The "Official" Denon AVR-2808CI Owners Thread - Page 131 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #3901 of 3929 Old 06-04-2016, 08:30 AM
saxdogg's Avatar
Thanks. The seller has said he had problems with it passing HDCP (?) protocols correctly so I'm probably not going to get it since I'm afraid I'll have those same problems with my sources. I'll probably end up just buying a budget new one. Thanks to all for the comments.
saxdogg is offline
post #3902 of 3929 Old 06-28-2016, 04:15 PM
Liked: 0
Need Help - no audio output via HDMI/coax
I'm hoping someone on this forum can help me with some issues I'm having with a Denon AVR-2808CI that I just purchased. Though I bought it 2nd hand, it was a former floor model and was essentially in like new condition with all remotes, accessories, etc. It even came in the original box! Right now I have the AVR hooked up to a Denon-1930CI DVD player. I am using this system exclusively for audio, especially surround sound DVD-audio and SACD.
Essentially, I am having two issues here, both involving audio output:
1) I have tried to use both HDMI and Coaxial connections between the DVD player and the AVR but I am getting no sound either way. The receiver is clearly reading the signal, as all of the "correct" lights are coming up on the receiver display. For example, I popped in a DTS-CD and it immediately lit up the speaker configuration for 5.1 sound and said DTS-surround on the display. Similarly, when I popped in another disc with a DTS 96/24 stream, the "96/24" and "DTS" lights came on. However, no audio is coming through my speakers. Now, if I switch to the all-analog EXT-IN option, then I get full audio and it sounds great, but I still would like to make sure that I have full functionality with this receiver. I also really would like to use the HDMI connection to set up a Blu-Ray player so that I can play Blu-Ray audio discs.
2) My second issue involves the "Test tone" set-up function. When I tried to use the test tones, I also did not get any audio coming out of the speakers. The display correctly cycled through each speaker and allowed me to make db adjustments, but I could not hear a test tone. Could this issue be related somehow to my first one?
The frustrating part is that all my other connections work fine. Like I said, the Ext.In signal sounds great, so I can play SACDs and DVD-audios. I've also got a CD player and turntable hooked up and they both sound great. I really like the sound of this receiver, so I'm hoping someone can help me here!
(Apologies on the long post....)
ogrerock71 is offline
post #3903 of 3929 Old 06-28-2016, 04:54 PM
jdsmoothie's Avatar
Quoted: 12113 Post(s)
Liked: 5515
Sounds like a defective HDMI board. Try resetting the microprocessor (p. 50 Owner's manual) a few times and if still no joy, get your money back.
ogrerock71 likes this.
jdsmoothie is online now
post #3904 of 3929 Old 06-29-2016, 03:18 PM
Liked: 0
Thanks for the response. I tried a hard reset, like you recommended, but nothing changed. I'll try it a few more times and, if that doesn't work, I guess I'll be returning it.
post #3905 of 3929 Old 08-15-2016, 01:20 PM
JeffR1's Avatar
Quoted: 622 Post(s)
Liked: 182
No Tone Sound Out of Some of The Speakers
As the title says...
I have the air conditioner on, and it overloads the breaker _ that same breaker also is running the AVR setup and of course the breaker "trips". (It's an old house and every year I turn on the Air Con for the first time, I forget about the breaker problem)
Can a sudden loss of power to the AVR 988 cause some of the speakers to not output any sound ?
I'm going to reset the processor, but I hate doing that and relearning how to set everything up again.
Fuses are fine in the speakers...
Thanks !
JeffR1 is offline
post #3906 of 3929 Old 08-15-2016, 02:47 PM
jdsmoothie's Avatar
Liked: 5515
Thanks !
Before doing a reset, I'd swap some speakers around to see if your speakers haven't been blown.
post #3907 of 3929 Old 08-15-2016, 05:12 PM
JeffR1's Avatar
Quoted: 622 Post(s)
Liked: 182
Thanks for that, looks like I'll be doing a reset.
I'll take my ohm meter to my speakers and check that way, I'm too lazy to move them around.
They should be at 4 ohm's.
They're all Magnepan's except for the sub of course.
JeffR1 is offline
post #3908 of 3929 Old 08-15-2016, 06:51 PM
JeffR1's Avatar
Quoted: 622 Post(s)
Liked: 182
The AVR is quite finicky, I did a processor reset and the SBL speaker still wasn't working doing the tone test, so I cranked it up to it's max volume and then it suddenly started working _ I could then put at 2.5 Decibels where I had it before.
Even the computer wasn't behaving, the left front surround didn't work until I reset the "Sound" in the control panel to default.
I also have to be carful on how to turn things on, the computer has to be on first, then the AVR, Sub, center output amp and finally the projector.
Please look at this screen shot, is there any difference in sound quality choosing 16 bit/24 bit, 44100, 48000, 96000 Hz etc. ???
Depending on which one I choose, the sound in the control panel doesn't always work doing the Windows tone test.
Thanks !
JeffR1 is offline
post #3909 of 3929 Old 08-17-2016, 07:58 AM
Quoted: 16 Post(s)
Liked: 0
Jeff leave it at the maximum 24bit 192khz and ser your software to bitstream the audio. The PC will send untouched signal to the Receiver to be processed.
Enviado de meu SM-N910C usando Tapatalk
jvtrigo is online now
post #3910 of 3929 Old 09-05-2016, 12:42 AM
JeffR1's Avatar
Quoted: 622 Post(s)
Liked: 182
I did a search and nothing came up, what does the "Distance" setting do to the volume of each speaker ?
Does it raise or lower the volume according to the distance set and if it does, what do we need channel level for ?
eg,: If I set the centre channel level to +12db (max setting) will setting the distance at 6 feet make it louder as apposed to 12 feet ?
JeffR1 is offline
post #3911 of 3929 Old 09-05-2016, 03:22 AM
jdsmoothie's Avatar
Liked: 5515
Distance accounts for the delay of the signal (eg. the distance for a subwoofer is generally much longer than the "actual" distance as it accounts for the filters in the sub which cause a delay in the signal).
JeffR1 likes this.
post #3912 of 3929 Old 09-05-2016, 07:57 AM
armedmetallica's Avatar
Quoted: 41 Post(s)
I have two Denons in the same room, and have changed the 2808CI to "Amp 2", and set the RC Setup on the remote control..
Everything there works great .. volume/power, speaker, etc..
Now, I want to turn Zone 2 on from the small zone 2/3 remote... However nothing seems to happen on the reciever. IF the main zone is one, it just shows the AMP 2, but nothing happens. I know the zone 2 is assigned in amp assign, and I can physically turn it on from the front of the unit.
Is there an equiquvalent to RC setup that needs to be done on the Zone 2 remote?
armedmetallica is offline
post #3913 of 3929 Old 11-27-2016, 12:29 AM
Slidell's Avatar
No Issues!
Just wanted to say my 988 has been pulling it's weight since 2008 as my HTPC Pre-Pro. Well, I do use the 988 to drive the back 3 speakers in 6.1 setup. The 988's "half" pre-outs drive my old Yamaha M-65 for mains, re-built Phase Linear 400 for twin full range center speakers and hand me down HSU amp to drive 1986 AR stereo Sub. A Clevo W110-ER feeds HDMI to 988 for lossless audio decoding which then passes video straight to 55" Sony, no up scaling ever used or needed. All but laptop totally controlled with Harmony 650. Since all media now on drives, my old PS3 sits sadly underused. Will check out infrared to USB down the road for laptop unless anyone has good suggestion.
Unlike friends 2 year old Emotiva UMC-200 Pre-Pro, 988 never had HDMI switching issues or power supply burning up. While the 988 has been solid, always looking at solid replacement gear if repairs get crazy.
Cheers
Slidell is offline
post #3914 of 3929 Old 11-28-2016, 05:22 PM
cocobeli's Avatar
Originally Posted by Slidell View Post
No Issues!
I’ll chime in here to say that my 988 has also been working well from the beginning. It’s in daily use in HT, watching TV, playing LPs, CDs, DVDs, radio… anything with sound. Harmony 659 does the remote duty.
-= Jed =-
cocobeli is offline
post #3915 of 3929 Old 12-26-2016, 05:11 AM
Quoted: 16 Post(s)
Liked: 0
Low dialogue
I´m having problems with low volume dialogue.
I usually play DTS-HD 5.1 but my system is 2.1 so I think the reciver is not downmixing 5.1 to 2.1 properly.
Anyone has a fix?
tks
post #3916 of 3929 Old 12-26-2016, 07:44 PM
jdsmoothie's Avatar
Liked: 5515
Anyone has a fix?
tks
Ensure your FL/FR speakers are angled towards your main listening position prior to running the Audyssey setup. If the issue only presents with one source, then you can use the Source Level setting to bump up the volume of that one source.
post #3917 of 3929 Old 12-27-2016, 04:11 AM
Quoted: 16 Post(s)
Liked: 0
Thank you.
Will give it as try.
BR
post #3918 of 3929 Old 12-27-2016, 04:14 AM
jdsmoothie's Avatar
Liked: 5515
Thank you.
BR
Also note, if you do a lot of movie/TV watching, you're much better served adding a center speaker as 85%+ of a movie's dialog is directed towards the center speaker.
post #3919 of 3929 Old 12-27-2016, 08:20 AM
Quoted: 16 Post(s)
Liked: 0
The thing is that when I watch TV the dialogs are fine the issue only happens when downmixing from 5.1 or 7.1 to my 2.1 set up.
post #3920 of 3929 Old 12-27-2016, 09:06 AM
jdsmoothie's Avatar
Liked: 5515
If your cable/sat box DD 5.1 audio is okay down mixed to stereo, then the issue is more likely with your Blu Ray player.
post #3921 of 3929 Old 12-27-2016, 09:27 AM
Quoted: 16 Post(s)
Liked: 0
My cable/sat source is 2.0.
post #3922 of 3929 Old 12-27-2016, 08:56 PM
Packard93's Avatar
Quoted: 12 Post(s)
Liked: 3
MY 2808ci CONNECTED VIA PC HDMI WITH POLK MONITOR CENTER POLK CHANNels . Ive had it for long time And I have not heard a better unit . HDMI Sound Is spot on . Great unit Since I bought it on Ebay used . I use it daily . It get daily use . Been on since the day I bought it . It outlast a couple of my other units . Its over 5yrs I still love it. Play xbox 360 GTA V SOUNDS AWSOME WITH IT . GAMES ARE INCREDIBLE. MOVIES ARE AWSOME . I reviewed tons of units this one is most powerful unit to power per channel on sound and vision ht measures. I immediately bought it after I saw those numbers. Very high output does not loose power in frequency. Very solid unit.Its been super reliable since the day I bought it . Its never had any issues . I know the output and it blows any onkyo away sony pioneer those are cheap . Denon 2808ci is the master of sound.
Packard93 is offline
post #3923 of 3929 Old 02-10-2017, 10:00 AM
Quoted: 16 Post(s)
Liked: 0
Hi Jeff,
Do you know if when I assign Surround Back (SB) to BI-AMP it will aplly also to the Pre Outs?
I would like to connect the subwoofer in a Line Level configuration and was wondering if I could use the Pre-Outs, but I´m already using the FL and FR to conect to the AMP.
Tks
post #3924 of 3929 Old 02-10-2017, 02:44 PM
jdsmoothie's Avatar
Liked: 5515
Hi Jeff,
Tks
Who's Jeff?
No, will not apply to pre-outs. Note however, using the AVR's bi-amp setting is unlikely to provide any benefit in either power or performance.
post #3925 of 3929 Old 02-11-2017, 05:31 AM
Quoted: 16 Post(s)
Liked: 0
Who's Jeff?
Sorry I tought your name was Jeff .
Is there any pre-out that would give me the exactly same signal as the Pre-Out FL and FR?
Tkssss
post #3926 of 3929 Old 02-11-2017, 07:26 AM
jdsmoothie's Avatar
Liked: 5515
Tkssss
The FL/FR pre-out.
post #3927 of 3929 Old 02-11-2017, 01:09 PM
Quoted: 16 Post(s)
Liked: 0
The FL/FR pre-out.
I´m already useing those, would like an extra Pre-out with same signal.
post #3928 of 3929 Old 02-11-2017, 02:03 PM
jdsmoothie's Avatar
Liked: 5515
Then use a "Y" splitter cable from each FL/FR pre-out.
post #3929 of 3929 Old Today, 08:16 AM
Quoted: 16 Post(s)
Liked: 0
Tks!!!
Denon Avr 2808ci Receiver , Denon Avr 988 7 1 Channel Multizone Home Theater Receiver
