Avr Faq - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #331 of 413 Old 03-28-2010, 07:07 PM
FuzzyZipperbaum's Avatar
Great Stuff... (Head is still spinning)...LOL...but great stuff.
FuzzyZipperbaum is offline
post #332 of 413 Old 04-04-2010, 05:41 PM - Thread Starter
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
I added a bit of info on 3D. Please correct me if you see anything wrong. Thanks.
"But this one goes up to 11"
MichaelJHuman is offline
post #333 of 413 Old 04-08-2010, 11:36 AM
aerogt3's Avatar
Wow, this was incredibly helpful. I was worried I needed some jiggawatt amplifier but after reading this I can see how just 50W/channel with my speakers will be plenty loud! Thanks!!!
aerogt3 is offline
post #334 of 413 Old 04-08-2010, 12:07 PM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
* Glasses which compatible with 3D titles (These glasses work off a signal and will alternatively pass light for one eye and not the other using LCD technology)
Glasses have to be of the active shutter type (not passive polarized or colored anaglyphic) and compatible with the display.
Greg Lee
GregLee is offline
post #335 of 413 Old 04-08-2010, 08:29 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Thanks, good info.
post #336 of 413 Old 04-15-2010, 05:17 PM
bigfoot15's Avatar
Found this excellent HDMI tutorial here :
http://www.hdmi.org/learningcenter/H...r_tng_1112.htm
My apologies if this link has been posted previously
bigfoot15 is offline
post #337 of 413 Old 04-15-2010, 06:04 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Come across as advertising!
post #338 of 413 Old 04-16-2010, 04:15 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Originally Posted by jordi25 View Post
Thanks Micheal for taking your time in writing this usefull info, it is the most complete and comprehensible info about avrs that i have seen!
And thanks for removing the article text which could have been confusing to people (especially after future edits!)
post #339 of 413 Old 04-23-2010, 06:01 PM
walkshaunt's Avatar
Hello, Encountered a problem with my AVR-1910. Cannot get output, via HDMI cable, to my HDTV. Can get components (DirectTV box and Blu-ray player) to work separately. Cannot get any on AVR-1910 setup screen menus to see if some function is disabled? Any suggestions.
walkshaunt is offline
post #340 of 413 Old 04-23-2010, 06:28 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
This thread is not the place to post questions (iunless they are about the FAQ.) Please post your question to a new thread. You will get much quicker answers, trust me
post #341 of 413 Old 04-28-2010, 06:43 AM
jdsmoothie's Avatar
Quoted: 15351 Post(s)
Liked: 7506
walkshaunt -
Rather than posting to a new thread ... there is already a Denon 1910/790 Owner's thread that you can post your question to as well as get additional information on your new 1910.
jdsmoothie is offline
post #342 of 413 Old 04-30-2010, 11:41 AM
MacAlert's Avatar
I have a question on power consumption. I am looking to replace an old Onkyo HTIB receiver and have decided on the Pioneer VSX-920 or the Onkyo TX-SR608. These receivers have a huge difference in power consumption.
Will the lower power consumption mean a cheaper electric bill? I don't need anything too powerful since this is in a bedroom.
MacAlert is offline
post #343 of 413 Old 04-30-2010, 10:17 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Probably best to post this to the forum, rather than to this thread. This is for questions on the FAQ.
post #344 of 413 Old 06-05-2010, 08:27 AM
WolfsBane's Avatar
Follow up question... I've noticed that a lot of the newer mid priced/features receivers do not have pre outs so that you can connect an outboard amp that way, (which makes no sense since they have the weaker power requirements). Are the pre outs a must to connect an external amplifier?
Welcome... to the house of Rock and Jazz !
WolfsBane is offline
post #345 of 413 Old 06-05-2010, 08:50 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Well, you can get a speaker level to line level converter box. But pre outs are more convenient. And converting speaker level to line level adds more stages to the signal path which could increase distortion. If crossover distortion from the class B amps is the worst offender, you only want it to occur once for example.
post #346 of 413 Old 06-05-2010, 09:02 AM
WolfsBane's Avatar
Thanks MichaelJ...
So the Pre Outs are really the better option. OK... There are options out there from Onkyo, Denon, Panny, and Yamaha, with at least 5 pre outs, (not including subwoofer), but they are almost all mid to higher priced models with the larger amps. Am still kind of hoping to find one with decent features that doesn't necessarily have a large amp section. Research... research... research....
post #347 of 413 Old 06-22-2010, 02:52 AM
bigc209's Avatar
sorry 4 a newbe question here but in the specs it says
192 kHz / 24-Bit DAC & 192 kHz / 24-Bit ADC
so I can assume this is a great thing 2 have in a AVR
bigc209 is offline
post #348 of 413 Old 06-22-2010, 09:18 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
192/24 is the defacto standard in modern receivers because HDMI allows for that limit. You probably would not want to buy a receiver without it. However, all receivers I have seen in recent history have 192/24 capability.
192 khz means the DACs can handle sample rates of 192,000 samples / second. You won't see that in common use. However, some players can upsample a CD or whatever to that rate. The merits of that high of a rate are highly debateable.
24 means the bit depth is 24 bits. All that means, is that it can handle audio samples with 24 bits. Again, this is allowed by HDMI, so you want it to (even though 20 bits is likely good enough.)
Marketers probably think it looks impressive, so they list it as a spec.
If anyone really wants a disertation on the subject of bit rates and bit depths, there's a paper called 'Coding high quality digital audio' which goes into a lot of technical detail.
post #349 of 413 Old 12-05-2010, 07:46 AM
Cal68's Avatar
Quoted: 232 Post(s)
Liked: 174
I am sorry if this question has been asked and answered before. Is there a disc, or a file that I can download, that contains a lossless soundtrack that can only be heard if my BluRay player is correctly decoding the lossless soundtrack and passing along the PCM to my pre-pro? I have a pre-pro that cannot decode DTS-MA or Dolby Digital HD, but will accept PCM from my BluRay player. I've set my BluRay player to decode the lossless soundtracks and pass along the decoded PCM to my pre-pro, but it would be nice to know that everything is happening as I hope it is. If there was a disc or file that would only play if my set-up was correct, it would be comforting to me!
Cal68
Cal68 is offline
post #350 of 413 Old 12-05-2010, 08:17 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
Doesn't your player have a status capability which shows the currently playing audio stream?
post #351 of 413 Old 12-05-2010, 09:32 AM
Cal68's Avatar
Quoted: 232 Post(s)
Liked: 174
My BluRay player does not tell me what audio stream it is sending to my pre-pro, so I have to assume that it is sending the PCM soundtrack because that is the setting I have selected. It would be good to get some type of confirmation that this is indeed the case. Hence the question from me. Thanks.
Cal68
Cal68
Cal68 is offline
post #352 of 413 Old 12-05-2010, 02:18 PM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
I thought it was standard to be able to see a status of what audio track was playing. Without that info, you can't know for sure. But if the player can decode all audio, and you select a given audio track, such as TrueHD, you are pretty much guaranteed lossless.
post #353 of 413 Old 12-06-2010, 03:46 AM
toby10's Avatar
Quoted: 36 Post(s)
How is your Blu-ray connected to your pre-pro? HDMI or analog?
I also find it very odd that your Blu-ray player cannot display the audio and video information on your TV while the movie is playing.
A $60 budget Blu-ray player has this feature.
toby10 is offline
post #354 of 413 Old 01-21-2011, 12:14 PM
coloradox's Avatar
Thanks for this FAQ!
coloradox is offline
post #355 of 413 Old 03-03-2011, 09:16 AM
Jeddi_Pimp's Avatar
very nice write up
Jeddi_Pimp is offline
post #356 of 413 Old 03-03-2011, 09:17 AM
Jeddi_Pimp's Avatar
Thank you
post #357 of 413 Old 05-23-2011, 09:22 AM
Spanbauer's Avatar
Output power is certainly of some importance. The problem is with AVR power ratings. Their output power is not measured consistently. For that reason, you may be trying to compare apples and oranges when trying to compare the output power of two different AVRs.
When looking at power output specs, consider the following factors –
• Rated impedance (e.g. 8 ohms)
• Rated bandwidth (e.g. 20hz – 20khz, or 1khz)
• Rated Total Harmonic Distortion (THD)
• Number of channels driven ( usually not specified )
Impedance is a measure of electrical resistance. Rated impedance is usually 8 ohms for AVRs. AVRs may also show a 6 ohm rating. Most AVRs are not rated for 4 ohms. If you choose to use 4 ohm speakers with an AVR not rated for 4 ohm speakers, you may run into problems. Excess current which results from lower impedance loads could damage a receiver which is why they have protection circuits. Some people have used 4 ohm speakers with AVRs not specifically rated for it. Whether or not you can get away with this depends on factors such as how loud you want your sound, what speakers you have and the receiver design. Prudence in operating a receiver that's not rated for 4 ohm speakers is dictated.
Note that a nominal impedance is listed for speakers. Their actual impedance will vary over frequency. And 8 ohm speaker might have an impedance of 20 ohms in one section of it's response curve and 4 ohms in another. Some people worry that these variations in impedance can make some speakers difficult for a receiver to drive. It's not clear (to me) how legitimate a concern this is though.
AVRs can be measured using different signals. You will typically see either a 1 khz signal used or a full bandwidth (20 hz to 20 khz) used in the receiver's specs. A 1 khz signal will result in a higher rated power than a full bandwidth signal, and manufacturers will use that to get a higher rated power.
I'm looking for an answer in regards to power, and while this does a good job of explaining the different rating methods, it doesn't explain which measurement actually translates to speaker max input power. Pioneer publishes all three types of measurement in their receiver specs; for my VSX-521-K, the three measurements are:
Power Output Per Channel(20Hz-20kHz,.08%THD@8ohm) 80
Power Output Per Channel (1kHz@8ohm) 110
Power Output Per Channel (1kHz@6ohm) 125
Ok, my front left and right speakers are (nominal impedance) 6 Ohms speakers, rated at 130 Watts max input power; so is my receiver powering them at 80, 100, 0r 125 Watts? Thanks everybody.
Click here for my home theater setup
Spanbauer is offline
post #358 of 413 Old 05-28-2011, 03:13 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
You are oversimplifying it, I think.
With a 1 khz signal, you get 125 watts, with one or two channels driven (into 6 ohms.) But that number is pointless, because you don't know what the distortion was present at that output level. Probably like 1% THD, the threshold of audible distortion. With a movie playing, where all channels are playing at the same time, you don't know. It will be less, though.
Call it an 80 watt / channel receiver, because that power rating is measured full bandwidth into 8 ohms. Maybe a bit more because of the 6 ohm load. Then lower that for movies a bit, as it can't push that kind of power into all channels at the same time (while realizing it won't have to, but it's probably not a heavy weight among receivers.)
post #359 of 413 Old 05-31-2011, 06:38 AM
Spanbauer's Avatar
Thanks for the reply, MichaelJHuman. I figured I was probably oversimplifying things.
To be honest, I have no idea what any of that means. But it doesn't sound like I need to
Ok, so if it's an 80 watt receiver and my front speakers are rated at 130 watt maximum input power, are my speakers being underpowered by my receiver? I guess that's really what I'm curious about. How does one determine how expensive of a receiver they require to effectively power their speakers when all of these specifications are seemingly useless?
I'm a little confused by this; how can manufacturers list "power output per channel" if the receiver isn't capable of outputting that much power per channel simultaneously? It's not really per channel then, is it? Thanks again, Michael.
post #360 of 413 Old 05-31-2011, 08:25 AM - Thread Starter
Quoted: 266 Post(s)
Liked: 151
If it was bad to power 130 watt speakers with less than that amount of power, they would fail with no power running through them (think about it
What people mean, when they talk about underpowering speakers is one of two things. If you push the volume of your system too high, and clip the output, that causes a high average power level. You can damage speakers this way. It's less likely to damage speakers with an unclipped signal, as average power is lower. The other way to underpower, is not understood well by me. The theory is that some amps/receivers have enough power on paper to power some speakers to loud levels, but the results are unsatisfactory - perhaps because speakers are reactive, and the amp/receiver runs out of current...
The FTC (Federal Trade Commission,) created a law to dictate how power is specified. For receivers/amps with more than two channels, they have this verbage about 'all associated channels.' That verbage allows manufactures to choose what associated channels means...based on bench tests in reviews, they usually manage to meet rated power with two channels, but usually not with more (see some reviews with bench tests to see what I mean, 5-channel power may be a fair bit below rated power in some cases - 7-channel power may be pathetic for budget models, like 25 watts.)
