Official Classe SSP-800 thread. - Page 195 - AVS Forum | Home Theater Discussions And Reviews
 82Likes
post #5821 of 6571 Old 07-13-2014, 09:12 PM
Sharp1080's Avatar
Quoted: 749 Post(s)
Liked: 480
I actually like running two HDMI outs from my Oppo BDP-105. I have one to my projector for video and one to the SSP-800 for audio.
Sharp1080 is online now
post #5822 of 6571 Old 07-14-2014, 05:32 PM
xbrmate's Avatar
I also run two HDMI cables out of my BDP-105, one to my SSP-800 for audio and one to my 65xbr900A for video. The only drawback is the loss of OSD for the OPPO.
xbrmate is offline
post #5823 of 6571 Old 07-18-2014, 05:12 PM
green giant's Avatar
Quoted: 78 Post(s)
Liked: 68
So I recently got a heck of a deal on a used ssp-800. I had thought about selling it, but man it sounds GREAT. Dynamic and accurate but just a bit of smoothness on the top end. Just getting to know it, but a pretty easy unit to set-up thus far.
My plans are to use a SVS AS-EQ1 to take care of my subwoofers. I typically don't like room EQ other than the subs anyways.
That said, I might be looking for a Delta series 3 or 5 channel amp if anyone out there is looking to sell theirs?
I have a butler audio 5150 I like a lot, and if I can find a 2250 I might use one to drive my mains and the 5150 to drive the centers and rears, but having heard this pre-amp, I'd really like to have a Classe driving my mains...
Drop me a PM if anyone is looking to sell. Thanks!
green giant is online now
post #5824 of 6571 Old 07-18-2014, 05:29 PM
Roger Dressler's Avatar
Quoted: 1545 Post(s)
Liked: 733
The PEQ in the SSP-800 not cutting it for your subs? I find it quite adequate for my 4 subs (driven in pairs).
I'm adding 4 height speakers for Atmos, so I need to swap out the CA-201 currently driving my mains for a multichannel amp. In case that's of interest.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #5825 of 6571 Old 07-18-2014, 05:40 PM
Quoted: 78 Post(s)
Liked: 68
I suppose I could run REW and use the parametric EQ to EQ the subs, but Audyseey XT does the job great and is easy...
post #5826 of 6571 Old 07-18-2014, 05:54 PM
adidino's Avatar
Quoted: 349 Post(s)
Liked: 277
Which processor you planning to use for Atmos?
adidino is offline
post #5827 of 6571 Old 07-18-2014, 06:47 PM
Liked: 733
First processor I can get. Probably the Marantz AV7702. The main 7.1 will use the SSP-800 7.1 bypass. Here's the room plan:
post #5828 of 6571 Old 07-18-2014, 06:57 PM
adidino's Avatar
Quoted: 349 Post(s)
Liked: 277
Nice one Roger.
Do you find monopole surrounds (side rear) should be mounted above ear level? Some feel the tweeter should be ear level like the mains. But different schools of thought on this subject (as usual).
adidino is offline
post #5829 of 6571 Old 07-18-2014, 07:22 PM
Liked: 733
Nice one Roger.
Yes, I believe firmly that surrounds should be elevated. In my case, they are all 20 deg (so the rears are 6" higher on the wall to account for the longer distance).
post #5830 of 6571 Old 07-19-2014, 04:42 AM
Quoted: 78 Post(s)
Liked: 68
I could use a little help with the subwoofer settings on my SSP-800.
I'm having a hard time getting it to let me run dual subs, with mono output with my mains crossed over.
It seems to allow me to run "double" bass (bass content going to mains and subs) in mono, or crossed over with the subs set up as Left and Right stereo. But for some reason when I try to set it up with dual subs mono and mains crossed over... it won't allow me to change the level on the subwoofer. Not sure if that makes sense.
It also seems when I have the subs on that all of my levels are a bit lower from a DB perspective (suppose I could check this with my DB meter today)
Any tips would be helpful.
post #5831 of 6571 Old 07-19-2014, 08:34 AM
Kal Rubinson's Avatar
Quoted: 719 Post(s)
Liked: 496
Unfortunately, it also inserts additional A/D/A conversions.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #5832 of 6571 Old 07-19-2014, 12:49 PM
Liked: 733
I use the "2 mono" mode and it works fine. Let's review the setup:
>system setup
>config
>pick config 1-6
>speakers
>aux channels
>subs
>2 mono
>back >back to the speaker setup page
>speaker config
>subwoofer
>sub enabled, and e-bass off
>home
When 2 subs are active, the bass level is dropped in each to compensate for the combination. If only one sub is operating, it may seem quieter. Are both subs playing? If you go to the room EQ page, scroll to the subwoofer, the select it. The test noise will come on for one of your subs. Now select Aux 2. The other sub should play the noise.
Does all this happen?
post #5833 of 6571 Old 07-26-2014, 02:48 AM
Alanoutaoz's Avatar
Resurrecting "lost" inputs
My installer deleted 14 unused inputs/channels from my SSP-800 with the thought that I wouldn't have to cycle through all 20 in order to switch inputs. Recently I've added an A&K 240 hi-rez player and a NAD C446 internet tuner which I have had to route through an Oppo BDP-105 player. Unfortunately the Oppo has some issues with 192kHz/24bit files and I need to feed it directly to the SSP-800. I've scoured this thread and the internet generally but have found no instruction as to how to restore a couple of the deleted or hidden inputs. The instruction book appears lacking/obtuse for my aging cerebral faculties, so short of calling tech support in Canada this appears the obvious pace to ask.
How does one bring the deleted inputs/channels back to life?
(without doing a complete reset which I believe would remove all my settings for the other inputs) My installer has moved away and is unavailable to do the job.
Any simple advice for this non-techie would be greatly appreciated
Alanoutaoz is offline
post #5834 of 6571 Old 07-26-2014, 05:19 AM
wildtangent's Avatar
Press the Menu key on the front panel then on the touch screen 'system setup'->'input'->'next input'
Keep pressing 'next input' until the you reach the input you would like to re-enable. Press 'in use' so that it is highlighted. press 'next input' to keep enabling inputs or configure the newly activated input for use or press 'home' to get out.
Remember to put the unit in standby (front panel standby switch) to save the new settings.
The current active input will have 'in use' grayed out, available inputs will be highlighted, deactivated inputs will not be highlighted.
wildtangent is offline
post #5835 of 6571 Old 07-29-2014, 01:07 PM
Alanoutaoz's Avatar
Thanks so very much toWildtangent for helping out with such a perplexing (for me) problem. The issue I have been confronted with has evaporated through his beneficence. I now look forward to inputting my A&K 240 and Oppo headphone amp directly into the appropriate inputs, hopefully without blowing my SSP up.
Cheers
post #5836 of 6571 Old 08-02-2014, 04:33 PM
wse
wse's Avatar
Quoted: 2189 Post(s)
Liked: 795
Cool how do you do that? "The main 7.1 will use the SSP-800 7.1 bypass."
wse is offline
post #5837 of 6571 Old 08-02-2014, 04:38 PM
Liked: 733
Just that I will leave the main 7.1 channels connected as they are. I can play the "music" system exactly as I do now.
Then, when it's Atmos party time, I turn on the AV7702, which triggers the extra amp driving 4 height speakers, and select "7.1 bypass" on the SSP-800 with master volume at 0 (unity gain).
Now I can run the whole Atmos show from the 7702.
post #5838 of 6571 Old 08-03-2014, 07:51 AM
wse
wse's Avatar
Liked: 795
Then, when it's Atmos party time, I turn on the AV7702, which triggers the extra amp driving 4 height speakers, and select "7.1 bypass" on the SSP-800 with master volume at 0 (unity gain). Now I can run the whole Atmos show from the 7702.
I see, I like that it sounds like a great idea.
So how do you connect this, I might look into it as well I want ATMOS but I doon't think Classe is going to release that anytime soon! Can you do 9.2.2 I like wide speakers
wse is offline
post #5839 of 6571 Old 08-03-2014, 09:22 AM
Liked: 733
For the dual subs I will use passive external A/B switching (DPDT) in the same box I already made that's the dual Y-splitter for the sub pairs.
You might need to do the same unless both subs are using the same output from the SSP.
You will treat the wides/tops same as I do the 4 heights. They stay quiet until Atmos mode (or whatever mode it is you use for wides).
post #5840 of 6571 Old 08-03-2014, 10:48 AM
riwi's Avatar
Quoted: 13 Post(s)
So you would connect the atmos source to the marantz using hdmi and then run the pre outs of the marantz to the 8 channel analog inputs of the ssp800. then via normal amps to the traditional speakers. The 7702 then feeds amps for the 4 ceiling speakers.
Interesting. I am very curious to read about the results.
riwi is offline
post #5841 of 6571 Old 08-03-2014, 01:55 PM
Liked: 733
It will be exactly the same as if the 7702 was the only processor in the chain. The SSP is just passing the analog signals straight through. It just makes it easier for me to keep using the SSP for my normal 7.1 music playback mode, which is the majority of the time.
post #5842 of 6571 Old 08-17-2014, 01:55 PM
wse
wse's Avatar
Liked: 795
How do you hook it up!
I assume your amps are hooked up to the SSP-800 and then how is the SSP-800 hooked up to the 7702? I might try that as well, sorry I don't get it! Drawing please, love the room improvements
wse is offline
post #5843 of 6571 Old 08-17-2014, 03:51 PM
Liked: 733
7702 has 7.1 main output channels
Feed those to the 7.1 inputs on the SSP-800. Select the 7.1 Bypass input. Set the SSP-800 MV to 0. (Remember to turn it down before selecting a different input!)
post #5844 of 6571 Old 08-17-2014, 04:25 PM
wse
wse's Avatar
Liked: 795
7702 has 7.1 main output channels Feed those to the 7.1 inputs on the SSP-800. Select the 7.1 Bypass input. Set the SSP-800 MV to 0. (Remember to turn it down before selecting a different input!)
So I need to unplug the Oppo BDP-105!
wse is offline
post #5845 of 6571 Old 08-24-2014, 07:54 PM
Arch 101's Avatar
Quoted: 12 Post(s)
OK, I give up. I have been installing and setting up my SSP 800 for the first time today and I can't get any audio or video to work at all. I'm almost positive I have everything hooked up correctly, which makes it even more puzzling. I have never set up separates before, but have set up surround sound receivers many times. If anyone out there has a few minutes to help me figure this out, I would be eternally grateful.
Arch 101 is offline
post #5846 of 6571 Old 08-24-2014, 08:59 PM
Liked: 733
Regardless of any inputs, it should be possible to use the internal noise generator to hear a tangible sign of life.
>menu
>system setup
>configuration
>make sure "in use" is highlighted to show it is active
>levels
>noise sequence, will play a noise signal starting in L.
Do you hear it? If so, we need to look at how you defined your inputs:
>system setup
>inputs
did you define audio and video input ports for each input?
post #5847 of 6571 Old 08-24-2014, 09:22 PM
Arch 101's Avatar
Quoted: 12 Post(s)
>menu
>system setup
>configuration
>levels
>system setup
>inputs
Roger:
Thanks for coming to my rescue. I did try the noise generator several times today and I did hear the noise in all 5 speakers. But I couldn't get the PS3 to display video on the TV or provide sound through the speakers either with a BluRay or a CD. I have the HDMI for the PS3 hooked up into the HDMI 2 input of the SSP 800 and the HDMI output going to my Sony 4K TV.
I finally tried playing a song from my iTunes library on my Apple TV, which is connected to the HDMI 1 input. Since I couldn't use the TV screen to navigate to a song, I tried the small onboard screen on the SSP 800 and I was able to select a song and play it through the speakers. It sounds great, however I'm sure I don't have it set up correctly yet for optimal audio.
So, at least the darn thing works. Which is great. Now I need to figure out how to get video to pass through the SSP 800 so I can watch a movie. I am also confused about "Configuration 1, 2, 3...." and a few other items as well. Maybe you can help me figure out how to get the video fired up.
Thanks again for your help.
Arch 101 is offline
post #5848 of 6571 Old 08-24-2014, 09:41 PM
Arch 101's Avatar
Quoted: 12 Post(s)
By the way, I did try to configure the input ports using the owners manual as a guide many many times today. The owners manual is not very clear on exactly what to do. I broke the inputs down into four different configurations and named them as follows:
1. Apple TV for movies with surround sound
2. iTunes to play my library in stereo
3. BluRay for movies using the PS3 with surround sound
4. CD to play CD's using the PS3 in stereo
I might need some guidance to make the correct selections or each input.
Thanks again!
Arch 101 is offline
post #5849 of 6571 Old 08-24-2014, 09:52 PM
Liked: 733
Make sure you have fully defined an input.
>system setup
>input (defaults to input 1. Build that for ATV, then start again and use "next input" to make one for PS3)
>video (scroll through list to select HDMI 1 when creating an input for AppleTV, and select HDMI2 for when building PS3.)
>back
>audio (scroll through list to select HDMI audio)
>back to configuration page, and select config 1. (It's a separate operation to define each config, but you only need one to describe the speakers connected).
post #5850 of 6571 Old 08-24-2014, 09:57 PM
Liked: 733
Thanks again!
You do not need to make new configs to do this. Just go to:
>system setup
>input
>fave processing. Here you can set the default to stereo, surround , etc.
Classe
