How to use Tag Mclaren Av32R to control Proceed AMP 5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-13-2001, 03:53 AM - Thread Starter
Adrian Low's Avatar
I'm having AV32R (no EX install) and Proceed Amp 5. Proceed AMP 5 come with RJ45 communication port which support PHAST Intercomponent Communication Protocol and 1/8" mini jack with the presence of 5-12DC will turn on and absent of voltage will turn off. The AV32R is Phast and Crestron certified. How can I make use of them so that I can use my AV32R remote control to control the Proceed Amp 5 to turn-on and turn-off.
Adrian Low is offline
post #2 of 5 Old 03-13-2001, 07:09 AM
Buzz Goddard's Avatar
The cleanest and simplest way is to get the EX instal done and use the prgrammable switches that come as part of the upgrade.
Buzz Goddard
TAG Mclaren Audio
Buzz Goddard
GoddardGroup
Buzz Goddard is offline
post #3 of 5 Old 03-14-2001, 07:21 AM - Thread Starter
Adrian Low's Avatar
Dear Buzz, I'm staying in Singapore, the shipment cost will be at least 30% of my EX upgrade cost. I hear that the will be another hardware upgrade coming soon. I feel that it is more worth to upgrade more things at one time because I can save on shipment cost. Can you confirm with this ?
post #4 of 5 Old 03-14-2001, 08:38 AM
Soon, is a very relative term. I have no time frame, but it will be measured in months, not days. It would of course be simple if you were using a 100x5R, that can be triggered via the TAGtronic bus or via simple IR. Here in the states there are devices (from, for example, Niles) that can sense the difference in current draw between on and off on the processor and then trigger a power strip. There are also optical sensors which can detect the display turning on and in turn trigger a power strip. Neither method is fail-safe and neither method is inexpensive.
Buzz Goddard
TAG Mclaren Audio
Buzz Goddard
GoddardGroup
post #5 of 5 Old 03-15-2001, 08:11 AM - Thread Starter
Adrian Low's Avatar
Thanks for your advise.
Closed Thread Receivers, Amps, and Processors
