Bryston/Lexicon amp break-in time needed? - AVS Forum | Home Theater Discussions And Reviews
Old 03-23-2001, 12:17 PM - Thread Starter
lolittle's Avatar
I've had my new Bryston 4B ST for about a week now. I have 95 hours on it. About half of that was break-in noise (track 20 of the Stereophile Test CD #3) & dynamic music (music at 80-90db).
It sounded great right out of the box. As far as I can tell, it sounds better every day. It's hard to tell, as I'm also breaking in my third pair of B&W Nautilus 804s. I had finish problems with the first 2 pair. My previous 804s took at least 200 hours to break in.
Anyway, how many hours does it normally take for Bryston/Lexicon amps to break in?
Lynn Olan Little
lolittle is offline
Old 03-23-2001, 02:07 PM
John Kotches's Avatar
Worm. Cans. Opened.
Lolittle -- the amp would be broken in long before break in of the speakrs is completed.
A lot of argument gets bounced back and forth over what's getting broken in on components (non speakers), the actual device or your ear/brain interface.
Contributing Writer,
Secrets of Home Theater and High Fidelity
Contributing Editor & Surround Music Reviewer Widescreen Review
Opinions are mine, not the publication I write for.
John Kotches is offline
Old 03-23-2001, 08:28 PM
Buzz Goddard's Avatar
John, just answer the question.
382 hours. At least between lattitudes 20 and 47.
Buzz Goddard
TAG Mclaren Audio
Buzz Goddard
GoddardGroup
Buzz Goddard is offline
Old 03-23-2001, 08:55 PM
David Panko's Avatar
Buzz - how many hours if north of 49°?
Bryston burns-in their products as part of QA:
<font face="Verdana, Arial" size="2">Each of our fully assembled products is connected to what we call a "burn-in table." For example, during 100 hours of continuous testing, our amplifiers are monitored through a range of input cycles and thermal stress levels to duplicate a broad spectrum of operational loads. If any failures occur, we want to catch them here, before you begin using our product.</font>
http://www.bryston.ca/mission.html
Dave.
[This message has been edited by David Panko (edited 03-23-2001).]
David Panko is offline
Old 03-24-2001, 09:07 AM
Thanks Dave.
FYI, the reason the Lexicon OEM'd amps exist is because I selected them as the best price/performance on the market. I am pretty familiar with them...
Oh, North of 49, no worries, you'd leave them on all the time to help heat the house. And they do sound better warm.
Buzz Goddard
TAG Mclaren Audio
Buzz Goddard
GoddardGroup
