I just wanted to start a thread for all owners of the Denon AVR-2808CI A/V receiver to post your impressions, useful information and a issues/resolutions for this unit. Mine will be arriving this week, and I'm sure there are others who will be receiving theirs soon or already have them up and running!
Here are some basic specs for anyone interested in purchasing one:
AVR-2808CI 7.1 CH/5.1+2 CH Home Theater/MultiMedia A/V Receiver with Network Client Compatible D-dock Port
The AVR-2808CI has been fortified with the latest A/V upgrades positioning itself to become one of the most popular audio video receivers in the industry, continuing on in its predecessor's footsteps. The AVR-2808CI now has HDMI v1.3a which brings with it the new surround formats for HD decoding allowing for ultimate surround performance for the best in home theater experience. Updated Audyssey audio processing has been added to provide improved auto calibration results for smooth sound reproduction. The well acclaimed Faroudja FLi2310 has been employed to allow for video scaling to 1080p resolution. Serial IR ports along with the RS-232C system control port provides ease of integration for complex home audio installations with 3rd party controllers. Couple this with the new EL remote and you have an A/V receiver sure to be a best seller.
* 110 watts x 7 channels
* Analog Video to HDMI Scaling - 1080p
* Rear Panel RS-232C
* XM ready tuning
* Dolby TrueHD and dts-HD Master Audio
* New DDSC-HD processing
* Expanded HDMI v1.3a ports with Deep Color and xvYCC Support
* Digital to Analog conversion for multi-zone connection flexibility
* Assignable +12V D.C. triggers
* Comes with dual remotes
* 2-way remote capability with optional RC-7000CI remote
Thanks for the heads up. The updates #56 and #58 were made avail 2 years ago. Usually the EU changelog provides a list of the specific fixes in the update. Are you able to access it?
The only change from Ver #58 to what you posted is the DSP1 changes from 36.57 to 36.61 so it's likely to be something really small and quite possibly only EU model related.
I wasn't wrong, rather perhaps I was simply unclear about what I was saying ...
I wasn't comparing the two updates you have posted (as there is no Ver # for the 1st update you posted), rather I was comparing what was provided to us as Ver #58 almost 2 years ago and the 1st update you have listed which shows no change in the Sub Ver # 37.
I need some advice, I own the AVR 2808 and i´m thinking to buy a blu ray, I wish to know if the 1610 or 2010 or wait for the 1611, the 2011 is out of my budget
you don't need a Denon blu-ray player, if the budget is tight I would get one of the much cheaper options from other brands.
The thing to understand is that all Blu-ray players are essentially IDENTICAL when it comes to video and audio quality when used with an HDMI receiver. So you need to think about what features you want on the player (like Netflix streaming) to decide what you need.
How about SACD, HDDVD, etc thrown in? Check out these great universal players: Oppo BDP-80 or 83 . The 80 is very good with upconversion (recommended for up to 60" screens) and audio, for under $300. The 83 has superb upconversion and audio for $499. High quality machines and top notch CS with timely FW updates.
From official site has downloaded new updating for AVR 2808.
I have bought in shop "direct" cable COM-COM. The cable of 100 % is serviceable. Specially for insertion updating has established WinXP.
All I do under the instruction 1. Please initialize the unit as follow: Turn on the power of unit while pressing the [STANDARD] button and [DSP SIMULATION] button simultaneously.
2. When FL Display will be indicated complete is the unit inzialized.
I start the utility and when I press [Check communication] button- аll time the message “Communication check NG!”.
The EU update software you have downloaded is somewhat different than what we use here in the USA, however, the final result is likely similar. The update software starts out with PORT = COM1. Keep trying different port numbers (e.g COM2, COM3, COM4, etc.) until you get an "OK" message. You may also get a "Communication OK" message but the firmware still won't install, so select another port number that gives an "OK" message and try that one instead. If you have tried all port numbers and the firmware still won't install, there should be an alternate installation method to use called the "Specific Update Method". Try that and it should work for you.
If you are using a MS laptop, although you may have only one "physical" COM port, you have probably 20 "virtual" COM ports. Where it says PORT = COM1, there should be a drop down menu that allows you to select another COM port.
In order to check your firmware Main Ver # and Sub Ver#, using the buttons on the front panel display (not the remote) first turn the 2808 ON (green light around power button). Then using the small power button, power the 2808 OFF (not in standby). Then turn the power of the 2808 ON with the little power button, while holding both the [RETURN] button and [STATUS] button (located under the flap on the front panel) simultaneously. After the unit powers on, each time the STATUS button is pressed, it will cycle through the various software version numbers including the Main Ver# and Sub Ver#.
i currently have this receiver pushing the following
2 Def tech towers in front
1 def tech center
1 supercube def tech
2 boston accoustics in rear (previous owner installed in cieling)
and the second zone has 2 outdoor speakers.
HERE is where the help comes in. I want to expand to 7.1 in the living room and wanted to make sure if i add 2 in ceiling speakers, that i can still have 2 zones and still have the outdoor speakers.....
Originally Posted by Chops27 /forum/post/18913529
...and the second zone has 2 outdoor speakers.
Hi Felipe. We usually just answer in the forum as it helps others/lurkers. You only have 7 amps available so the surr back amps can either be used for that OR they can be assigned to Z2 as you have now, not both.
But let's look at the issue from another perspective. Why do you want back surr backs? Describe your room (or provide a diagram) size, location of seating, current surr speakers and proposed speakers. If it is an average room and you are seated near the rear wall, I'd suggest optimizing the surrs. They should be even with (90 degrees) or just a little behind you (maybe 100 degrees) and toward the sides (and if on the wall, about 2' above seated head position). See this .
just to be clear, the answer to your question is YES, you absolutely CAN have a 7.1 setup and still use the outdoor speakers. The issue is that you need to add an external amp because, when running 7.1 in the Main Zone, you have used up all 7 of your amps.
In this setup, you would run RCA's from the Zone 2 pre-out jacks (red/white) to the L/R inputs on an external 2-ch amp. Doesn't have to be anything fancy to power outdoor speakers, any old stereo amp will do (if you have an old stereo receiver lying around that will work great).
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
