The Official Onkyo TX-SR705 Thread (FAQ in 1st Post) - Page 297 - AVS | Home Theater Discussions And Reviews
post #8881 of 8910 Old 03-24-2014, 06:44 PM
chappatti's Avatar
Really need some help!!
I bought a DTR-50.2, but I cannot ifnd the serial number sticker anywhere on the receiver. It is supposed to be a white label with 10 digit number. But I have searched, and searched the back and there is absolutely no label... None.
I called up Integra support and they say it must have one.
IS there any way I can look it up in the firmware? Is there a hidden service menu that lists the serial number....
This is driving me nuts !!!!!!!!!!!!!!!!
Thanks for any help.....
chappatti is offline
post #8882 of 8910 Old 03-24-2014, 06:58 PM
Lordhits's Avatar
Sure you have the right forum? This is the Onkyo TX-SR705 forum.
Lordhits is offline
post #8883 of 8910 Old 03-24-2014, 07:02 PM
chappatti's Avatar
This is the only forum that came on my search about hidden menu settings, and since Onkyo=Integra, I posted here. If there is an official DTR-50.2 thread, I would gladly post there......
Thanks !
post #8884 of 8910 Old 04-18-2014, 11:58 AM
ComponentActual's Avatar
Quoted: 20 Post(s)
Okay so I read the entire Owners FAQ (1st post), but am still very confused about what listening mode I should use with a 5.1 speaker setup. The FAQ said that I should just leave it on Multichannel Audio, yet I don't have that listening mode. The only thing I seem to have is mono, stereo, Direct, and Dolby D, so I am using Dolby D for now. This may be because I don't have my rear channel speakers hooked up yet, so I basically have 3.1 speaker setup right now. I disabled all the surround speakers in the speaker setup menu. When I do get my rear speakers what is the best listening mode for both movies and cable? My cable box has an option to output audio is surround sound. It doesn't specify what format of surround sound it uses it just gives you two options stereo or surround it is hooked up using HDMI. The cable box is for AT&T Uverse.
ComponentActual is offline
post #8885 of 8910 Old 04-18-2014, 10:01 PM
Robbiey60's Avatar
Quoted: 20 Post(s)
Liked: 237
I use multichannel pcm sent via hdmi from ps3, thats for blurays. Not sure of your cable as im from nz, my cable bitstreams dolby digital 5.1 through optical. All above using audessey, fronts set to large, double bass on and center and surrounds set to 60hz. Music is 2ch stereo, audessey off. Hope this helps, if not let me know
(2)RF-82ii (1)RC-64ii (2)RC-62ii
(2)Exodus audio tempest-x 15" 200l sealed enclosures (1)Velodyne CHT-12Q
Onkyo 705
Behringer EP4000
NAD C275BEE
AMC 2N100-3
Robbiey60 is offline
post #8886 of 8910 Old 04-21-2014, 10:32 AM
Quoted: 20 Post(s)
Just watched the Cosmos last night on Fox, it is one of the few shows that seem to be broad cast in full 5.1 channel Dolby Digital. It sounded completely amazing. I think I will be using that mode whenever it is available, and I will just keep playing around with PLII, THX5.1, and Neo 6, till I decide which upmixes stereo the best.
Have a new problem now. I am having troulbe getting the system loud enough. Even at max volume the system is only a moderate volume, few would consider it loud. It is quite annoying. I had run the Audyssey set-up and I guess I had my subwoofer turned down to low during the setup cause it had set it at 0db and everything else at -7 to -4. Well it appears that having the sub set higher than the other channel wouldn't allow the other channels to reach max volume cause the sub would reach max volume first and in order to preserve the differences in volume between the channels the receiver wouldn't allow the other channels to increase in volume any further. So I fixed this by lowering the sub to the same volume as the other in the setup and then cranking the gain on the back of the sub. But this only have me another 5db and while it was a noticeably improvement I still wouldn't call it loud. I was finally able to get the system to play loudly by turning up the intellivolume setting to +12. This allows me to reach the level of loudness that I desire while still being around 20db from the receiver's maximum volume setting. Are there any drawbacks to using intellivolume? Are there any other settings I should be looking at to squeeze volume out of the system?
post #8887 of 8910 Old 08-02-2014, 07:21 AM
wraunch's Avatar
Quoted: 88 Post(s)
Liked: 32
Ok so I have a newly built dedicated theater. I have a 705 hooked up to 3 M&K 750 THX for LCR and 2 550thx speakers for surrounds. I ran audessy and it dialed everything down from -1 to -4 DB. I am currently having to run it up to about -15 to get the level of sound I'm looking for. Wondering if I need to add a separate 3 channel amp for the fronts or if it's time to retire the 705 and move up. Thoughts?
wraunch is offline
post #8888 of 8910 Old 08-04-2014, 05:27 PM
deano86's Avatar
Quoted: 52 Post(s)
Liked: 58
So, what exactly is the problem? If it sounds good at -15, who cares? If you performed Audyssey correctly, you are still 15 db below reference level.... Depending on the source or soundtrack, then that level is probably fine...other sources -15 is probably blasting... Unless your speakers are literally starting to sound bad(clipping) or your 705 goes into protect mode after a while at your preferred volume, then you really don't have a problem... More than anything I could see you upgrading the 705 for additional or preferred features as opposed to lacking power. Trust your ears, and don't worry about what the volume display says....
deano86 is offline
post #8889 of 8910 Old 08-04-2014, 06:56 PM
IntelliVolume's Avatar
Quoted: 344 Post(s)
Liked: 67
Raunch,
As a long-time Onkyo owner and enthusiast, this is something that has always bothered me and many others that own this company's electronic gear (the "low volume as it reads on the volume display" thing) -- I own the receiver that's a step down from yours, the TX-SR605, but have some suggestions because I too am one of those that are "bugged" by the readout level on the receiver's display (even if this is all just a mental/placebo thing). First -- are all sources connected to your 705 exhibiting the volume output thing (needing to turn it up to -15dB)? If it's one source in particular, go into the AVR's SOURCE SETUP in the Setup Menu and look for INTELLIVOLUME -- this controls the "output" level of the connected sources (almost like old power amps of their day and their "sensitivity controls"). Try jacking the source you're questioning (BD/DVD, CD, Tuner, etc.) up to +10dB on IntelliVolume...let me know how that sounds after you do. I have more suggestions after that...
IntelliVolume is offline
post #8890 of 8910 Old 08-05-2014, 07:14 AM
wraunch's Avatar
Quoted: 88 Post(s)
Liked: 32
Thanks for the suggestions I will take a look tonight. I think it's quieter on my Xbox 1 which i use for games and blu rays. I will check the intellivolume. Also I wasn't pleased with the Audyssey calibration. It set my LCR to 150hz on the crossover and set my sub to 90 hz. I had no bass anywhere.
wraunch is offline
post #8891 of 8910 Old 08-05-2014, 07:19 AM
wraunch's Avatar
Quoted: 88 Post(s)
Liked: 32
Do you see any issues with me splitting the sub output to run two active subs? I have a M&K V1250 and an Elemental Designs A2-300 I'd like to run if possible. Currently the V1250 is not getting it done in this space.
wraunch is offline
post #8892 of 8910 Old 08-05-2014, 03:18 PM
Quoted: 344 Post(s)
Liked: 67
Raunch,
PM me for non-Audyssey setting suggestions...
post #8893 of 8910 Old 08-11-2014, 08:57 PM
deano86's Avatar
Quoted: 52 Post(s)
Liked: 58
Originally Posted by Steve Bosworth View Post
Firmware , cant find version.
Hi I am new here so hope I am posting in correct place. I am about to add a blu ray player to my TXSR 705 and have read about this "gunshot problem". I have tried to find the firmware version by
1) Turn on Receiver
2) HOLD down the "Display" button and press "Standby" button once.
3) Release the "Display" button.
4) Press the + or – keys to cycle forward and backward through all the firmware display pages.#
However all that is displayed is "unknown" and an arrow sign
Is the + - keys the one buttons on the front of the unit or the remote control? Unfortunatly my remote has broken - battery contacts went rusty and broke , and I am trying to obtain a new one.
Any help appreciated.
Regards
Boz
Yes, you use the keys on the receiver itself... not the remote. You must not quite be holding/releasing the buttons at the proper time... here is the actual DSP firmware update instructions... for what it's worth!
http://www.nitarosemassage.com/DSP%2...05-805-875.pdf
deano86 is offline
post #8894 of 8910 Old 08-12-2014, 06:42 AM
deano86's Avatar
Quoted: 52 Post(s)
Liked: 58
Well, you may indeed be fine as far as the DTS bomb being already fixed. You may just not have the very latest DSP firmware that was issued.... Contacting Onkyo tech support for certain would be a good idea. Otherwise, what you could do is just use the Multichannel PCM audio option on your player to send the lossless sound to your 705, instead of bitstream.
The loud "gunshot" type defect is only for DTS bitstreamed to the receiver.. PCM removes that possibility... This spike noise you talk about probably isn't the DTS bomb defect... if you actually are bitstreaming a "DTS soundtrack" and your receiver does the defect, you will know it! By all accounts, it is extremely loud... like jump out of your chair loud....
deano86 is offline
post #8895 of 8910 Old 08-12-2014, 04:53 PM
Robbiey60's Avatar
Quoted: 20 Post(s)
Liked: 237
Thanks very much deano, to be safe I will go with the PCM option ! Tried the two settings and I think there may be only very very slight difference in the sound, PCM a little bit quieter, so will just turn it up a bit.! Also taking your advise contacting support. I assume its ok th leave Dolby Digital HD in bitstream and its just the DTS ones as my player lists both?
Really appreciate your advise on this
Cheers
Boz
I found with dd and dd truehd via bitstream I got loud random screethes from my speakers. I run all PCM now and haven't had a problem. The 1 issue I have had since new, still excellent as my pre/pro.
post #8896 of 8910 Old 09-12-2014, 07:20 AM
Liked: 0
Receiver goes into Audyssey setup mode unexpectedly at various times. It will enter setup mode telling me to "place the microphone...." while I am viewing a TV program. Very annoying....
Any one else having this issue?
Any suggestions how to fix?
TIA
SNiCJet is offline
post #8897 of 8910 Old 09-19-2014, 08:58 AM
MattG!'s Avatar
Liked: 0
Anyone one else running Redmere HDMI cables with their Onkyo 705?
I have the Samsung 60f8500, Im having intermittent signal loss issues. It worked fine when I first plugged them in, then the next day I get a no signal error even though everything is plugged in. If I shut everything off, unplug the HDMI cable, it may work again. This method is hit or miss though.
I thought it was just a bad cable, so I replaced it with another. Worked fine for a day, then "no signal" error again. I tested a regular HDMI cable direct from Fios box, but that wasn't working either....But I still had the Redemere cable plugged into the TV to receiver in another port. When I removed the redmere cable, I get audio/video fine with just the regular HDMI.
Wondering if it's the receiver or TV not playing nice with these cables.
MattG! is offline
post #8898 of 8910 Old 09-23-2014, 10:54 PM
Quoted: 51 Post(s)
Liked: 1
Hi, I just picked up one of these TX-SR705's today on craigslist with a setup mic and remote. Boy it works nice, I've got a Yamaha RX-A830 to compare it to, that I am returning, and the Yamaha sounds "weak" in my sisters words. I got the new Yamaha to compare with my RX-V661 that I had been using, and in all honesty the difference from the 661 to the new 830 was rather slight. I'm running amplified speakers off of the preamp outputs (studio monitors). This brings me to my next question, will the new TX-NR828 sound similar to this TX-SR705? The 7 series don't have preamp outs on the new models. If the differences are as slight as on the old vs new Yamaha, I'm going to get the new model soon, as I really would like to have Dynamic EQ and Dynamic Volume. I had that on a Marantz SR5005 I tried, and loved how it sounded to use those features for late night listening. I however didn't like the Marantz sound overall and sold it. I also tried an older Pioneer Elite, and found it to be overdone on the bass. The Onkyo is the first receiver I've tried that actually got it right, once I ran Audyssey on it.
One key difference I notice between the 705 and the 828 is the new model does not have MultiEQ XT, it just has MultiEQ. Will this make a big difference? I ask here as I figure owners of the 705 receiver have heard the new ones, and might know the difference.
NetTechie is offline
post #8899 of 8910 Old 09-24-2014, 03:21 PM
Robbiey60's Avatar
Quoted: 20 Post(s)
Liked: 237
I haven't heard the new ones, but imho I wouldnt downgrade the audessey. I have been looking at maybe upgrading my receiver but to properly upgrade I would want audessey XT32. I also run seperate amps so next step is to check out pre/pros, but if I cant find a decent price for one with XT32 I doubt I will upgrade just yet.
post #8900 of 8910 Old 10-15-2014, 06:27 PM
CountryBumkin's Avatar
Quoted: 70 Post(s)
Liked: 26
I have a similar setup - but the 64F8500 set. I have not had any issues so far feeding Video and Audio from my HTPC through Onkyo and to Samsung. However, I'm not using the Redmere cables. I believe those cables have the chip in them and must feed the signal in a specific direction (meaning on end must go to AVR and the other to TV. Swapping ends around will/may cause a problem).
CountryBumkin is offline
post #8901 of 8910 Old 11-28-2014, 06:18 PM
DrDarwin's Avatar
Hi all,
Has anyone had issues with Chromecast and video pass through on their 705? All I get is noise when going through the receiver. No issues when plugged in directly.
I've tried various settings/input assigns with no avail.
Ty
Edit: So it seems this is related to the common issue of not being able to properly pass through 1080p content....
DrDarwin is offline
post #8902 of 8910 Old 12-26-2014, 05:27 AM
guzie's Avatar
Just popped in here and noticed your xbox one being quieter issue. There are two digital output options in the xbox, one for DTS and one for Dolby Digital. If you use the Dolby Digital bitstream option it will be louder output than the DTS option. I don't play blu ray discs in my xbox one anyways because it doesn't output a clean unadulterated bitstream to the receiver for decoding. It sends the Dolby digital or DTS bitstreams but they are not the full 7.1 blu ray bitstream you want. You want to play the blu ray disc on a dedicated blu ray player set to bitstream so the receiver can properly decode into DTS Master or True HD for the full range of sound. Your ears will thank me.
guzie is offline
post #8903 of 8910 Old 12-26-2014, 05:30 AM
guzie's Avatar
Originally Posted by DrDarwin View Post
Hi all,
Ty
Hmmm. I pass thru 1080p on my receiver just fine. I only have one other 1080p source going direct to the tv because I ran out of hdmi inputs on the receiver. All others pass through and show as 1080p on my Samsung HLT5687 DLP tv.
guzie is offline
post #8904 of 8910 Old 12-26-2014, 08:57 AM
DrDarwin's Avatar
That's strange. I wonder why mine has issues then. I'd assume it was my projector, but any of the sources that I have problems with stream just fine when connected directly to it.
DrDarwin is offline
post #8905 of 8910 Old 12-26-2014, 11:05 AM
guzie's Avatar
Wonder if it's a hdmi handshaking issue? Any other 1080p displays to test it on?
guzie is offline
post #8906 of 8910 Old 01-28-2015, 02:05 PM
spank2223's Avatar
Problem, just started, I have noticed every now and then, I get loud screeching sound coming from the speakers. Coming from the cable box, blu-ray player. Happens randomly but often. Any idea why?
I have all sources running hdmi into the 705 and then out to tv. Speakers are hooked up to the 705.
spank2223 is offline
post #8907 of 8910 Old 02-04-2015, 10:49 AM
dtlocke's Avatar
Liked: 4
Any kind of "loudness" compensation in the 705?
Can anyone advise if there is any kind of loudness compensation available in the 705, or suggest a clever way of getting there? I'm talking about boosting the bass at low volume levels, I think it's Dynamic EQ in newer receivers with Audyssey
I read the manual twice and couldn't find anything.
We listen to music at low levels when we go to bed and all we hear is mid and highs... And I'd rather not have to jack with the bass all the time...
Thanks and sorry if that has been hashed out before, I couldn't find anything...
-Dick Locke
dtlocke is offline
post #8908 of 8910 Old 02-12-2015, 07:55 AM
Liked: 0
Screeching, popping sound at random
@spank2223 , I have a similar issue. I got my 705 in 2007 and have been living with the noises for years. Sometimes it went days without making the noises, but more recently it became more frequent. I've never had any problems with video output. All my stuff is connected via HDMI. I have a Comcast/ Motorola DVR cable box, a second generation Apple TV box, and a Panasonic blu-ray player connected to a 2007 vintage Panasonic plasma. I believe the TV only does 1080i, and I know the Apple and Comcast only do 1080i. Because the noises recently got worse, I contacted Onkyo and asked for a firmware upgrade. They sent me an upgrade CD right away. I did the firmware upgrade and I don't think we've heard the noises since, but it's only been a few days since the upgrade so we're not out of the woods yet.
DavidAdams is offline
post #8909 of 8910 Old 02-12-2015, 08:09 AM
deano86's Avatar
Quoted: 52 Post(s)
Liked: 58
Yes, there was a DSP firmware update that dealt with noise issues such as this.. Specifically from bitstreamed, I believe. You could also switch your sources to PCM audio output or analog where possible as an alternative...
deano86 is offline
post #8910 of 8910 Unread Today, 07:41 AM
Liked: 0
Can anyone point me in the direction of any websites to get a replacement remote control in the UK really struggling to find one. My battery contacts rusted and fell apart. I don't actually need it at present as I use a universal remote to control my home cinema but a backup remote would be handy. I have been quoted £60 for a new one, but if I could pick up a replacement that works but not necessarily the original would be nice.
Also I have never been able to do the DSP update on my amp using my Onkyo DV-SP502 player, anyone had any luck updating it with this player?
Cheers
Steve Bosworth is offline
Onkyo Tx Sr705 Receiver
Gear in this thread - Sr705 by PriceGrabber.com
