SSP & Pre/Pros that support HDMI Audio MPCM - Page 27 - AVS Forum | Home Theater Discussions And Reviews
post #781 of 1049 Old 07-26-2009, 10:10 AM
Haroon Malik's Avatar
The specs of the ADA Cinema Rhapsody Mach IV flagship HT preamp controller are on the official website now:
http://www.ada.net/products/ht/cinem...sody_mach4.php
- Dolby TrueHD & DTS HD Master Audio
- Multi-Channel (192KHz/24 Bit) PCM Audio
- Full 7.1 EX/ES, THX Ultra 2, Dolby Pro Logic IIx, DTS Neo 6
- 8 HDMI Inputs with HDMI Equalization Settings per input
- 2 (Dual) Mirror HDMI Outputs with HDMI Equalization Settings
- Parametric Multi-Band Equalizer
- 8 Stereo Analog Audio Inputs
- 6 Digital Audio Coaxial Inputs
- 2 TOS-Link Optical Digital Audio Inputs
- 8 Channel DVD Audio/SACD Input With Bass Filters
- 8 Composite Video Inputs
- 8 S-Video Inputs
- 8 Component Video Inputs
- Analog And Digital Audio Record Outputs (2nd Zone)
- 2 Main And 2 Record (2nd Zone) Composite Video Outputs
- 2 Main Component Video Outputs
- Rear Panel Ethernet Connection (ADA Net)
- 2 Programmable Low Voltage Output Triggers
- ADA MX-900 (Universal Remote Control) Included At No Additional Charge
- 90-260Volts AC 50/60Hz 40 Watts
- 23 lbs 3.5"H x 19"W x 17.5"D
The "Trinnov" logo is on the front faceplate. The Mach IV looks mighty impressive by the look of things. Can't wait for user reviews.
Haroon Malik is offline
post #782 of 1049 Old 07-26-2009, 10:19 AM
kal
kal's Avatar
Quoted: 17 Post(s)
Liked: 76
Certainly look impressive but I question how seriously you can take a company that has SPELLING MISTAKES on the front display of their unit!
It's not "Blueray". It's "Blu-ray". It's also not a "Blueray DVD". It's simply a "Blu-ray". It's not "DVD". That's a different product. Sony's done a lot of work to brand Blu-ray for what it is and not as DVD - they don't want the word "DVD" used to describe Blu-ray.
They even do this on their site here:
Where they say:
The Cinema Rhapsody Mach IV decodes all the latest Dolby TrueHD, DTS-HD Audio Master and Multi-Channel PCM soundtracks found on Blueray DVDs.
IMHO, pretty sad. If there's this little attention to detail to what you see on the outside, how much attention did they spend under the covers? It's one thing for the marketing guys to make a mistake on the website but when the techs who design and build the interface don't even know it's called "Blu-ray" how can anyone take this product seriously?
Kal
kal is offline
post #783 of 1049 Old 07-26-2009, 01:40 PM
Kal Rubinson's Avatar
Quoted: 761 Post(s)
Liked: 526
Sure. OTOH, I shopped around a lot when buying a kitchen range to find an acceptable one that spelled the word "Light" for ignition instead of "Lite" but, in the end, settled for one that suited my needs despite the misspelling. It works just fine that way.
The other Kal
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #784 of 1049 Old 07-26-2009, 02:19 PM
Nascar_984's Avatar
Where they say:
Kal
I agree and I also question why they would have a PEQ option with the trinnov? It also states it has a DSP and analog bass crossover.
Nascar_984 is offline
post #785 of 1049 Old 07-26-2009, 09:15 PM
The other Kal
Kal,
It would be nice if you could get hold of one of these ADA Mach IV units for a review.
post #786 of 1049 Old 07-26-2009, 11:26 PM
sdurani's Avatar
Quoted: 4973 Post(s)
Liked: 3436
Because no automated room correction system is perfect and/or adjustable to the user's tastes. PEQ offers an alternative, which can yield preferable results if the user has the tools, patience and inclination to EQ manually. Wish more pre-pros had options like this.
Sanjay
sdurani is online now
post #787 of 1049 Old 07-27-2009, 09:56 AM
AngelEyes's Avatar
I wouldn't read a lot into the images on that website, they look CG rather than actual product photos. Not saying the spelling mistake isn't in the production models but it might not be.
However it seems to be a common issue!
Adam
AngelEyes is offline
post #788 of 1049 Old 07-27-2009, 04:21 PM
Nascar_984's Avatar
PEQ does not offer near the performance that audyssey or trinnov offer and a lot of people would disagree with you.
post #789 of 1049 Old 07-28-2009, 06:35 AM
sdurani's Avatar
Liked: 3436
PEQ does not offer near the performance that audyssey or trinnov offer....
What's the difference in performance?
Sanjay
post #790 of 1049 Old 07-28-2009, 07:41 AM
Quoted: 761 Post(s)
Liked: 526
In practice, Audyssey and, I assume, Trinnov are automatic and not tweakable. A PEQ is and, of course, one can make it sound really crappy in the attempt to suit one's taste. OTOH, it would be nice to have the PEQ for "house curve" implementation superimposed on the room correction from Audyssey or Trinnov.
Kal Rubinson
post #791 of 1049 Old 07-28-2009, 11:38 AM
Nascar_984's Avatar
Plus PEQ is only good for on possition, I see it as usual in most audio applications where companies/people are afraid of new technology.
post #792 of 1049 Old 07-28-2009, 05:30 PM
sdurani's Avatar
Liked: 3436
Too few samples and careless mic placement, and one can get really crappy sound from the auto-EQ systems as well. I don't feel that the ability to make things worse is a valid reason for not offer an option.
Sure, or even for doing some nominal correction, like knocking out a single pesky resonance. Even with the latest auto-EQ systems, it doesn't hurt to have a manual EQ option, like the kind in the ADA unit.
Sanjay
post #793 of 1049 Old 07-28-2009, 06:21 PM
Quoted: 761 Post(s)
Liked: 526
Agreed. I was pointing out the ups and the downs.
Kal Rubinson
post #794 of 1049 Old 07-28-2009, 07:19 PM
sdurani's Avatar
Liked: 3436
Really? So if someone were to find a room resonance using measuring software (like the free Room EQ Wizard) and minimize it using a PEQ (like the kind in your fave Classe processor), you're saying it would only be good for one position. But if Audyssey found the same resonance and minimized it, you're saying it would be good for other positions as well? Why?
BTW, after Audyssey processes the measurement information, what does it use to change the sound?
Sanjay
post #795 of 1049 Old 07-28-2009, 09:28 PM
Nascar_984's Avatar
Audyssey depending on the version can measure far more then one listening position, what is so hard to understand about that?
post #796 of 1049 Old 07-28-2009, 11:56 PM
sdurani's Avatar
Liked: 3436
The same can be done with measuring software and a mic moved around the room, in order to find problems that are common to multiple listening positions. How would treating those problems with a PEQ then be limited to only one listening position?
BTW, you still haven't answered my question, so I'll ask again: after Audyssey processes the measurement information, what does it use to change the sound?
Sanjay
post #797 of 1049 Old 07-29-2009, 06:06 PM
Kevin C Brown's Avatar
Quoted: 12 Post(s)
Liked: 27
Audyssey and others like them can use time domain correction in addition to freq EQ'ing. With Parametric EQ, no time domain adjustment is possible.
I agree though that using PEQ *in addition* to some other automated room EQ has a benefit. But do any current SSP's even give you that option? I thought most if not all of them were automated room EQ *or* manual PEQ?
If it's not worth waiting until the last minute to do, then it's not worth doing.
KevinVision 7.1 ... Something old and something new :-)
Kevin C Brown is offline
post #798 of 1049 Old 07-29-2009, 07:23 PM
Nascar_984's Avatar
I am sure if lexicon offered trinnov or audyssey you would be singing a different tune.
post #799 of 1049 Old 07-29-2009, 07:27 PM
sfogg's Avatar
"With Parametric EQ, no time domain adjustment is possible."
If the problem is minimum phase (which room resonances are) correcting with PEQ does in fact correct time domain as well.
Shawn
sfogg is offline
post #800 of 1049 Old 07-30-2009, 01:46 AM
AngelEyes's Avatar
Pre/Pros like the Onkyo 886 that offer the facility to use the Audyssey Pro kit do offer some manual adjustment, I have not used it so am not sure exactly how much freedom you have.
Adam
post #801 of 1049 Old 07-30-2009, 06:28 AM
sdurani's Avatar
Liked: 3436
Nope.
Why are you evading my question? I'll ask for the third time: after Audyssey processes the measurement information, what does it use to change the sound?
Sanjay
post #802 of 1049 Old 07-30-2009, 06:45 AM
AngelEyes's Avatar
It changes the level of the input signal, applies FIR Filters and I believe it also performs phase and delay corrections and of course they use their own algorithms for weighting how these corrections are applied to the measured area.
Most other manual PEQ devices use IIR filters if I am not mistaken, although I think Trinnov has both available. I think it is a debate in itself as to the merits of each.
This is just my understanding, I am by no means an expert on Audyssey
Adam
post #803 of 1049 Old 07-30-2009, 01:09 PM
sdurani's Avatar
Liked: 3436
Agreed. The PEQ on the ADA unit may not have the FIR filters of Audyssey, but it does have resolution down to 1Hz and adjustable Q. This allows the user to EQ a very narrow range with minimal effect on nearby frequencies. As Shawn mentioned, room resonances are minimum phase, so a PEQ can not only correct in the time domain but it can do so at more than one listening postion, irrespective of what Doug ...er, Nascar may believe.
Sanjay
post #804 of 1049 Old 07-30-2009, 05:33 PM
Nascar_984's Avatar
Nope.
Nope.
I am sure, well AngelEyes had a good reply but what in specific do you mean by "changing" the sound? You can email chris at audyssey and he will get back to you rather quick.
post #805 of 1049 Old 07-30-2009, 11:34 PM
sdurani's Avatar
Liked: 3436
...what in specific do you mean by "changing" the sound?
Modifying the input signal (in Audyssey's case, to compensate for what the room is adding). My point was that you had no idea what type of EQ Audyssey was using modify the signal (evidenced by you evading the question) vs how a PEQ works, hence your erroneous claim that PEQ is only good for one position.
Sanjay
post #806 of 1049 Old 07-31-2009, 01:29 AM
AngelEyes's Avatar
Personally I would tend to agree that PEQ is generally only useful in a single position or small area. Not because it is impossible to average out a 'better' reponse over an area using PEQ (after all this is part of what Audyssey is doing) but most PEQ applications give a very small number of filters to achieve this, typically 12 per channel.
Vanilla Audyssey MultEQ has the luxury of 256 for the subwoofer alone (IIRC) depending on the implementation. Given the expertise, time, willingness and enough filters, perhaps manual PEQ could do a comparable job but I wouldn't want to do it
I might make the effort over a 3 seater sofa but anything more than that is time I don't have
Adam
post #807 of 1049 Old 07-31-2009, 06:39 AM
sdurani's Avatar
Liked: 3436
Sure, which is why I mentioned earlier that it's for users that have the tools, patience and inclination to EQ manually. Even if you do find problems that are common to multiple seating locations, it will take lots of trial and error to address them. Personally, I'll take the convenience of a good auto-EQ system. To that end, my posting history shows that I've been a big proponent of Audyssey from the very begining. But that doesn't mean I attach magical properties to it that somehow can't be accomplished by other means.
Sanjay
post #808 of 1049 Old 08-18-2009, 01:14 AM
AngelEyes's Avatar
New Onkyo PR-SC5507 Processor:
http://www.eu.onkyo.com/press/press_...n_8599753.html
http://www.aventhusiast.co.uk/new-on...3.htm#more-893
More money, more crap you don't need, yay
Adam
post #809 of 1049 Old 08-18-2009, 08:30 AM
Quoted: 761 Post(s)
Liked: 526
This is a changing situation. First, there are measurement tools that will average multiple measurement positions. Second, DSP-implemented PEQs can have as many filters as (or more than) Audyssey. Take a look at what JBL-Pro is doing this field and expect a trickle-down to consumer products. Thus, one can duplicate (to a great extent) with a PEQ what Audyssey does. However, it requires complex tools, lots of time and, critically, lots of knowledge.
I have to agree. Some others have a need to use a "hand's on approach" but I ain't that neurotic.
Kal Rubinson
post #810 of 1049 Old 08-18-2009, 09:28 AM
Krobar's Avatar
Adam
Integraresearch.com is now "Under Construction"....... A return for CEDIA? (Complete Speculation on my part)
Krobar is offline
