Official NAD T175 Surround Processor - Page 159 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #4741 of 4768 Old 01-01-2014, 09:30 AM
aakelley's Avatar
OK, thanks. I did file a support ticket with NAD too so one way or the other I guess I'll get it. Happy new year!
aakelley is offline
post #4742 of 4768 Old 02-21-2014, 01:48 PM
deerplow's Avatar
I have the opportunity to buy a T175 or a T175HD for $300 more. Do you guys suggest I bite? I love the sound but all the pops and assorted HDMI issues have me worried. Does the AM200 card sound any different?
deerplow is offline
post #4743 of 4768 Old 02-23-2014, 12:34 PM
Willland's Avatar
I have owned my T175HD for about 2 years with no real issues at all. An occasional HDMI lock on hesitation when switching back to satellite from another source but no loud popping issues at all.
An NAD T175HD for $300.00 is a no brainer IMO.
Bill
pioneertop likes this.
Willland is offline
post #4744 of 4768 Old 02-24-2014, 07:01 AM
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
As willand said ...i to have had the T 175-HD ..for about two years with no major..trouble..and i reall love the sound quality of the NAD pre/pro
..not t0 mention the simple easy of use....willand i think he meant..that he can get the T175-HD for $300 more ..than the T 175...?
loves...home theather/music/football:)
pioneertop is offline
post #4745 of 4768 Old 02-24-2014, 03:26 PM
Willland's Avatar
Yeah, I realized that after I posted. I do think having Audyssey MultEQ XT with the AM200 module would be worth the extra $300.00.
Bill
Willland is offline
post #4746 of 4768 Old 03-19-2014, 01:05 PM
purplerain's Avatar
Quoted: 42 Post(s)
Liked: 27
Can a NAD T175 be used with my Denon 2313?
*ENTERTAINMENT PURPOSES ONLY - PIONEER KRP-500M*
(2) Monitor Audio RX6 towers - (1) Monitor Audio RX center - (2) Monitor Audio RX FX surrounds - (1) NAD T758 AVR - (1) Velodyne Optimum 8 Sub
purplerain is offline
post #4747 of 4768 Old 03-19-2014, 03:11 PM
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
..sorry mate...no the denon does not have the multi -ch inputs... for you to use a T 175 ..pre
post #4748 of 4768 Old 03-20-2014, 12:01 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
funny, I owned a T175, and really loved it's sound and it's simplicity. But also wanted all the network connectivity (streaming capability, InterNET, etc.,...), and all the other wonderful "Denon' stuff. So I ended-up with a Marantz AV8801 processor/Parasound A51 amp/Oppo BDP-105 to sort of cover both worlds- as my main system. I have a Denon AVR-2112CI/Oppo BDP-103 that I use in a separate set-up in another room, and love it.
WestCoastD is offline
post #4749 of 4768 Old 03-28-2014, 11:35 AM
deerplow's Avatar
I ended up with the 175HD, but with a VM120 card. The video scaling on the VM200 kept deciding to do its own thing at random, and I really didn't even want it. The VM120 is HDMI 1.4, so it includes ARC and CRC, which is much more useful to me. No more HMDMI issues so far.
In home audtioning the 175 and 175HD, I was never able to A/B them, but I'm fairly certain the AM200 card sounded slightly better to me than the AM100. And the added codec support (192/24 over optical for instance) was a bonus. I haven't even run Audyssey yet.
The 175HD sounds amazing,, and I am very happy with it. My only gripe is the internal switches, which occasionally cause a loud "pop" in the speakers. Its not as bad as the 175/AM100 I auditioned, but its there and its concerning.
deerplow is offline
post #4750 of 4768 Old 03-28-2014, 12:49 PM
Phil Tomaskovic's Avatar
Quoted: 35 Post(s)
Funny when I had my 775 with a VM150 card update, I never got CRC or ARC to work. But when they replaced with the 787 which theoretically has the same cards then everything worked.
I know the 787 has different firmware so noy sure what cause the 775 not to work.
When do you get the pops? Is it with any sources or mainly dvr/TiVo type inputs? I would have pops when the audio stream changed from 5.1 to stereo to 5.1 mainly after commercials which were in 2.0.
I had to go back a release on my 787 firmware which was causing problems with an old TiVo HD when doing commercial skips (I would lose audio or have delays).
Phil Tomaskovic
Phil Tomaskovic is offline
post #4751 of 4768 Old 03-28-2014, 03:13 PM
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
..well congrats.. hope you enjoy the unit as much as i do.. when it comes to the pops ..don't be to alarmed ..you get use't .. to it , i did ..lol..but i know what you mean..smile.gif
post #4752 of 4768 Old 07-08-2014, 07:42 PM
Randyman...'s Avatar
Quoted: 30 Post(s)
Old thread bump:
I have a T175HD with the AM200 and VM200 cards that recently began giving me issues. Running DSP v1.34. It is out of warranty.
The display will show “CHECK DSP BOARD” and not pass any digital audio for approx. 30-45 minutes until the unit gets up to normal operating temperature (rather warm) – then the error goes away and the unit begins passing digital audio again. “Analog Bypass” seems to work fine while in this error state. I also randomly hear pops - sounds like digital clocking (sync) issues.
Sometimes, the front display won’t show ANYTHING and won’t even pass HDMI video to the TV for 5 minutes, and then the display turns on, passes HDMI video, and then displays the “CHECK DSP BOARD” error for 30-45 minutes (until warm). Seems like more than just the AM200 card might be affected?
I’ll admit the issues only started when I removed the MDC cards to thoroughly blow the unit out (maybe a static discharge happened?) – so it is likely something I caused myself – but I have seen other reports of these T175 issues with a Google search (no associated resolution to be found ). The temperature aspect seems to be an odd symptom for a static discharge fault, no?
Any pointers? I tried multiple factory resets, I re-seated all cards again, and double checked all grounds – everything looks OK. I have also tried re-flashing the firmware after the unit warmed up (flash successful followed by factory reset), but same issues occur until the unit is warmed up. I also tried disconnecting EVERYTHING but AC power to eliminate external variables and have the same results.
On the recommendation of another AVS member, I already have a Denon AVR-X4000 on the way (mainly for the Audyssey X32, but also because it was only $850 as an open box w/full 3 yr warranty!).
A new AM200 DSP card for the T175HD is $600 – and I'm not even sure if that will resolve all of the issues. I figured $850 for an entire AVR with superior Audyssey and additional bells and whistles was likely a better prospect for my hard earned cash. I don’t even use my AVR for “Critical” 2Ch audio playback (mixing and mastering audio projects), so I’m sure the X4000 will be plenty sufficient for my HT needs regardless. But I'd LOVE to get the T175HD issues sorted if possible...
Anyone have a AM200 (or even an AM100) card they are looking to sell CHEAP?
Thanks for your time – and have a nice day!
Randyman... is offline
post #4753 of 4768 Old 07-16-2014, 08:41 PM
Quoted: 30 Post(s)
Bump. I received the Denon AVR-X4000 I mentioned above, and it looks like I'll be fine w/o my T175HD - but I would love to get the T175HD back in good working order to possibly sell it. Any input from my previous post? Or should I just write it off as a multi-thousand dollar loss? (caused by my own incompetence )
Grazie
post #4754 of 4768 Old 07-17-2014, 08:29 AM
pioneertop's Avatar
Quoted: 28 Post(s)
Liked: 176
Grazie
I have been checking around but no luck..I got my replacements boards from Nad, but you may have to pay the full price..that's the only downside to owning ,Nad gear...I have full contact info if you'll like
post #4755 of 4768 Old 07-17-2014, 10:19 PM
jdc115's Avatar
Grazie
I had to write mine off as multi-thousand dollar loss. Mine bricked while changing a HDMI input about 1 month after warranty. I took it for service and they couldn't resolve the issue but said they could order a new main board and was quoted something around $1300. Instead I just decided to put the money towards a Denon and left my bricked unit at the repair centre as it would have cost me $50 for the troubleshooting.
jdc115 is offline
post #4756 of 4768 Old 11-30-2014, 03:51 PM
Quoted: 30 Post(s)
Yep - So my costly T175HD sits back in the cardboard box. Not sure what to do with it - tossing it (recycling it) just seems wrong, but I'm not interested in spending more than $500 to get it fixed. I'm SURE there are salvageable parts. Anyone interested in it for $100 plus shipping?
PS - Still loving the AVR-X4000 that replaced the T175HD.
post #4757 of 4768 Old 11-30-2014, 08:01 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
what about NAD analog sound comparison to the AVR-X4000?
I owned the first release NAD T175, great sound for music. Clean sound for HT as well. But, obviously, limited in digital functionality (etherNET enabled, etc.,...)
post #4758 of 4768 Old 11-30-2014, 08:13 PM
Quoted: 30 Post(s)
Not a single complaint. I was somewhat concerned about a "Step Down" in SQ, but with today's modern DAC chips and a reasonably talented engineer designing the remainder of the circuit, it is kind of hard to make a bad sounding DAC IMO.
I really can't discern any difference between the two - and any "Critical Listening" (mixing) bypasses the AVR anyway. The X4000's feature set is pretty sweet to boot
Enjoy!
post #4759 of 4768 Old 12-01-2014, 12:43 PM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
you're probably right there
yeah, I've moved from the NAD T175 to a Marantz AV7005 processor. Then to a Marantz AV8801 processor, still setting things up.
Also use a Denon AVR2112CI receiver in another room, very well performing unit. While I have'nt operated much using pure analog audio it does sound sweet via-HDMI using sound modes (ie. "Multi-chan Stereo"). Pure 2ch analog, playing CD music using Oppo BDP95 player, sounds good but maybe sightly veiled
post #4760 of 4768 Old 01-28-2015, 08:57 AM
J-man's Avatar
NAD T175HD no OSD Menu
My NAD T175HD is having problems with the OSD Menu. The OSD will only display garbled static over HDMI and gibberish over RCA video. Regular video and audio over HDMI and analog is not affected.
NAD support was not any help, expect to say reset the unit (which I did, no change). Any thoughts on causes or likely fixes?
I'm moderately handy, and game to replace a card or do some minor soldering. At first I thought cold solder joints, but am starting to wonder if there is a separate card/chip for the OSD. My local NAD dealer is no help.
Thanks, Jon
ID:	507850   Click image for larger version
J-man is offline
post #4761 of 4768 Old 01-28-2015, 09:16 AM
Quoted: 30 Post(s)
No constructive help on a solution, but I will recommend you proceed VERY CAREFULLY if you plan on re-seating cards and such.
I removed a few of my cards to blow out the unit, and it began malfunctioning. It's basically useless at this point, and there's not much sense in spending tons of cash to get it fixed IMO (see my above posts). I'm not quite a novice myself, and have built dozens and dozens of PC's and other intricate DIY gear - so the T175 seems to be overly-sensitive to such actions from what I can tell. I know the T175 can be easily damaged if "hot plugging" HDMI connections, for example.
I don't really miss my T175HD (now sits in a box in the attic and the Denon X4000 proudly replaced it), but certainly miss the ~$2.5K I spent on it!
post #4762 of 4768 Old 01-28-2015, 10:16 AM
J-man's Avatar
Thanks for the warming! I don't want to try anything unless there are very clear instructions and a high chance of success! I have my Oppo 103D running direct to my amp, so at least I am functional while I figure this out. Depending on repair cost I may end up just buying something new.
J-man is offline
post #4763 of 4768 Old 01-28-2015, 11:44 AM
WestCoastD's Avatar
Quoted: 252 Post(s)
Liked: 96
hee hee
I really loved the analog sound from my Denon DVD-3930CI player going thru the T175, to my Parasound A51 amp, to my Monitor Audio Gold GS60 fronts. sweet! But my T175 is long gone
Randyman... likes this.
post #4764 of 4768 Old 01-19-2016, 10:09 AM
Timo11's Avatar
Quoted: 16 Post(s)
Originally Posted by WestCoastD View Post
hee hee
Sorry to revive an old thread!
How do/did you like the Marantz units compared to the NAD? I sold my T175 a few months back and am now waiting on delivery of a 7702mkii.
I really did like the sound of the NAD, it was sold purely for lack of 2nd HDMI output and partially for lack of HD audio decoding. (atmos/DTS-X another story completely...) And the upgrade path did not make sense dollar wise. They priced themselves out of that equation in my opinion. Very unfortunate.
That being said, I never did like what audyssey did on the NAD and never turned it on.
Timo11 is offline
post #4765 of 4768 Old 06-01-2016, 02:36 PM
karos's Avatar
trying to upgrade the firmware on my NAD T175. I found the firmware here:
http://nadelectronics.com/download.p...5-V144Video111
But it asks which MDC modules are installed.
Is there a way for me to determine what's in the preamp. I upgraded it a while ago but actually forgot what they put in.
karos is offline
post #4766 of 4768 Old 06-01-2016, 02:46 PM
bommai's Avatar
Quoted: 192 Post(s)
Liked: 48
It is supposed to auto detect. Does it? My T775HD correctly detects am200 and vm150.
bommai is offline
post #4767 of 4768 Old 11-10-2016, 08:02 PM
graycf's Avatar
Originally Posted by MrTaxMan View Post
Quote: Originally Posted by tb123
Is there something in the NAD setup that needs to be selected for it to accept these audio via PCM?
It would appear you are making it harder than it really is. There's several issues going on with your question. There's nothing you need to set up on the NAD other than making sure you are receiving digital audio via the correct HDMI input.
When the BD-60 is set to output Dolby TrueHD as PCM, the NAD should display "Direct". At that point you can only switch from Direct to Stereo Downmix and back to Direct. Since the NAD is not decoding Dolby, the Dolby light should not show up on the display and you should not be able to select any other other Dolby mode. So what you describe indicates you are not receiving PCM.
When the BD-60 is set to output Dolby TrueHD as Bitstream, the Dolby light on the NAD will light up and you can switch to other Dolby modes. Of course in this case you are only getting regular Dolby 5.1
The BD-60 will always display the same thing no matter if you choose Bitstream or PCM, so don't expect to see anything different there. When you view audio information on the BD-60, it is only telling you the format being played on the disc -- not what the player is decoding or what NAD is receiving.
Make sure the BD-60 is set to output PCM for both Dolby and DTS. Note: Turning Secondary Audio on or off only matters when you output Bitstream.
Also, set PCM Down Conversion to Off and Downmix to Surround Encoded.
With PCM, you should NOT see Dolby on the NAD display. If you do, then you're receiving Bitstream.
Going back years here, but I had some questions on your answer. I just purchased a NAD T758. Playing through my PS4 (HDMI, Linear PCM), I only have the Direct and Stereo Downmix options. It sounds like those are the only options I am supposed to have? When I play spotify via the PS4, it only plays stereo. How do I force it play out of my 5.1 system (e.g. use EARS, enhanced stereo, etc.)? Hoping for some help. Confused if I can't do this.
graycf is offline
post #4768 of 4768 Old 11-11-2016, 06:37 AM
bommai's Avatar
Quoted: 192 Post(s)
Liked: 48
I think I replied to this in the other nad thread hat you posted in. Check what kind of signal you are getting into the receiver. In mine, I can press the display button on the front panel once or twice and it will show what kind of signal I am getting. If you are getting a 5.1 or 7.1 signal (in my it says 3 2 .1 or 3 4 .1) then that is your problem. Also make sure you have not plugged anything into the headphone jack.
bommai is offline
Nad T 787 , Nad
