Is it important to use the same HDMI cable for your output as your inputs? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-03-2007, 10:00 AM - Thread Starter
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
Is matching the type of HDMI output cable to your input cables important? I have noticed a few dropouts, which I assume are HDMI handshaking issues, since I have switched over to the Onkyo 605. The video and audio will dropout for a few seconds and then return. Sometimes the picture will get all shaky right before it happens. I have Monster HDMI Ultra-High Speed cables going from my HD DVD and Blu-ray player to the 605's two inputs, and an older Monster HDMI cable (about 18 months old) as the output to my TV. Could the fact that the output HDMI cable is not as current as the input cables be causing these handshaking issues? Any help is appreciated.
cuzzin is offline
post #2 of 3 Old 12-03-2007, 08:08 PM - Thread Starter
cuzzin's Avatar
Quoted: 63 Post(s)
Liked: 68
bump
cuzzin is offline
post #3 of 3 Old 12-03-2007, 09:03 PM
Endymion's Avatar
You definitely do not need to match cables between your inputs and outputs. You only need to ensure that the cables are good. It is possible that the old cable has gone bad. Try substituting one of the newer cables from either your bluray or HDDVD players for the cable going to the TV and then play the system with a new cable on each side and see if that helps.
John
Endymion is offline
