Will I see a great benefit with certain Onkyo receivers paired with these speakers. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-05-2007, 12:21 PM - Thread Starter
lowenbotten's Avatar
Hello all,
First, I have the Ascend Accoustic 340SEs accross the front and 170SEs for surrounds (5.1 setup).
I'm looking at the Onkyo 605, 705, 805 receivers. I'm aware of the different features such as more HDMI inputs with the 705 & 805 and the 805 having the Burr-Brown DACs.
My main question is, will I see a dramatic benefit in sound choosing an 805 over a 605 or 705? Or a 705 over a 605?
While I do appreciate good sound, I wouldn't call myself an audiophile. Would I really notice a difference if I was using an 805 vs a 605 or 705?
lowenbotten is offline
post #2 of 7 Old 12-06-2007, 12:06 PM - Thread Starter
Bump. Looks like my post was buried and forgotten.
post #3 of 7 Old 12-06-2007, 12:19 PM
gunbunnysoulja's Avatar
You will probably be satisfied with the 605, but the 705 or 805 may be a better choice depending on how loud your listening levels are (I watch movies at reference level) and how big your room is.
gunbunnysoulja is offline
post #4 of 7 Old 12-06-2007, 12:22 PM
inca's Avatar
I watch movies on the Onkyo 605 at about 61-62 level. I don't know what it goes up to, but if I listen to it any more then that it gets annoying. Not that it sounds bad, it sounds just fine at higher levels, its just too loud and it wears me out quick.
inca is offline
post #5 of 7 Old 12-06-2007, 12:30 PM
Filthy McNasty's Avatar
The 340SEs + 170SE speakers will be the SQ limiting factor with any of the AVRs that you mentioned.
Filthy McNasty is offline
post #6 of 7 Old 12-06-2007, 12:30 PM
Jakeman02's Avatar
If power and sound quality are your only basis for comparison I'd remove the 705, it's going to be more of a sideways move from the 605 in that regard, it's biggest features are the added preouts and extra HDMI input.
I think you'd notice enough of a difference between the 605 and 805 to justify the price difference which is becoming less and less with sales lately. Especially if you listen at higher volumes, the weight difference between the two is a good indication of the difference in the amps and heatsinks. The 805 is a tank in comparison.
Jakeman02 is offline
post #7 of 7 Old 12-06-2007, 12:44 PM
inca's Avatar
From what you explained, I think that you would be more then satisfied with the 605, especially for the price. Onkyos make really good receivers, and from what I have heard from the 605 so far, it sounds REALLY good. Sounds even better then my Onkyo HTR-510 receiver that I have had for about 3-4 years, I can especially tell in the surrounds.
inca is offline
