Denon 3801 Pre/Pro quality vs. Hi End? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 03-22-2001, 11:31 AM - Thread Starter
PanamaMike's Avatar
Yes, I'm beating this Denon 3801 thing to death, but I'd like to know how it truly compares. I know the amp section is not great, but I'm just interested in the pre/pro since it uses the SHARC DSP technology. Taking this into account how does it compare with the big boys,
Lexicon
Tag
EAD
Proceed
B&K
How does this pre/pro stack up? Is the difference night and day, or does the pre/pro performance approach these units. I've seen great values in amplification such as:
Sunfire
Bryston
Aragon
so where is the equivalent in the pre/pro arena?
PanamaMike is offline
post #2 of 6 Old 03-22-2001, 12:33 PM
fitsman's Avatar
I had a 3801 on loan for about 4 weeks before my B&K Ref 30 came in. In DD or DTS mode there was not a big difference, unless your speakers are very power hungry. But in two channel mode, I noticed a big difference. Especially handling analog signals. I have a SACD player it sounds much much better with the Ref 30 than it did with the 3801.
Both were used as just a pre-amp. I have B&K AMPS for my amplification. So I really cannot comment on the amp section of the 3801.
fitsman is offline
post #3 of 6 Old 03-22-2001, 12:37 PM - Thread Starter
PanamaMike's Avatar
That's exactly the type of information I'm looking for in a reply. Thanks!
post #4 of 6 Old 03-22-2001, 02:17 PM
usabrian's Avatar
Yes the stereo is the only weakness this thing has. For me, it doesnt matter much because i have gotten to the point that i only listen to it in 5-channel stereo, which is incredible on this unit. In dts or dd i'd challenge anyone to find much of a weakness.
Brian
Zed's dead baby, Zed's dead.
[This message has been edited by usabrian (edited 03-22-2001).]
Guide to Internet Forum Posting: Posting and You
usabrian is offline
post #5 of 6 Old 03-22-2001, 04:27 PM
jerndl's Avatar
Quoted: 33 Post(s)
<font face="Verdana, Arial" size="2">Originally posted by fitsman:
In DD or DTS mode there was not a big difference, unless your speakers are very power hungry.</font>
This may be a dumb question but since you are using the 3801 as a pre-amp only and using external main amps how do power hungry speakers make a difference. Thanks.
Jay
jerndl is offline
post #6 of 6 Old 03-23-2001, 10:30 AM
fitsman's Avatar
I did not try to use the 3801 internal amps, but its rated at only 100 watts. That part of it was just an opinion, not tested.
fitsman is offline
Closed Thread Receivers, Amps, and Processors
