The "Official" Denon AVR-2808CI Owners Thread - Page 130 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
Old 11-06-2015, 03:03 AM
585-645-1006
jdsmoothie's Avatar
Quoted: 8432 Post(s)
Liked: 3797
Originally Posted by csseahawk View Post
Hello.I would appreciate a firmware update please. I cannot send you a private message due to not enough posts. Thanks............
P.S. If my source selector knob is not working, what could be wrong? I can still access all the inputs via remote...........
csseahawk@yahoo.com
Whenever the AVR is being problematic, the first troubleshooting step to perform is to power off the 2808 and unplug the power cord for at least 10 minutes and then power on and see if that resolves the selector knob issue. If still no joy, do a microprocessor reset (p. 50 Owner's manual), although note doing so will erase all settings and return them to factory defaults, so if you don't use the Source selector knob, I wouldn't bother with the reset. I will forward the firmware update to you, but it won't resolve your current issue.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
AV Science - Dealer for Denon, Marantz, Yamaha, Onkyo, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
Old 11-06-2015, 08:30 AM
cprawks's Avatar
Quoted: 255 Post(s)
Liked: 59
I have never updated the firmware on my 2808CI. How do I proceed with the update?
No longer looking straight into a flashlight. Calibrate!
2014 Vizio P60 1.2.23 Settings.
cprawks is offline
Old 12-02-2015, 04:04 PM
eyedoc1971's Avatar
Same problem as in post #3851 . I have video but NO audio at all. I get audio dropout but video remains on HDMI input from Xifinty box. I have to change input then go back to same input to get sound back. I also have a WD live TV box on separate HDMI input with no problems at all. Any advice? Just run all HDMI inputs through switch box? Thanks
eyedoc1971 is offline
Old 12-02-2015, 05:39 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3797
Review the following post on HDMI handshakes ....
The "OFFICIAL" 2015 Denon "S-series" / "X-series" AVR Owner's thread + FAQ (HDCP 2.2)
Old 01-15-2016, 08:04 AM
cprawks's Avatar
Quoted: 255 Post(s)
Liked: 59
How do you turn off Jazz Club on HDP. I'm connecting FireTV on HDP input, but I don't want Jazz Club or any listening modes.
cprawks is offline
Old 01-15-2016, 10:12 AM
batpig's Avatar
Quoted: 3156 Post(s)
Liked: 2982
Check the manual for surround mode buttons -- the easiest way is to flip open the panel on the front and look in the upper left where there are buttons for "Standard", "DSP Simulation", "Pure Direct", and "Direct/Stereo". Jazz Club is one of the DSP modes, so if you are looking for standard multich playback use "Standard" and for 2ch playback use the "Direct/Stereo" button.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 03-10-2016, 03:48 AM
Liked: 0
jdsmoothie,
I have tried PM you a few days ago, I´m not sure if the message went tru.
Can you, please, send me the newer firmware version?
Best Regards,
JV
jvtrigo is offline
Old 03-10-2016, 04:02 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3797
Originally Posted by jvtrigo View Post
jdsmoothie,
Best Regards,
JV
Sorry, but no PM received as you must have a minimum number of posts to send a PM (15?).
Please forward your non-gmail/non-edu email address to me at jd@avscience.com requesting the 2808CI firmware. Note this update applies to the USA model only.
jvtrigo likes this.
Old 03-29-2016, 12:32 PM
Liked: 0
Troubleshooting AVR-988
Hello Guys,
I´ve been troubleshooting an Denon AVR-988 and I found a strange anomaly on frequencies from 30hz to 100hz. It´s OK on higher frequencies.
As I can´t here anything strange on the drivers I´m thinking that this can be because of Al24 Processing Plus.
Please refer to the videos in the link below: Unfortunatly the system doesn´t allow me to post links becaus I´m a new user.
It seens that it has another wave runing in the background with almost the same frequency as the original wave.
Have anyone seen something like this?
Thank you,
JV
jvtrigo is offline
Old 03-29-2016, 12:33 PM
Liked: 0
Hi Guys,
Here is the link of my previous post.
.dropbox.com/sh/nrlus8vt6q6hvp7/AAC8Sj2RvCSIAGw3-O4Xb-hNa?dl=0
Please add "https://www" before .dropbox
Best Regards,
JV
jvtrigo is offline
Old 03-31-2016, 09:30 AM
Liked: 0
Well I found the solution to the problem above.
It actually has nothing to do with AL24 Processing Plus, it was a ground feedback.
It is odd that only affects the Denon, my Yamaha integrated AMP is normal, maybe due to the diferent architecture.
BR,
JV
jvtrigo is offline
Old 04-02-2016, 02:59 PM
cocobeli's Avatar
BR,
JV
Thanks for the update.
-= Jed =-
cocobeli is offline
Old 04-05-2016, 09:21 AM
Liked: 0
Hi Guys,
Another noob question.
I just bought a subwoofer SVS-SB1000.
To connect it I need a analog coaxial cable (RCA) 50/75 ohms, right?
Or can I connect using a digital cable (110 ohms)?
BR,
JV
jvtrigo is offline
Old 04-05-2016, 09:24 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3797
Hi Guys,
BR,
JV
Digital coax cable is normally used.
http://www.monoprice.com/category?c_id=102&cp_id=10236
Old 04-06-2016, 09:11 AM
Liked: 0
Tks JD.
jvtrigo is offline
Denon Avr 2808ci Receiver , Denon Avr 988 7 1 Channel Multizone Home Theater Receiver
taboola here
