Best video processor in AV Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-28-2007, 12:29 PM - Thread Starter
davidiis's Avatar
Recommendations on what is the best AV Receiver for video upscaling? Do any of them upscale standard cable feed to 1080p LCD?
davidiis is offline
post #2 of 12 Old 12-28-2007, 12:46 PM
Jay_Davis's Avatar
Price range?
It matters.
Jay_Davis is offline
post #3 of 12 Old 12-28-2007, 01:02 PM - Thread Starter
davidiis's Avatar
Mid to high end approx $800+
davidiis is offline
post #4 of 12 Old 12-31-2007, 02:15 PM - Thread Starter
davidiis's Avatar
davidiis is offline
post #5 of 12 Old 01-01-2008, 08:02 AM
Filthy McNasty's Avatar
Your TV should have a better upscaler than any $800 AVR.
You need to get a HD cable box.
Filthy McNasty is offline
post #6 of 12 Old 01-01-2008, 09:19 AM
Ray Collins's Avatar
I have a new Panasonic 50PZ700u plasma and it is hooked to a Comcast box but the SD picture is poor. Will the video processor in the Onkyo 875 significantly improve the PQ? If not what will and at what price?
Ray
Ray Collins is offline
post #7 of 12 Old 01-01-2008, 09:24 AM
lcaillo's Avatar
Not likely.
Yes, calibration is important...every user should be calibrated.
Need electronics repair? A great place to start looking for a shop in your area: http://www.tvrepairpros.com/
lcaillo is offline
post #8 of 12 Old 01-01-2008, 09:33 AM
rudolpht's Avatar
I would call $800 as low-mid range, but the Realta does a good job in the Onkyo's slightly higher in the true mid range (now that firmware is fixed), but garbage in (bad SD signal) is garbage on the screen. See AVRs that support HDMI Audio Multichannel PCM (MPCM) and/or HBR Bitstream Decoders
Tim
Selling Anthem PVA7.
STABILITY + Superior audio (SC09-TX) + Incredible picture (VPL-VW200) + good integration.
rudolpht is offline
post #9 of 12 Old 01-01-2008, 10:07 AM
JVi
JVi's Avatar
Eyeballs are like ears...there is a limit to what they can sense and these limitations are well below the levels of detail produced by electronics.
JVi is offline
post #10 of 12 Old 01-01-2008, 11:43 AM
rudolpht,
I paid a visit to the link you identified and found the Denon5308ci; it is a little too expensive for me at $5200. There was no Onkyo listed as having the Realta chip. What gives...or did I misunderstand your message?
Basic question is will the Onkyo 875 improve the SD PQ from a cable box or Direct TV on my 50PZ700U? I am using an Oppo 981 for DVD's and the PQ is excellent; I would like to match this PQ for broadcast signals.
post #11 of 12 Old 01-02-2008, 02:17 PM
Jay_Davis's Avatar
The Onkyo 875 and 905 both have the Reon. I do notice that standard def is better through the Reon than when put directly into my Sony A2000 SXRD.
post #12 of 12 Old 01-02-2008, 04:01 PM
Thanks Jay
Ray
