Do I need HDMI 1.3a with new equipment..help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-21-2008, 02:45 PM - Thread Starter
gkman1's Avatar
I've read a lot of the forums, but still can't find a straight answer...I just bought the Onkyo SR805 and will be using it with a PS3, Toshiba HDA2, Sony projector......wiill I or do I need the HDMI 1.3a cables for the best possible audio/video??
Mike
gkman1 is offline
post #2 of 6 Old 01-21-2008, 02:49 PM
kemiza's Avatar
Liked: 92
No but if you do...http://www.monoprice.com/products/su...02&cp_id=10243
Panasonic TC-P50ST60 plasma HD television, Onkyo TX-SR805 and PIONEER ELITE VSX-47TX receivers, Klipsch RB-75(2 pair) and RB-61 bookshelf speakers, Klipsch RSW-10, RSW-12(2), Velodyne HGS-12, HGS-18 subwoofers, OPPO BDP-103, PS3 80G, PIONEER DV-525 dvd player, Klipsch RS-42 surrounds, Klipsch RC-52 center channel
kemiza is offline
post #3 of 6 Old 01-21-2008, 03:02 PM - Thread Starter
gkman1's Avatar
Thanks...I've bought many cables from Monoprice....I just don't know enough about 1.3a...and is it that necessary.
gkman1 is offline
post #4 of 6 Old 01-21-2008, 03:04 PM
M Code's Avatar
Quoted: 728 Post(s)
Liked: 438
Mike
MIKE..
Really depends upon a number of things..
One the actual signal being transfered..
If high resolution video then better cables are suggested.
Additionally..
Cable length also plays a major part, lets say one has a 20' run from the AVR HDMI out to the HD video projector..
Do not get suckered into that you need to get the $250 HDMI cables.
But stick with known, proven brands rather than the bargain bin special..
Just my $0.02..
M Code is offline
post #5 of 6 Old 01-21-2008, 03:44 PM
kemiza's Avatar
Liked: 92
No
kemiza is offline
post #6 of 6 Old 01-21-2008, 04:30 PM
rynberg's Avatar
They don't really cost that much to worry about it, just get the 1.3 Cat 2 certified and be assured for a only a couple of dollars more.
rynberg is offline
