsen is offline
post #275 of 3951 Old 11-02-2007, 11:16 AM
Aenima99x's Avatar
I thought that might be the case.
Can't do this becuase my TV only has one HDMI input. I'm currently using a Monoprice HDMI switcher. Also wouldn't I be losing quality using the HDMI since the HDMI board in my tv only supports 576p?
Cool thanks.
I've always wondered why my pic quality seemed to look worse after switching from component to HDMI....
post #276 of 3951 Old 11-02-2007, 12:37 PM
seedman56's Avatar
I have a pioneer plasma 6070 and have just purchased the Oppo 981hd (Its on its way) I have a Starchoice HD sat. rec. Is there any advantage for me to have the 2808 as compared to the 2308? The Oppo has to go HDMI thru the Denon, as it only has HDMI output. I am a oldie, but a newb to this newfangled contraptions!!
seedman56 is offline
post #277 of 3951 Old 11-02-2007, 01:00 PM
eyedoc1971's Avatar
Hi, newb here.
Could someone give me step by step instructions on how to set my 2808 to pass thru only of all video signals (DVD, Cable box).
Thank you!
eyedoc1971 is offline
post #278 of 3951 Old 11-03-2007, 08:31 PM
Pharcyde23's Avatar
Went to audition one of these today at my local Magnolia. They just happened to be rewiring the entire rack.
I currently have a Yamaha 661 (90Wx7). Would anyone be able to tell me how much difference in sound quality to expect between the two? Also how well does this unit handle LFE?
My system is Def Tech. BP7004 mains, CLR 2300, pro monitor 1000s. Mirage S10 sub.
Pharcyde23 is offline
post #279 of 3951 Old 11-04-2007, 04:49 AM
CHAS ZOSS's Avatar
Quoted: 13 Post(s)
Originally Posted by insitedata View Post
You can adjust input source volume. It is an option on the other menu option for an input source. It is described on page 36 of the manual.
Can you explain how you get to that option in the menu I would like to increase the volume and page 36 did not explain squat! Thanks
CHAS ZOSS OPPO EAP 2nd ROUND late entry!
CHAS ZOSS is online now
post #280 of 3951 Old 11-04-2007, 04:58 PM
r_russ08's Avatar
Just spent 4-5 hours reading threads on the Denon AVR 2808Ci, 3808Ci, Onkyo TX-SR705, and 805 and want to thank all the members for the invalueable info.
As far as audio, will they both put out audio via HDMI to the TV or will I need to run another digital signal? Which will better perform in HT surround sound and music playing from a HTPC?
r_russ08 is offline
post #281 of 3951 Old 11-04-2007, 07:32 PM
Bob0115's Avatar
Thanks Tony. Went back and A/B'd the Yamaha v1800 and the Denon won. It's not "bright".....but rather clean and clear. The clarity is great. Going to stop sweating it now!!!
Bob0115 is offline
post #282 of 3951 Old 11-04-2007, 07:56 PM
wabkab's Avatar
Good deal. I've had quite a few things from Nakamichi to Marantz to Pioneer Elite and Counterpoint separates. I've gravitated back to Denon, it's hard to beat for the money.
Tony B
wabkab is offline
post #283 of 3951 Old 11-05-2007, 10:06 AM
ndjedinak's Avatar
Originally Posted by openwheelracing View Post
http://www.ti.com/lit/gpn/dsd1608
Thanks! So it uses one of the new 8-channel BB DAC's. Interesting. I wonder how it compares to the 987 (uses Analog Devices DACs) I have now. Any thoughts?
What did you think of the Onkyo 805?
I'm running the Denon essentially as a pre/pro in my system; I do use the internal amp for Zone 2, but I use external amplification for F/R and C/Surround. I scored my 987 for around $400, and I like it, but I've been wondering if I'd like the 805's supposedly superior DAC performance.
The sound of the 987 (in 2-channel, fed pre-out to an external amp) is quite nice: sweetly extended, very detailed, and lend a nice feeling of air to the performance. On the negative side, the sound tends towards the thin side of the spectrum more than I'd ideally like.
ndjedinak is offline
post #284 of 3951 Old 11-06-2007, 06:19 AM
CHAS ZOSS's Avatar
Quoted: 13 Post(s)
Please help!
post #285 of 3951 Old 11-07-2007, 12:36 AM
RAE 1's Avatar
I'm seriously considering the 2808CI, but I have a basic electronics question:
What will happen if I hook up the 2808CI to my existing 4 ohm speakers? (The manual says they should be 6 ohms or higher -- 8 ohms if you use both A and B speakers.) Will I just get higher volume at a given setting? Do I run the risk of blowing out my speakers? Could it cause a problem for the receiver itself?
RAE 1 is offline
post #286 of 3951 Old 11-07-2007, 10:04 AM
zoro's Avatar
Quoted: 225 Post(s)
Liked: 41
I owned a 805, now own Denon 3808, I would love to downgrade to 2808, but 4 HDMIs stop me! even I do not need all advanced networking etc.
I could have bought 805 from CC for $650 to downgrade to 3 HDMI, but I do not have heart to save myseld $600 after owning and returning 805. If budget allows stick with denon.
zoro is offline
post #287 of 3951 Old 11-07-2007, 10:12 AM
Black Magic's Avatar
Give Scott at 6ave.com a call at extension 8362 to get the 2808ci for $798 (Free ground shipping!). The deal ends today.
Black Magic is offline
post #288 of 3951 Old 11-07-2007, 10:24 AM
EJ1
EJ1's Avatar
Is it possible to connect an external amp to the AVR-2808CI, such as a Rotel RB-1080. I'd only use the Denon for processing, no amplification. If this is possible, how so? Thanks in advance.
EJ1 is offline
post #289 of 3951 Old 11-07-2007, 10:57 PM
rsandhu's Avatar
The 2808CI is accepting an HDMI signal (from a DVD player), optical audio input (from the HDTV built-in ATSC tuner) and one HDMI output to my TV.
The menu is not displayed unless the HDMI I/P scaler is on. The menu is not overlayed with the scaler turned on. Is there a configuration that will display the menu (or atleast the volume)? Would a composite connection to my TV solve the problem?
rsandhu is offline
post #290 of 3951 Old 11-08-2007, 05:26 PM
rsgoodman's Avatar
Hey- Newb here. I have had the 2808CI for a few months and over the past few weeks- it has been randomly (i.e. once every few days) turning off and the power indicator flashes red. I know it could be overheating or wires touching one another. The unit is in a cupboard; but pretty well ventilated. Nothing is moving- so I doubt it is the wires. Any other suggestions/ recommendations. Thanks
rsgoodman is offline
post #291 of 3951 Old 11-08-2007, 08:58 PM
paulsen's Avatar
This sounds like an overheating problem to me.
First be sure you don't have 4ohm speakers. Must be at least 6ohm. If this is not the problem I can believe that being in a cabinet (even if well-ventilated -- which can be a matter of opinion) it might overheat with either prolonged use or use at high volume (or with 4ohm speakers). You should try a fan. The best I have found is the following:
http://www.stayonline.com/detail.aspx?ID=8663
Be sure to get the one linked above and NOT the following:
http://www.stayonline.com/detail.aspx?ID=8665
The first is a complete set-up: fan and power supply. The second is an extension unit that needs to be plugged into the power supply provided by the first. They daisy-chain together.
These fans are very quiet and turn on and off based on temperature. They have very low air movement but just enough to do the job and remain quiet.
If you want, you can buy a set of three to daisy-chain:
http://www.stayonline.com/detail.aspx?ID=8664
rcp
paulsen is offline
post #292 of 3951 Old 11-08-2007, 11:05 PM
xplayazplayzonx's Avatar
I Have A Denon 2808CI. I Like It Very Much. Im Ordering My Mordaunt Short Speakers Slowly. Just Picked Use Some Avant 906i Floor standing Speakers And I Bi Wired It. Since It Has A And B Speakers And They Send The Same Front Signal. But The Speaker Separates The Bass And Treble. Have A Bose Center Speaker For Now. Infinity Sub That Pushes Out 250 Watt RMS. Picked Up A Denon Dvd Player With Upconvert, And Toshiba HD-A2. Just Gota Pick Up Some HDMI Cable From Monoprice :]
xplayazplayzonx is offline
post #293 of 3951 Old 11-09-2007, 09:12 PM
jsl262's Avatar
I'm a current owner of a denon 3208 receiver. I'm debating as to the need to upgrade to the 2808.
My needs are to get the most from my new toshiba A35 hd dvd player on my panasonic plasma.
How important is "THX" certification lower price receivers have it, but not denon prods.
Any comments welcomed. john
jsl262 is offline
post #294 of 3951 Old 11-10-2007, 04:47 AM
Stouty's Avatar
hi guys nice reciever
Can someone please help me understand ....
here are specs taken from denon uk re 2808 ...... http://www.denon.co.uk/site/popup/in...&Pid=351&vPidN[0]=338
Scaler 480p bzw. 576p / 720p / 1080i
(for analogue Video-Signals > HDMI-output)
HDMI Video Conversion
Video, S-Video ->HDMI 480i/576i, 480p/576p, 720p, 1080i,p
Component 480i/576i ->HDMI 480i/576i, 480p/576p, 720p, 1080i,p
Component 480p/576p ->HDMI 480p/576p, 720p, 1080i,p
Component 720p ->HDMI 720p, 1080p
Component 1080i -> HDMI 1080i, 1080p
Ok so it scales analogue signals to only 1080i & spits it out the HDMI out(eg to display).....
but then sais it takes a vid,s-vid, component input & scales it to HDMI 1080p ....huh isnt component analogue aswell? confused?
So if i send a 1080i component signal from my HD set top box will it scale it to 1080p & send out HDMI to monitor?
Stouty is offline
post #295 of 3951 Old 11-10-2007, 05:56 AM
fahertyps's Avatar
I called 6ave yesterday and he told me I could call him back on Monday and get this same price. I hope it holds true. I'm still researching the Yamaha 3800 though. Its only $300 more. Any recommendations? (I know this isn't the yammy forum.) Also, I had his extension down as x8632. Perhaps I'm dis-lexic. Anyways, just ask for him by name.
-PSF in VA
fahertyps is online now
post #296 of 3951 Old 11-10-2007, 06:47 AM
hiko13's Avatar
I'm pretty much in the same boat...I'll be interested to hear if you've got any luck. Either way I've got a phone call to make Monday morning.
PSN: Thrillho
XBL: Herald of Woe
hiko13 is offline
post #297 of 3951 Old 11-10-2007, 10:47 AM
sgoodsell's Avatar
1080p scaling via component?
I'm feeding my Denon 2808 via component from my sat box (1080i) and then to my tv. Where, if it exists, would I find the settings to scale and output from the 2808 to TV at 1080p? I thought this was a basic setting toggle but can't seem to find that menu. The HDMI set up is straight forward but I'm a couple of weeks from receipt of my HDMI cables.
sgoodsell is offline
post #298 of 3951 Old 11-10-2007, 11:48 AM
rafale's Avatar
Yes, the 2808CI has preamp outs so you can connect it to another power amp.
rafale is offline
post #299 of 3951 Old 11-10-2007, 11:56 AM
rafale's Avatar
At 4 ohms, in order to output the same wattage the amp will need to drive more current.
Power=current x voltage
But Ohm's law: Voltage = impedance x current
Power = Impedance x Current^2
The sound you will get depends on sensitivity. It is expressed in dB/Watt
If you want say 60 watt through your speaker (assuming that the speakers have the same sensitivity, they will have the same volume)
with 8ohm speakers you will need 2.74 Amps per speaker
with 4ohm you will need 3.87 Amps.
This means that the amp will have to drive more current and will heat more to the point of potentially shut down...
rafale is offline
post #300 of 3951 Old 11-10-2007, 04:11 PM
curlyjive's Avatar
Quoted: 534 Post(s)
Liked: 246
FYI,
My wife called to see if the deal was still available....it was and she ordered it for xmas for me They have a 3 yr warranty for a good price too
curlyjive is offline
Denon Avr 2808ci Receiver , Denon Avr 988 7 1 Channel Multizone Home Theater Receiver
