The "Official" Denon AVR-2808CI Owners Thread - Page 9 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #241 of 3951 Old 10-26-2007, 06:10 PM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
^Bump^ Anyone?
curlyjive is online now
post #242 of 3951 Old 10-26-2007, 07:24 PM
shogunprophet's Avatar
Does the 2808CI passthrough 1080p24? Thanks.
- Jon
shogunprophet is offline
post #243 of 3951 Old 10-26-2007, 07:25 PM
efjay's Avatar
- Jon
I have the 988, equivalent to the 2808 and it passes 1080p24 with no problems to my Toshiba DLP.
efjay is offline
post #244 of 3951 Old 10-27-2007, 07:33 AM
wabkab's Avatar
Originally Posted by curlyjive View Post
^Bump^ Anyone?
Sorry I can't do it with my 5.1 and zone 2 setup, but based on the post proccessing mine does(as advertized) I'm convinced it'll do what the manual states( ie. yes). I'm surprised no one has answered. Maybe a minority use 7.1?
Tony B
wabkab is offline
post #245 of 3951 Old 10-27-2007, 08:04 AM
wostertag's Avatar
- Jon
Yes it does. Running mine into a Pearl.
wostertag is offline
post #246 of 3951 Old 10-27-2007, 12:16 PM
knr
knr's Avatar
I just recently bought an avr 2808ci and am using only one of its HDMI inputs (DVD). The input source signal is from a BD PS3, passed thru a video-processor that de-interlaces and scales the signal. The receiver is just a pass-thru device to a Sony Pearl projector.
The picture goes blank after a few minutes. If route the signal directly to the projector without the receiver in the middle, everything runs fine.
Anyone have such a problem with the new denon avr 2808ci? I'd appreciate some advice/suggestions.
knr is offline
post #247 of 3951 Old 10-27-2007, 03:51 PM
wostertag's Avatar
does the 2808 post process 5.1 PCM to 7.1 using PLIIx? And if so, what modes will work with PCM 5.1 to 7.1?
Yes it does. I just sent 5.1 PCM from my PS3 to the 2808 (over HDMI), and yes it will use PLIIx to output 7.1. The PLIIx modes were Cinema, Game, and Music.
post #248 of 3951 Old 10-27-2007, 04:20 PM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Excellent! Thank you! I have a PS3 as well, so even better as a test!
This is my top pick so far in my search. Even over the 3808, which seem to be having alot of issues for some reason.
Is anyone having issues with their 2808?
post #249 of 3951 Old 10-27-2007, 05:08 PM - Thread Starter
Troyus's Avatar
Originally Posted by NoPlasmaYet View Post
Question.
Does the 2808 receive HD radio stations?
If you have an XM radio subscription, and get the XM addon for this receiver, yes it should. After looking through the manual, I noticed it has Neural Surround....and it also mentioned that "it's the chosen audio format of XM's HD Surround programming..."
So yep, HD Surround radio...apparently 3 channels are fully dedicated to using such HD radio content, not sure if that has changed or not...
Troyus is offline
post #250 of 3951 Old 10-28-2007, 03:34 PM
henryld's Avatar
Had a new unit fail durring initial auto setup and am currently awaiting a replacement from 6th Ave; going on 2 weeks now.
henryld is offline
post #251 of 3951 Old 10-28-2007, 03:36 PM
henryld's Avatar
Don't think that is what he meant. This unit does not have a built in HD radio tuner AFAIK.
henryld is offline
post #252 of 3951 Old 10-29-2007, 06:30 AM
NoPlasmaYet's Avatar
Quoted: 12 Post(s)
Henry,
You are correct. I was comparing it to the Yamaha 1800 and the 1800 says it receives "HD radio". So I wondered if the Denon did it too.
Thanks for your reply
NoPlasmaYet is offline
post #253 of 3951 Old 10-29-2007, 02:06 PM
Hopalong's Avatar
I don't have much experience with XM radio. How's the sound quality? Is it as good as well tuned FM?
Hopalong is offline
post #254 of 3951 Old 10-30-2007, 09:30 AM
wabkab's Avatar
The only thing I haven't figured out (and it may not be an inherent bug) is a video drop/sync issue? of 3-5 seconds when using HDMI(not via components) when commercial changes/and/or(I assume) resolution changes occur during TV broadcasts. I have a DirectvHD20DVR and thought that if I had fixed that problem by setting the box to 1080i output only, but that hasn't fixed it. I tried all the menu settings i/p scaler on vs off. Tried i/p scaler on resolution set to 1080i with no luck. I don't know if its a temporary handshake issue as my plasma read "no signal" during these dropouts. It seems if I passed everything as one resolution, it would work? I'd love not to default to Component as HDMI was one of the main reasons for me to get this Reciever.
Tony B
wabkab is offline
post #255 of 3951 Old 10-30-2007, 09:54 AM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
Do you have other HDMI sources that work fine? Such as a HD DVD or BD player? Movies have previews that may change from 1080i to 1080p and also switch sound formats. If you have one of those and it doesn't lose the signal than I suspect a handshake issue with the HR20. DO you have this issue going direct HDMI to the TV? I plan on using component with my HR20 b/c I have had issues with Directv's HDMI connections.
post #256 of 3951 Old 10-30-2007, 10:29 AM
wabkab's Avatar
I don't have any other HDMI sources to test(been waiting for this BluRay HD-DVD fiasco to settle out or just go with an new OPPO).. I haven't tried a direct connection to the TV--good idea, but I couldn't leave it like that and have the 2808 as the switcher.
I am assuming if I have the STB(HR20) set to either 1080i or 720p output resolution, that would be a set resolution. How does the Denon need to be set to just pass this through?
Another thought, I have the HR20 menu set to 480i,480p, 720p, 1080i. I did this because I wanted my analog out to be active for recording to DVD and maybe this is what causing the changes/video sync dropouts during broadcast.
Tony B
wabkab is offline
post #257 of 3951 Old 10-30-2007, 10:43 AM
curlyjive's Avatar
Quoted: 538 Post(s)
Liked: 247
I don't own the unit yet (though I did read the manual), but I think disabling the i/p scaler will just pass everything through as is. That said, I am not sure if it still needs to handshake with the Denon anyway. Those handshakes can be problematic between all kinds of devices.
If it works direct to the Tv, then the Denon must be having issues handshaking with it.
Just my guess.
post #258 of 3951 Old 10-30-2007, 11:35 AM
wabkab's Avatar
Just my guess.
I'll try a few things tonight and let you know.
Tony B
wabkab is offline
post #259 of 3951 Old 10-30-2007, 09:32 PM
rafale's Avatar
Wow.. Wabkab, You are still at it? I never have more than 1 or 2 sec of off time and I do get a lot of resolution changes...
rafale is offline
post #260 of 3951 Old 10-31-2007, 03:31 PM
paulsen's Avatar
In "Menu -> Input Setup -> Other" there is a setting called "Video Convert" with two choices: ON and OFF. The manual is not too helpful on the effect of this. It says "convert video input to monitor output format". I tried both ON and OFF but it didn't seem to make any difference.
All connections are with HDMI using the 2808CI in between the Blu-ray and the TV.
My TV and Blu-ray player are both Samsung and work just fine without the 2808CI in the middle so I am not sure what conversion could be required.
Can someone elaborate on this setting a little?
rcp
paulsen is offline
post #261 of 3951 Old 10-31-2007, 04:36 PM
wabkab's Avatar
Maybe it's my PDP(Vizio 50") that takes a little longer to sync? I haven't found a setting that gets the drops less than 5 to 6 seconds.
Tony B
wabkab is offline
post #262 of 3951 Old 10-31-2007, 04:47 PM
wabkab's Avatar
rcp
I assumed that is the converter for composite and S video to Component and HDMI.
Tony B
wabkab is offline
post #263 of 3951 Old 10-31-2007, 08:24 PM
wabkab's Avatar
I checked it on and off. It definitely is that. For instance, with it off, my DVD player would not display on my PDP fed with HDMI out of the Denon. My DVD is hooked up with component out on progressive scan(480p). Switch converter back to on and it's back on.
Tony B
wabkab is offline
post #264 of 3951 Old 11-01-2007, 04:13 AM
paulsen's Avatar
Thanks for the investigation. So in my case (all HDMI) the Video Convert setting is not involved one way or the other. That's what I observed but wasn't sure if I might have been missing something.
rcp
paulsen is offline
post #265 of 3951 Old 11-01-2007, 10:06 AM
wabkab's Avatar
rcp
Yep. In the manual, I think in very last section before the "brand" codes, there are 2 tables with the far left column being Video convert on and Video convert off, respectively. If you mull over that a while, it all makes sense.
Tony B
wabkab is offline
post #266 of 3951 Old 11-01-2007, 05:55 PM
henryld's Avatar
Got my replacement unit this PM from 6th Ave. Look forward to getting it set up this weekend. Sure I will have some questions for you people.
henryld is offline
post #267 of 3951 Old 11-02-2007, 06:30 AM
Bob0115's Avatar
I'm having the same issue. Right now, only running composite into 2808 and HDMI out to the TV. Thought it might be an analogue to digital conversion lag. Are you running HDMI into the receiver?
Bob0115 is offline
post #268 of 3951 Old 11-02-2007, 06:40 AM
ndjedinak's Avatar
Does anyone know what DACs the 2808 uses?
ndjedinak is offline
post #269 of 3951 Old 11-02-2007, 07:15 AM
Bob0115's Avatar
Recently purchased the 2808 and am kinda second guessing myself. I had an 1803 previously and pretty much just went and got the 2808 without doing a lot of listening to other receivers. Don't know if I'm confusing clean/clear sound with bright but it is as though the sound seems a little bright to me. Anyone do a lot of sound comparisons with the 2808 against Yamaha V1800, Onkyo 805 or Pioneer 91THX? If so, I would like to hear your impressions. Don't want to open up a debate on which one is best or anything, just looking for some past experience. Thanks.
Bob0115 is offline
post #270 of 3951 Old 11-02-2007, 07:16 AM
openwheelracing's Avatar
Liked: 36
http://www.ti.com/lit/gpn/dsd1608
as far as the sound of Denon. I find it neutral and perfect for my taste, and I usually prefer warmer sound (but accuracy is important to me). I have fairly neutral/warm speakers though (Rockets with upgraded capacitors). I compared the Denon to Onkyo 805 and Panasonic XR-55. I kept the Denon, returned the Onkyo and use the Panny in the bedroom. The Panasonic sounded VERY bright compared to the Denon.
I think your speakers have more to do with the brightness you are experiencing.
openwheelracing is online now
Denon Avr 2808ci Receiver , Denon Avr 988 7 1 Channel Multizone Home Theater Receiver
