Can I connect two amps to the same speaker? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 11-20-2007, 09:50 AM - Thread Starter
kirkwilson's Avatar
I have a Yamaha RX-V659 surround receiver and a Yamaha M-85 power amp that I use for 2-channel listening. I would like to use my Def Tech BP-20s for my fronts in surround and as my mains in 2-channel. Can I connect both amps to the same terminals on the speakers? I would set each amp's speaker select to 'none' and turn it off when using the other amp. I have a pair of Def Tech BP-2s that I use for my surround 'presence' speakers and I'd like to be able to connect them to the M-85 'B' output so I can have both sets of speakers going in 2-channel.
kirkwilson is offline
post #2 of 15 Old 11-20-2007, 09:54 AM
Splicer010's Avatar
Liked: 39
Do so at your own risk...It is NOT advisable to connect 2 amps to 1 speaker...
Splicer010 is offline
post #3 of 15 Old 11-20-2007, 10:03 AM
kulims's Avatar
Why not.
kulims is offline
post #4 of 15 Old 11-20-2007, 10:10 AM
Splicer010's Avatar
Liked: 39
For obvious reasons...
post #5 of 15 Old 11-20-2007, 10:51 AM
zero-R's Avatar
You stand the risk of running current driven by one amp into the output side of the other amp, something that isn't intended by any stretch of the imagination...
Got $$?
zero-R is offline
post #6 of 15 Old 11-20-2007, 11:06 AM
usp1's Avatar
DOes your receiver have pre-outs? If so, you could use the preouts for the front LR from your receiver and plug them into your power amp and then use the power amp to drive your fronts for both HT and music. You would of course have to route your 2ch music through the receiver in that case.
usp1 is offline
post #7 of 15 Old 11-20-2007, 11:08 AM
webdevsam's Avatar
Its like crossing the streams, you just don't do it. It would be bad. Try to imagine all life as you know it stopping instantaneously and every molecule in your body exploding at the speed of light. Total protonic reversal.
webdevsam is offline
post #8 of 15 Old 11-20-2007, 11:53 AM
Calcvictim's Avatar
don't try to reinvent the wheel, use google
http://www.hometech.com/audio/spswitch.html
Calcvictim is offline
post #9 of 15 Old 11-20-2007, 12:04 PM
eklinger's Avatar
Don't even try it. Just run pre-outs for the front left/right to the amp and use it for both surround sound and 2 ch. I don't understand why you would want to use the receivers amp for surround sound and the external amp for 2 ch. music.
eklinger is offline
post #10 of 15 Old 11-20-2007, 02:43 PM
jhe
jhe's Avatar
You can do it. But you must get a dual voice coil speaker. Not even sure if those are still made. I've seen them only on woofers.
jhe is offline
post #11 of 15 Old 11-20-2007, 09:42 PM - Thread Starter
kirkwilson's Avatar
I am not sure and I'm not an engineer but I think there's something called 'reverse breakdown voltage' rating for power transisters. Until the voltage reaches a certain level there is no reverse current so it doesn't damage anything. Anyway I saw the error of my ways and it certainly makes more sense to switch the low-voltage inputs instead of connecting the high current outputs. Thanks for the response- I'd hate to think I caused any 'total protonic reversal' that led to the end of the audio paradisical universe we are now experiencing!
post #12 of 15 Old 06-30-2010, 07:31 PM
spivonious's Avatar
Major thread necromancy here, but this question recently came up and I wasn't sure what to say.
Surround sound AVR and a very nice tube setup (separate pre and power amps). He wants to use the same front L/R speakers with both amps without switching the speaker wire each time.
Would a simple a/b switch work? This way it would be impossible for them both to be connected at the same time, and therefore avoid any backflow on the amplifiers.
spivonious is offline
post #13 of 15 Old 06-30-2010, 07:36 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
Yes.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #14 of 15 Old 06-30-2010, 07:40 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
An A/B switch will work but get the "break-before-make" variety if you can to keep from momentarily shorting the amps (most speaker switches are already designed that way). Also, not all amps are stable into an open load, and tube output transformers in particular may get warm. A double-pole, double-throw relay or switch would be best, with a load (can be fairly light, like 16 or 32 ohms) to keep the "off" amp happy. That said, tube amp outputs are generally more forgiving of brief shorts and the like due to their transformer isolation.
Edit: Kal gave the short version of my answer.
As for why not connect the wires together, the amps are not always in phase, and many amps have floating outputs that really don't want to see anything except a load across their own two terminals and nothing else. That means that, despite appearances, the amps are not always (or even at all, if the phase on one is reversed from the other) going to be working together in parallel. There are also load-sharing effects, stability issues, etc. Think about taking a power cord from the wall, putting a plug on the other end, then plugging it back in, backwards. Or, jump-starting a car with the positive and negative cables backwards on one vehicle. Don't try this at home, folks...
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #15 of 15 Old 07-01-2010, 07:09 PM
Arnold_Layne's Avatar
Niles Audio makes a the switch you need.
http://www.nilesaudio.com/product.ph...ecordID=Source Switching Systems&categoryID=Switching Systems&catcdID=10&prdcdID=FG00003
Arnold_Layne is offline
