Difference between 2307CI & 2308CI or 887 & 888? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-29-2007, 05:32 PM - Thread Starter
RandysWay's Avatar
What is the difference between the AVR-2307CI and AVR-2308CI?
Also, I just noticed that the 887 and 888 models (respectively) are nearly the same receiver - what are the differences between the above models?
It'll be driving a pair of Definitive BP7002's, BP2X Rear Surrounds, CLR2002 Center and a SuperCube Reference Subwoofer, with a Sony Pearl VPL-VW50 or Black Pearl VPL-VW60 Projector, along with a Toshiba HD-DVD player.
Thank you!
- R
RandysWay is offline
post #2 of 5 Old 10-30-2007, 07:12 PM - Thread Starter
RandysWay's Avatar
Anybody?
- R
post #3 of 5 Old 10-31-2007, 07:18 AM
William Mapstone's Avatar
Liked: 54
did the 2308ci just recently replace the 2307ci?
PSN: UndeadREDD
My Racing Seat
William Mapstone is offline
post #4 of 5 Old 10-31-2007, 09:07 AM
PLincoln's Avatar
it did...and while they were at it, they removed the pre-outs from the 2308 that the previous model had....step backwards
the general diff between the CI's and 887/888 is that the CI's are for Custom Installers ... they offer some settings not available on the non CI's ... functionally they are the same
PLincoln is offline
post #5 of 5 Old 10-31-2007, 09:21 AM
naschbac's Avatar
The biggest difference between the old 887/2307 and the newer 888/2308 is that the newer models use DCDi video processing and accept 1080p analog signals for Component->HDMI upconversion. Considering the only 1080p component analog device I know of is the Xbox360, and it's native res is 720p, and all the new ones have HDMI... this probably isn't a show-stopping difference between the old Denon's and the new ones.
The 887 can be found for cheap if you scour, and if you like the Denon sound it's a good buy. I just compared it to an HK AVR 247 and a Sony STR-DG1000. Of the three I ended up keeping the Sony, which absolutely shocked me as until now I've never liked their receiver products.
naschbac is offline
