the "official Denon AVR-2308ci / AVR-888 owners thread - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #811 of 838 Old 03-10-2013, 12:46 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 7337 Post(s)
Liked: 3376
The OPT (out) only works with whatever is connected to the OPT (in). There is no HDMI ---> digital/analog down conversion.
"JD" - Call 585-645-1006 or email jd@avscience.com for AVR selection and pricing discussion 8am - 8pm EST daily (incl Sat/Sun)
Authorized dealer: Denon, Marantz, Yamaha, Onkyo, Sony, Def Tech, Atl Tech, SVS, Oppo
Think you have a defective AVR? Owner's manual - Factory reset 4-5 times in a row.
jdsmoothie is offline
post #812 of 838 Old 03-10-2013, 04:54 PM
jeffrocc's Avatar
All the dig opt ins or just the dvr next to the opt out?
jeffrocc is offline
post #813 of 838 Old 03-11-2013, 06:40 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3376
The manual would lead you to believe only the matching OPT(IN); however, others have stated it works with any OPT or digital coax input as well.
post #814 of 838 Old 03-11-2013, 10:16 PM
jeffrocc's Avatar
Hey thanks for the info. Really appreciate it.
jeffrocc is offline
post #815 of 838 Old 03-22-2013, 07:30 AM
kmlersch's Avatar
I was trying the same thing with a set of gaming headphones and got the same results. It looks like the "TOSLINK" out is only for the dvr setup and I could only get audio out from my "TOSLINK" input.
kmlersch is offline
post #816 of 838 Old 09-16-2013, 07:34 PM
Sean Elmore's Avatar
Hey guys. I'm having a really annoying issue with my AVR-888
Im running sound into the receiver via HDMI from a PC.
Im using two QEF Q90's for the front speakers a Boston center channel and a JBL woofer connected to the preout.
I can't seem to get my woofer to work with my loudspeakers to play stereo music.
I can only get woofer to work when the output on the computer is set to stereo over hdmi.
And the reciever is set to Dolby , Neo 6 or Neural
None of these options are good for listening to music. The soundstage seems to move all over the place
I've tried changing speaker setting on the computer to Stereo/5.1/7.1 to no avail.
Sean Elmore is offline
post #817 of 838 Old 09-16-2013, 10:24 PM
batpig's Avatar
Quoted: 2845 Post(s)
Liked: 2741
You need to enable bass management by setting the fronts to "small". Stereo music doesn't have dedicated sub content so the sub will only make noise if you redirect it there.
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is online now
post #818 of 838 Old 10-18-2013, 05:14 AM
HDPioneer's Avatar
quick question guys, thanks for any help!
whats the difference between the 2308 and the 2308CI ?
mate selling a 2308 for £90... is that a decent price for such an old amp? or is the CI much better?
HDPioneer is offline
post #819 of 838 Old 10-18-2013, 09:42 AM
batpig's Avatar
Liked: 2741
Sounds like you aren't in the US? The "CI" suffix is only used for USA/NA units, so it's basically the same unit just with different branding. I believe another difference is that the non-NA version (EU and Asia) has preamp outs for external amplification.
It's a solid unit with basic Audyssey calibration and a couple of HDMI inputs. Obviously a bit dated in some ways but it really depends on your needs.
HDPioneer likes this.
Setup Guide and FAQ
post #820 of 838 Old 10-18-2013, 09:47 AM
HDPioneer's Avatar
My needs are having never had any 5.1 surround sound system, its finally time to go surround sound and I figured for a few hundred pounds I could get a decent used amp and speakers that would probably be more than good enough for my lame ears wink.gif
I dont need to feed HMDI because my 3D projector does not like being fed messed up signals. wink.gif I guess I just need optical and standard hook ups for my ps3, xbox and PC?
Cheers!
post #821 of 838 Old 12-01-2013, 06:12 AM
Dougy Giro's Avatar
Hi
Following on from the last post, I have an issue with receiving 3d Sound from a dual output Sony 790 Blu-ray Player. What should the manual set up be on the 2308 to receive 3D audio only signal as as soon as I switch from 2D to 3D on the bluray the sound goes off. The 3d picture is streamed directly to the projector.
Dougy Giro is offline
post #822 of 838 Old 12-01-2013, 06:17 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3376
This is a source issue. The Blu Ray player must be set to pass video from one HDMI and audio from the other.
post #823 of 838 Old 12-01-2013, 06:51 AM
Dougy Giro's Avatar
Cheers - I honestly thought that I had the HDMI separation set on the Sony so had never checked it all of the time I have fannied on with the Denon! Just changed it and it works great which is a relief as the 2308 has an awesome sound and didnt want to upgrade to an inferior 3D receiver (or change Blu-ray)
Time to watch Closer to the edge in 3D now
post #824 of 838 Old 12-05-2013, 09:26 AM
jeffrocc's Avatar
Hey just wanted to really thank all the cats out there that are so helpful and respond to the questions from us noobs about the gear. Especially the older stuff which is still in circulation and really usable but can be daunting without some guidance. I keep an eye on this particular thread cause I have an old avr 888 that still pumps out the juice quite nicely. Hats off to you all!!!!
jeffrocc is offline
post #825 of 838 Old 01-25-2014, 12:53 PM
tinng321's Avatar
I have a 2308ci and I want to use the v.aux input in the front but it's not under source. When I turn the knob to select the source it only giving me dvd, dvd ext., tuner and tv/cable. please help.
Thank you,
Tin
tinng321 is offline
post #826 of 838 Old 01-25-2014, 01:34 PM
JChin's Avatar
Quoted: 244 Post(s)
Liked: 175
Thank you,
Tin
Hi tinng321, it appears it may have been removed. Go into Menu -> Manual Setup -> Option Setup -> Source Delete and make sure it is not deleted.
JChin is offline
post #827 of 838 Old 01-25-2014, 05:27 PM
tinng321's Avatar
thank you. i was trying to figure it out the whole day.
tinng321 is offline
post #828 of 838 Old 02-18-2014, 11:00 AM
jwrezz's Avatar
I have a 2308ci with cable box (FiOS Motorola QIP 7216) and a Roku (was a 1st gen, just got a Roku3) hooked up via HDMI. The cable box works great (on either HDMI input) but the Roku and some times when I switch it out for my laptop, is always a very grainy picture. This is all outputted to an Optoma HD20 projector. I turned down the sharpness on the projector which helps a bit, but is not ideal for any other viewing. Any way, upon connecting the Roku3, I learned it has both 720 and 1080 output so I changed to 1080 and the pic went away completely. I had to connect it to another TV to view and reset to 720. When I brought it back there were crazy green and black lines and I was really confused. Turned off all devices one at a time. Projector was the culprit. It worked after resetting that. I wondered if that was my initial problem so I put the roku back to 1080 and turned every thing off and on. Still no pic so I reset it to 720 and it works. Still a very grainy/ noisy picture. Trying to get thru the OSD is impossible unless I pull out an old Composite input device, but maybe that is what I need to do to adjust the HDMI input for some reason? Any ideas?
BTW I tried resetting my 2308's microprocessor but I can't for the life of me get that reset procedure to work! Do I have to hold the buttons for a really long time or something? Pressing all simultaneously doesn't work. Pressing the speaker A/B buttons slightly ahead of the power button doesn't work (it won't turn on until I lift the speaker A/B buttons). I hold the power and press the speaker A/B buttons just after and hold for up to a minute or so until my fingers get sore and I've NEVER got the display to blink.
Thanks for any help y'all can offer!
John
jwrezz is offline
post #829 of 838 Old 04-02-2014, 09:51 AM
zdcatc12's Avatar
I have a 2308 that I have had for about five years, but have never used the HDMI inputs until now. My issue is when using an HDMI input, the video outputs fine, but the audio through the amp is just a bunch of hissing. If you turn the volume all of the way up, you can barely make out the dialogue behind the static. If the audio output is set to the TV, the audio is fine. Also, if I use the optical jack, the audio is also not working. If I use analog inputs, the audio works fine.
Another interesting thing was if I did test tones, each tone came out of all the speakers, instead of the specific one being tested.
 Both HDMI inputs were tested, one with a cable box and the other with a DVD and both did the same thing.
zdcatc12 is offline
post #830 of 838 Old 04-02-2014, 03:39 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3376
Refer to the section in your Owner's manual on "Resetting the microprocessor" (near the back) and see if that doesn't resolve the issue.
post #831 of 838 Old 06-06-2015, 07:44 AM
Liked: 0
Hi All,
I am doing my first surround system, I just purchased the 2308ci thinking that it was a 7.1 system. I know it has the 7 channels and all, but looking at the codecs it seems like most of them would not even use all the speakers.
I was hoping for 7.1 audio to have the full immersion experience with games, but also on movies and music of course. Did I make a mistake? It doesn't support the new HDMI AV TrueHD or DTS, though I know it has a different version for audio only sources.
Is this a 7.1 system or what? 6.1 would actually work alright too but I don't see how it goes back and forth unless it just pairs the rear two...
A lot of questions here, If you could at least help me out in any way you could I'd appreciate it. Thanks!
Eutility is offline
post #832 of 838 Old 06-06-2015, 09:13 AM
Liked: 0
Originally Posted by Eutility View Post
Hi All,
Phew, please excuse my ignorance, been researching all night and I finally have come to some kind of tenative conclusion. After hours and hours I found out that SPDIF won't support 7.1, BUT I did find the 7.1 preamp connectors which was way too confusing.
So I think it should work out knowing this. Not sure if the auto tuning will still be valid and how it will go but at least I'm on the right track. (ordering cables now). I'd still appreciate any insight if anyone is around who knows about using these older systems. I just went from despair to joy so hopefully this will work out. Thanks.
Eutility is offline
post #833 of 838 Old 06-06-2015, 10:52 AM
585-645-1006
jdsmoothie's Avatar
Liked: 3376
The 2308CI was released in 2007; however, cannot play the HD DD/DTS codecs which is possible on the next higher model 2808CI and all models since that year. When playing a 2CH or 5CH DD/DTS track, you can use Dolby Digital PLIIx - Cinema to expand the audio to 7.1 and use the surround back speakers.
post #834 of 838 Old 11-07-2015, 01:56 PM
Liked: 0
Hi, I have an AVR-2308, since it was brand new.
Now I'm trying to configure the optical output, in order to use it with my computer's sound card wich includes an optical input.
My goal is to transfer to digital my old vinyls, but I`m not sure if digital output is possible from an analog inpute.
Anyway, I first tryied to configure the Opt2 output from an digital source, without any results.
According to the manual it seems that no matter what audio source you select, the receiver's optical output will work anyway through Optical 2 out. On page 48 it saids "The source selected for main zone is output from the digital output connector (Optical 2). The source selected in the Rec Select mode is not associated with the output from the digital output connector (opt. 2)"
I tried several configurations (even selecting DVR as input configuring the Opt 2 in as the manual sugested), withut any results.
Also performed the Factory Reset....
any help?
thanks in advance....
goldenwigns is offline
post #835 of 838 Old 11-07-2015, 09:54 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3376
Optical IN ---> Optical OUT
post #836 of 838 Old 11-08-2015, 04:29 PM
FLorp's Avatar
I picked up a used AVR-2308ci from an estate sale because I've been happy with my AVR-888 and could use a second amp. However, I'm running into some problems that make me believe it may just be a broken unit:
1) No sound is output to the Surround or Speaker B connections. It's not the wires or speakers (they work fine when connected to the front outputs). Even with the built-in tone generator (from the Manual Setup menu), no sound from the surround or B speakers (and yes, "Speaker B" is on).
2) Any audio from a digital source is distorted. Analog sources sound fine, but digital 5.1 sources (HDMI from a PC and optical S/PDIF from a TV) sound clipped and noisy.
I've factory reset the box, and can't find anything else in the setup/menus that looks promising, but maybe I'm missing something obvious.
Much appreciation to anyone with suggestions to try!
-Scott
FLorp is offline
post #837 of 838 Old 11-08-2015, 04:42 PM
585-645-1006
jdsmoothie's Avatar
Liked: 3376
Give it at least 5-10 microprocessor resets. If still no joy, you likely got a dud.
post #838 of 838 Old 11-08-2015, 05:32 PM
FLorp's Avatar
Hey, thanks, that fixed the missing surround speakers issue! Still no go on Speaker B output or the digital source distortion, but I'll keep banging on those for a bit longer.
-Scott
FLorp is offline
Denon Avr 888 7 1 Channel 5 1 2 Channel Independent Zone Home Theater Receiver With Hdmi I O And Ser
