Sony STR-DG510 - Issues w/ Hook-up - AVS Forum | Home Theater Discussions And Reviews
post #1 of 27 Old 11-29-2007, 07:59 AM - Thread Starter
beerisgood's Avatar
My Setup:
60'' 1080i Sony LCD - One HDMI hookup.
A3 DVD player - One HDMI hookup, optical.
Directv HD Box - One HDMI Hookup, optical.
3 HDMI cables, 2 optical cables.
1) Does the Sony STR-DG510 NOT upscale?
2) Since I have an HD cable box and the A3, can I connect these 2 HDMI sources with 2 optical outputs for sound? Or will I have to buy an optical-coaxial converter? I'm afraid the 510 doesn't support 2 HDMI audio sources via optical audio at the same time? Is this true?
3) Can I plug the A3 into the 510's DVD hdmi slot and not lose anything? Will the cable box hdmi plug go into the 510's blu ray player/video 2 hdmi slot?
Basically, I want to run the cable box and the A3 into the 510 via two diff hdmi's and two different optical for audio. Then, the tv into 510 via hdmi.
beerisgood is offline
post #2 of 27 Old 11-29-2007, 08:29 AM - Thread Starter
beerisgood's Avatar
Here is the back:
post #3 of 27 Old 11-29-2007, 08:30 AM - Thread Starter
beerisgood's Avatar
Here is the back
post #4 of 27 Old 11-29-2007, 08:31 AM
JOHNnDENVER's Avatar
I don't think the 510 even trancodes. I know it doesn't have a scaler.
Are you saying you are out of optical inputs? I'm not grasping the issue here.
All the HDMI inputs can be used for any HDMI device.
Once again I didn't think the 510 will transcode. So one cable is not possible unless all your sources are HDMI.
JOHNnDENVER is offline
post #5 of 27 Old 11-29-2007, 08:40 AM - Thread Starter
beerisgood's Avatar
So, when I play a sd-dvd in the A3, and the A3 is hooked up via HDMI in the 510 avr, it won't upconvert it? The 1080i tv is plugged into the AVR as well.
My sources:
A3
HD Cable Box
HDMI 1080 TV
As far as the audio, my question is, can the 510 handle the cable box and the a3 optical audio at the same time? I want to be able to switch the inputs from the 510. So, when a hd dvd is done playing (at 640k audio via optical), and I want to watch hd tv, I just change the input from the receiver, and still get 640k optical audio from the cable box.
post #6 of 27 Old 11-29-2007, 08:50 AM
As long as you have enough available digital audio inputs of the optical type you can do what your asking. The cable box usually provides a much lower bit rate DD than 640k to be honest though.
Upconvert what? If your hooked up HDMI to the 510 and your A3 is set for 1080i, your display that is also hooked up via HDMI to the 510 will get the video that is being put out by the A3.
The A3 is doing the scaling here, not the AVR.
post #7 of 27 Old 11-29-2007, 08:51 AM
Pocket Aces's Avatar
Read the manual. You will have to assign each optical input to the matching HDMI input. Why do you need upconverting? If you are connecting HDMI to HDMI all you need is passthrough which is exactly what the 510 does. Seriously read the manual, all your answers are in there. We could answer your questions all day but it would only take about 30 mins of looking at the manual on your side.
Pocket Aces is offline
post #8 of 27 Old 11-29-2007, 08:58 AM - Thread Starter
beerisgood's Avatar
I don't have the manual with me, but I just wanted to confirm some of these things.
The thing that worries me right now is the optical audio and the two hdmi sources all functioning correctly.
post #9 of 27 Old 11-29-2007, 09:02 AM
http://esupport.sony.com/US/perl/mod...l?mdl=STRDG510
I think page 18 pretty much explains it.
post #10 of 27 Old 11-29-2007, 09:24 AM - Thread Starter
beerisgood's Avatar
It states:
Audio: (Optical) SAT IN and VIDEO2/BD IN.
Video: DVD IN and VIDEO 2/BD IN.
"OPT: Lights up when VIDEO2 and/or SAT input is selcted."
So, I put the cable box into the the video 2 hdmi slot (video), and the optical into VIDEO2? Or SAT?
"COAX: Lights up when DVD input is selected."
So, I plug the A3 into the hdmi video slot labeled 'DVD'. Then, for audio, what do I do because there's no DVD IN for optical audio. This is saying COAX when DVD input is selected. Since the HDMI is going into the dvd input for video, does this mean I can't run optical sound? I have to run COAX? Or can I mismatch and put the optical in SAT with the A3 in the DVD IN for the video (hdmi)?
post #11 of 27 Old 11-29-2007, 09:40 AM
Originally Posted by wsolosy View Post
It states:
It looks to me like you might be out of luck as it doesn't seem like the 510 allows you to remap the DVD HDMI to the 2nd Optical. Have you checked to make sure your cable box doesn't have coax? They do make optical to coax converters which may be your best option at this point.
post #12 of 27 Old 11-29-2007, 09:41 AM
I don't see an OSD here?
If so I do think your inputs are hard coded to each other. This is not the way most AVR' do it.
Do a seach, you can purchase Optical to Coax digital audio converters for $10 or so.
post #13 of 27 Old 11-29-2007, 09:46 AM - Thread Starter
beerisgood's Avatar
The cable box is the directv H20 - which has digital audio.
Do I plug the A3 into the BD hdmi video, and BD optical?
And for the H20 - have no idea.
post #14 of 27 Old 11-29-2007, 09:55 AM
That is fine, for the H20? If it does not offer digital coax audio putput? You will need an Optical to Coax digital audio converter.
post #15 of 27 Old 11-29-2007, 10:00 AM - Thread Starter
beerisgood's Avatar
I might as well return the 510, and get the 810.
post #16 of 27 Old 11-29-2007, 10:03 AM
Heck yeah. the 810 processes audio from HDMI.
post #17 of 27 Old 11-29-2007, 12:12 PM - Thread Starter
beerisgood's Avatar
So, with the 810, I will only need 3 HDMi cables for Audio and Video, right?
And the 810 is also true-hd?
post #18 of 27 Old 11-29-2007, 01:40 PM
It does not have the decoders, but takes TrueHD audio predecoded by the player and output as multi-ch-pcm to the AVR.
post #19 of 27 Old 11-29-2007, 01:41 PM
PS: With the DG810 and all hdmi sources, you would need no other interconnections.
post #20 of 27 Old 11-29-2007, 01:51 PM - Thread Starter
beerisgood's Avatar
Thank!
post #21 of 27 Old 12-06-2007, 09:07 AM
cobolisdead's Avatar
Quoted: 45 Post(s)
Ok, I am getting one of these as a Christmas Gift thanks to the Black Friday Special at Best Buy. My question is can I plug my HDMI cable into the receiver from my 1080p Upscaling DVD player and not need anything else for it?
Quis custodiet ipsos custodes?
cobolisdead is offline
post #22 of 27 Old 12-06-2007, 09:27 AM
Nope you will need an optical, coaxial or RCA connection from the DVD player to the receiver to get sound. For HDMI sound you will need to get the DG710 or higher.
post #23 of 27 Old 12-06-2007, 11:07 AM - Thread Starter
beerisgood's Avatar
I think only the 810 and 910 do hdmi audio though.
post #24 of 27 Old 12-06-2007, 11:11 AM
710 does HDMI audio. Go to this link and look at page 18 http://www.sonystyle.com/wcsstore/So...f/STRDG710.pdf
post #25 of 27 Old 12-06-2007, 12:45 PM
Quoted: 45 Post(s)
Well, that is discouraging, I guess I will have to see what outputs my DVD player has then. Thanks for the help!
post #26 of 27 Old 12-06-2007, 01:03 PM - Thread Starter
beerisgood's Avatar
Oh, ok I apologize. Only thing is, it only has 2 HDMi inputs, so be careful with that.
post #27 of 27 Old 12-06-2007, 05:38 PM
Airric's Avatar
Also remember, while the 710 does accept audio over HDMI, it will only process/play 2 channel PCM through HDMI. So even if you have an HD-DVD/Bluray player that can decode Hi-rez audio to PCM and send it out HDMI, the 710 can only play L&R info, regardless of how many channels of PCM are sent to it. This was a last second change by Sony right before this model was released.
Eric
Current Concepts
Home Automation Specialists
Airric is offline
