Can someone recommend a good receiver with HDMI audio for less than 350? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 11-04-2007, 04:28 PM - Thread Starter
skippy911's Avatar
I have my new HD-A2 and xbox 360. I want to replace my aging 5.1 channel Yamaha receiver with a receiver that supports hdmi video passthrough and also allows the audio from the hdmi to be passed to the speakers. Most receiver I have seen only allow the video to passthrough to the tv. My budget is about 350. I found the Sony STR-DG810 but I am not sure how good a receiver it is. My current speaker setup is 5.1 and I dont plan to add any more speakers for a while so 5.1 would be fine as well. Any help is greatly appreciated
skippy911 is offline
post #2 of 14 Old 11-04-2007, 05:51 PM
SierraMikeBravo's Avatar
Quoted: 334 Post(s)
Liked: 214
If you can swing a few dollars more, the Onkyo 605 is a pretty nice setup and rather popular with members here on the board. Amazon has them for $420 with free shipping and it offers the latest Surround decoding formats and HDMI connection plus 7.1 surround. Not a bad buy. Spend the extra $70 bucks. You'd pay that if you bought locally with tax anyway.
Good luck!
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is online now
post #3 of 14 Old 11-05-2007, 12:27 PM
samsurd2's Avatar
I took a quick look via Nextag.com this morning and found the Sony STR-DG910 for $330. It's a better choice at that price the DG810 (7.1, 3 HDMI in/1 HDMI out, converts/transcodes composite & component video to HDMI, plays high def audio received as PCM from HD-A2, etc). OTOH, if you decide to stretch your budget, also consider the Yamaha RX-V661 and Sony STR-DG1000.
samsurd2 is offline
post #4 of 14 Old 11-05-2007, 04:15 PM
Hunter844's Avatar
I've currently got a Onkyo 604 and wanted to know how much of an upgrade there is to a Onkyo 605?
Looking for all the loseless surround formats and realize the 605 seems to be the logical choice...just wanted to some opinions on "Is it worth it". Right now my Toshiba A2 sends the Dolby True HD as Multichannel PCM which sounds alright but I'm not totally impressed.
Thinking about maybe making another leap in "quality"...but then again I've got a smaller living room so I don't know that I need some sort of $800 AVR
I've got the following to give you an idea what I'll be working with
LG 1080p 42'' LCD
Toshiba HD-A2
Onkyo 604
PSB Alpha T fronts
SVS NSD 10 and SVS center
Cheap Samsung surrounds (this is probably my next upgrade)
Brand new HTPC I built myself using optical out
Dish Network HD
Hunter844 is online now
post #5 of 14 Old 11-05-2007, 04:19 PM
gunbunnysoulja's Avatar
LG 1080p 42'' LCD
Toshiba HD-A2
Onkyo 604
PSB Alpha T fronts
Dish Network HD
The 605 will do exactly the same thing with the audio from the a2 as the 604, Multi Channel PCM. If your not satisfied with the sound, its not because its being sent as Multi Channel PCM, as its bit for bit identical.
gunbunnysoulja is offline
post #6 of 14 Old 11-05-2007, 04:34 PM
Hunter844's Avatar
So is the marketing of it supporting these next gen formats just hype? Or is it just that the 605 is as limited as the 604 in this regard? Is this the toshiba's doing and no receiver has anything to do with it?
The big thing I don't like about the Multichannel PCM is I can't get it to go into 7.1 mode and I tend to like the sound of that. I also find that some HD-DVD movies seem rather low volumed which I understand I'm am supposed to adjust accordingly. If it's supposedly ossless audio...why is it so low sounding when it comes out the other end
post #7 of 14 Old 11-05-2007, 04:41 PM
The 605 is not limited with internal decoding, the A2 is limiting it. You would need a player that can send High Resolution Bitstream, like the A35. Again, the only difference should be that the TrueHD light will light up, as the sound quality should be the same.
If you want to matrix 5.1 MC-PCM to 7.1, that has nothing to do with being PCM also. That has to do with the specific receiver. Some receivers allow this. Level 5 or Level 6 category in this thread:http://www.avsforum.com/avs-vb/showthread.php?t=738511
The Onkyo 604 is a level 3.5, and CAN NOT matrix 5.1-7.1 PCM, like you said. The Onkyo 605 is a level 4, and also CAN NOT matrix 5.1-7.1 PCM.
You NEED to understand low volume = GOOD. It is called DYNAMIC RANGE, which is an incredible advantage to TrueHD. Quiet will be quiet, and loud will be loud.
post #8 of 14 Old 11-05-2007, 05:25 PM
scdaf-'s Avatar
Skippy, check your pm
scdaf- is offline
post #9 of 14 Old 11-05-2007, 05:39 PM
Hunter844's Avatar
Thanks for the thread referal. I think I'm going to wait tell there is more information...hopefully spring 2008 will bring more support for post processing to 7.1 (Levels 5 & 6) especially for sub $500 range.
post #10 of 14 Old 11-05-2007, 05:47 PM
If your not against refurbs, this receiver is GREAT for the price and is level 6:http://www.ecost.com/detail.aspx?EDP=36683261
Heres another site that has it in stock for the same price:http://www.secondact.com/product/AVR...r__AVR887.html
post #11 of 14 Old 11-05-2007, 06:11 PM
playball49's Avatar
Does anyone have the onkyo 504 and is useing it with the A2. If so i would to know how it is working for you.. I have one it is brand new and never use it yet.
playball49 is offline
post #12 of 14 Old 11-05-2007, 06:30 PM
The 504 is a decent receiver and sounds good. The only downside is it doesn't process Multi-Channel PCM over HDMI.
post #13 of 14 Old 11-06-2007, 04:10 AM
Jack Gilvey's Avatar
Quoted: 35 Post(s)
Liked: 34
As noted, that's what TrueHD is, packed PCM. Like a zipped computer file. DTS-HD MA also. And while such lossless compression means that the resulting data is identical to the master, it doesn't guarantee that the master itself is full of excitement.
It's also possible that many systems benefit from a more limited dynamic range.
And, breathless initial assertions to the contrary from new adopters notwithstanding, the jump to lossless is usually fairly subtle compared to a very good lossy track for most systems/people. Especially if you're actually watching a movie and not squinting into your eyelids listening for sonic revelation.
The Yamaha 661 mentioned above will do that, ~$400.
Jack Gilvey
SVS Customer Service
Jack Gilvey is offline
post #14 of 14 Old 11-06-2007, 05:20 AM
Murilo's Avatar
Quoted: 126 Post(s)
Liked: 30
661, was in the same spot as you last month, sounds the best, and does loseless hdmi audio
Murilo is offline
