Denon 788/1908 + PS3 2-channel PCM = no DPLII layer? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-17-2008, 11:36 AM - Thread Starter
mariachi's Avatar
I can't seem to be able to layer DPLII on 2 channel PCM sources coming from the PS3. Is this something that can't be done or am I missing something?
-Vic
mariachi is offline
post #2 of 6 Old 02-17-2008, 12:28 PM
kplex's Avatar
It's something that can't be done easily. The ps3 encapsulates 2 channel audio inside a 5.1 or 7.1 multichannel pcm signal. It's not much of a solution, but if you disable all the multichannel modes, you can force it to output 2 channel pcm.
kplex is offline
post #3 of 6 Old 02-17-2008, 08:29 PM - Thread Starter
mariachi's Avatar
Okay, i think I see what you are saying... the only reason I was asking is because the downloadable movie trailers are 2 channel only and when I was using the optical I could just use DPLII, but when using hdmi, all I'm getting now is sound from the two front channels. I guess I'll just have to put up with it.
mariachi is offline
post #4 of 6 Old 02-17-2008, 09:30 PM
eightninesuited's Avatar
Quoted: 132 Post(s)
Liked: 70
LOL.
Open the flip side of the remote, and choose your poison (Neo6, DPL2x) etc.. There's even a game mode.
Also check your HDMI audio settings in the PS3.
Proud Member of "Bass-a-holic Anonymous" - Dual Bottle of Choice: SVS PC-13 Ultra + SVS PC-12 NSD. Drink of Choice: Flight of the Phoenix Crash
7.2 SVS and Energy Reference system.
eightninesuited is offline
post #5 of 6 Old 02-18-2008, 05:52 AM - Thread Starter
mariachi's Avatar
Originally Posted by eightninesuited View Post
LOL.
Nope. that's the problem. Even when pressing those, the sound still only comes from the front L, R, speakers when there's a 2 channel PCM signal coming from the PS3. Basically, you can't apply any of the surround modes. When there's a multi channel PCM signal, I'm good as it's already 5.1 so I don't have to do anything.
-Vic
mariachi is offline
post #6 of 6 Old 02-18-2008, 05:58 AM
UHD Addict
aaronwt's Avatar
Quoted: 6415 Post(s)
Liked: 3963
The problem is with the PS3. It should output only 2 channels when playing 2 channel content. Instead it still sends out a 7.1 signal even when the content is only 2 channel. The 360 doesn't suffer from this problem.
And the PS3 should have never had this problem to begin with. Maybe one day Sony will fix it but I wouldn't hold my breath.
53TB unRAID2--41TB unRAID3--35TB unRAID1a
Sony 65x850C--Sony UBP-X800--Onkyo HT-S7800
XBL/PSN: WormholeXtreme
aaronwt is online now
