Bryston 9B amp w/ B&D Ref30 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-26-2001, 07:05 PM - Thread Starter
myjunk's Avatar
Welp, my dealer is still having a problem getting the 7250. Yes, I know he shouldn't, but I need to move on.
I've seen a lot of great comments on the Bryston 9B and I heard it audition with the Integra Research preamp, but never heard it with the B&K Ref30.
Does anyone have this setup or has anyone heard it? I'm splitting 50/50 between HT and music. The other equipment is B&W 804, HTM1, 805, high quality cables, biwire yada yada yada.
Any comments on this would be appreciated. Unfortunately, I will not be able to audition this exact set up.
Mike
myjunk is offline
post #2 of 2 Old 04-26-2001, 11:20 PM
lolittle's Avatar
I'd definitely go with the 9B if you own B&W Nautilus 800 series speakers. I use a 4B ST with my N804s & the combination is superb. They are both very neutral. Of course, the 20 year warranty & great customer support is icing on the cake.
Lynn
Lynn Olan Little
lolittle is offline
Closed Thread Receivers, Amps, and Processors
