What exactly is HDMI™ switching? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-02-2007, 07:39 PM - Thread Starter
causeofhim's Avatar
Is a receiver has HDMI switching what exactly does this mean? Will I be able to hook up all components using HDMI and other connections and run only HDMI to my projector?
causeofhim is offline
post #2 of 9 Old 11-02-2007, 07:44 PM
gunbunnysoulja's Avatar
No, that would be transcoding (sometimes misused as upconversion, even when no scaling is being done).
HDMI switching is the same as passthrough.... ex.- 2 inputs, 1 output.
gunbunnysoulja is offline
post #3 of 9 Old 11-02-2007, 07:56 PM - Thread Starter
causeofhim's Avatar
So an HDMI switching receiver will not be able to do this?
post #4 of 9 Old 11-02-2007, 08:00 PM
rudolpht's Avatar
Post the specific receiver and we'll let you know.
If you mean you have multiple HDMI components in to one HDMI out to the set, then you may be all set. If you need upconversion of non-HDMI component/S-video/or composite inputs it depends on the unit.
Better info in means better info out, posts are like TVs
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #5 of 9 Old 11-02-2007, 08:12 PM - Thread Starter
causeofhim's Avatar
Harman Kardon HK AVR 147
post #6 of 9 Old 11-02-2007, 08:22 PM - Thread Starter
causeofhim's Avatar
Or. . .If I run HDMI and component cables to the projector, would that work?
post #7 of 9 Old 11-02-2007, 08:28 PM
The 147 does not do any transcoding. What ever you connect to the inputs, you must output the same cables.
post #8 of 9 Old 11-02-2007, 09:06 PM
M Code's Avatar
Quoted: 718 Post(s)
Liked: 421
HDMI switching only is actually a pass-through function.
HDMI processing comes @ a higher price, so switching only provides the ability of the AVR the ability to handle an HDMI source such a Blu Ray player. The HD video Out from the Blu Ray goes into the AVR via HDMI and then out to the video display via HDMI, while the audio is handled either through S/PDIF (coax or optical) or analog.
Now HD video and audio are switched together, there will be a slight drop in the audio quality but the $ cost of the AVR will be lower and more competitive if one is on a tite budget..
M Code is offline
post #9 of 9 Old 11-02-2007, 09:20 PM
rudolpht's Avatar
There are many Manuals that discuss HDMI switching even for high end units, it's called English, do a search on high end receivers that do not only transcoding of non HDMI signals but do motion adaptive 1080i deinterlacing. My Anthem does HDMI switching and it has a high end Gennum chip, that's WHY it's important to get more information than a catch phrase. It's important to answer questions more than on a "keyword" without context. Incidentally, there are HDMI switching units that do not transcode but DO switch audio.
Please watch out for pseudo-Experts around here that talk about HDMI into displays when HDMI into video processors is the thread or make glittering generalities without basis of facts. Thanks to gunbunnysoulja for actually answering the question based on full context and not extrapolating "switching only" into the meaning.
Tim
rudolpht is offline
