Denon 3808/4308/5308 Firmware Tracking Thread - Page 128 - AVS Forum
post #3811 of 3834 Old 06-29-2013, 08:43 PM
Purk's Avatar
Has anyone had to clean the relay contacts before and if so, could you please post how you did it?
Purk
Purk is offline
post #3812 of 3834 Old 01-01-2014, 10:48 PM
So Solid Jedi's Avatar
Hi, I'm not sure if i got my firmware problems sorted, can someone confirm these firmware settings look up to date please.
My current firmware for my European (non FPU) Denon 4308 Receiver are as follows:
Serial No. N/A
Main Ver. 02.04
Sub Ver. 01.11
DSP1 Ver. 36.61
DSP2 Ver. 39.49
*Ethernet IMG I200809050721
*Ethernet BL B200707020733
*Ethernet CNE C20080905
*Ethernet WEB W200809050808
*Ethernet MAC N/A
GUI FPGA CONFIG A080719A
GUI PRG 00007621
GUI DAT 37750020
DGTL FPGA 00.71
Video PLD 00.50
DAB Ver. 0300
Do these versions look correct and up to date?
Whenever i try to check firmware update it always says Latest.
So Solid Jedi is offline
post #3813 of 3834 Old 01-05-2014, 03:41 PM
valquentine's Avatar
After I upgraded my Denon 3808 just a couple of days ago it says that I have the latest firmware. But when I try to go to Add New Feature I can see that Registration = "Not Registered" and I can see Audyssey Dynamic EQ, Audyssey Dynamic Volume and HDMI Control. I just want to upgrade the HDMI control so that I can enable pass through. I have followed the instructions in this thread however most of the links provided are now broken (maybe because it was long ago 2008). Can anyone help me with this please? Btw, I'm in Australia.
valquentine is offline
post #3814 of 3834 Old 02-28-2014, 10:07 PM
lukescerri's Avatar
Did you have any luck with this? I'm in Australia, and I want to enable the audyssey eq stuff
Devout home-theaterist
lukescerri is offline
post #3815 of 3834 Old 04-16-2014, 02:46 PM
lukescerri's Avatar
Just an update on this. I contacted the local au distributor, qualifi, they sent out a form, I filled it in, and registered for the audessy update. Updated last night. All good!
post #3816 of 3834 Old 08-20-2014, 08:22 PM
Liked: 2
I am wondering if New Feature update is purely software update. I called to Denon and the person I was talking to told me that this update is not available anymore and required some hardware upgrade for avr 3808ci. I am not sure if that it is case. Can anyone confirm? Thank you in advance!
vladc77 is offline
post #3817 of 3834 Old 08-21-2014, 07:14 AM
davelr's Avatar
Quoted: 17 Post(s)
If you mean the upgrade that enabled Dyn Vol, Dyn Eq, CEC, etc., then no it didn't require any hardware update, at least not on my 3808. Not sure if they are still making it available, but I know a couple of people have said they've gotten it in the last 6 mo. or so.
davelr is online now
post #3818 of 3834 Old 08-21-2014, 09:28 AM
Liked: 2
I was referring to upgrade adding the following features:
Audyssey Dynamic EQ
CEC HDMI Protocol
Rhapsody
Sirius Radio
Thank you for your reply. I am wondering if you needed to bring the receiver to the Denon service to do this upgrade and if you had to pay for it. Maybe, the dealer did it but you weren't informed about all process which I doubt. I just wanted to verify.
The Denon's representative said about this upgrade that it is not possible to do on your own because it requires to install hardware and software. Now, I am thinking that he just did not want to deal with it. I am not sure what is the other way to get this upgrade if Denon is saying it is not available anymore. Any ideas?
vladc77 is offline
post #3819 of 3834 Old 08-21-2014, 11:11 AM
davelr's Avatar
Quoted: 17 Post(s)
Audyssey Dynamic EQ
CEC HDMI Protocol
Rhapsody
Sirius Radio
The upgrade did NOT require any hardware work, nor did it require taking the AVR to a dealer or service facility. It was done totally over the internet (wired connection only of course). At the time I bought it ($100, around 2008) you needed to provide the sn or mac layer address (can't remember which) and then the unit would validate to a server at Denon that would download the upgrade, all software.
I could only guess at the motivation of the Denon staff, but have heard of others being told the upgrade is not any longer available only to hear of others that were able to get it. I believe it is no longer being charged for.
I'd suggest going to the "Official Denon 3808" thread,
The "Official" Denon AVR-3808CI Thread
and searching the later pages to find references from people that appeared to get the upgrade recently.
post #3820 of 3834 Old 08-21-2014, 11:39 AM
Liked: 2
Thank you again. I'll do it.
Does this update is really worth to be installed? Do you feel you have a huge advantages for your day by day applications with having this upgrade?
vladc77 is offline
post #3821 of 3834 Old 08-21-2014, 01:32 PM
davelr's Avatar
Quoted: 17 Post(s)
Yes. I don't ever use CEC as my entire system is controlled by Harmony Remote programming. I rarely use Dyn Vol, but it can be useful in the evening. Dyn EQ does make a big difference for movie content but I do trim back the surrounds a couple of db and the center up a couple of db. I only have Audyssey MultiEQ XT.
post #3822 of 3834 Old 08-21-2014, 02:43 PM
Liked: 2
Thank you. It is good to know.
vladc77 is offline
post #3823 of 3834 Old 08-22-2014, 06:19 PM
Liked: 2
I finally was able to do this upgrade.
vladc77 is offline
post #3824 of 3834 Old 08-23-2014, 08:39 PM
ac3boy's Avatar
Would you mind listing the steps you took to get the upgrade? I just installed a chromecast and would love the CEC feature. Thanks.
ac3boy is offline
post #3825 of 3834 Old 08-23-2014, 08:56 PM
Liked: 2
I found that the best way is to communicate with customer support over the internet.
1. Create account with Denon Customer Support - http://denon.custhelp.com/
2. Go into the receivers menu and do the following to retrieve the Upgrade ID.
Manual Setup
Option Setup
Add New Feature
You will see the Upgrade ID appear on your TV.
3. Request politely for enabling access to the upgrade and provide the Upgrade ID.
4. They will enable you access
5. Go into the receivers menu and do the following to retrieve the Upgrade ID.
Manual Setup
Option Setup
Add New Feature
Initiate upgrade.
This is pretty much what you'll need to do. I hope it helps.
vladc77 is offline
post #3826 of 3834 Old 08-23-2014, 09:19 PM
ac3boy's Avatar
Thanks for the fast reply! I have my upgrade ID already so set there. Setting up account now. Thanks again.
ac3boy is offline
post #3827 of 3834 Old 08-23-2014, 09:53 PM
ac3boy's Avatar
I submitted a request. Thanks again. Hopefully it will be approved soon.
ac3boy is offline
post #3828 of 3834 Old 08-30-2014, 03:55 PM
ac3boy's Avatar
Just reporting back that Denon authorized my receiver. I never saw an email but decided to just check today. Upgrading right now.
Thanks to vladc77 for your assist.
ac3boy is offline
post #3829 of 3834 Old 09-02-2014, 12:34 AM
Liked: 2
You are welcome. I am glad I was able to help.
vladc77 is offline
post #3830 of 3834 Old 09-05-2014, 09:27 PM
zoro's Avatar
Quoted: 31 Post(s)
is this time to upgrade my 3808ci to x4100 or x5200?
my excellent stead 3808ci, what $can possibly bring me in so i can align my finances towards upgrade
zoro is offline
post #3831 of 3834 Old 09-06-2014, 08:52 AM
Liked: 2
I actually downgraded my receiver to AVR 3808 and added apple tv3 for airplay. Do you think x4100 or x5200 will bring you something new that you really will be using? The sound quality will not necessarily be better.
vladc77 is offline
post #3832 of 3834 Old 09-07-2014, 11:54 AM
zoro's Avatar
Quoted: 31 Post(s)
i dearly want to venture into atmos
zoro is offline
post #3833 of 3834 Old 09-07-2014, 03:07 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 1100 Post(s)
Liked: 1521
Upgrading to either the X4100W or X5200W would add the following:
(1) Audyssey XT32 offers much better audio quality then only XT on the 3808.
(2) Sub EQ HT adds dual sub control
(3) Dolby Surround upmixer which replaces DD PLII, DD PLIIx, and DD PLIIz
(4) Dolby Atmos
(5) HDMI audio to Zone 2
(6) HDMI inputs - 8
(7) HDMI outputs - 3 to include Zone 2
"JD" –
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
; shop.avscience.com ; 585-645-1006, AVScience - Authorized dealer for AVRs, Speakers, etc.
Mon - Fri: 10am – 10pm EST (Sat/Sun too if you leave message)
Call for pricing on Denon, Marantz, Yamaha, Def Tech, Atlantic Tech, Parasound
** Think the AVR is defective?  Reset the microprocessor 4-5 times.
jdsmoothie is online now
post #3834 of 3834 Old 09-09-2014, 03:43 PM
Liked: 2
(4) Dolby Atmos
(6) HDMI inputs - 8
I really hope it all will justify the price difference. I maybe uneducated well enough to not value all of these additions. I learned that if you play a little bit with EQ settings then it will make the sound you'll want. I did the software upgrade for 3808ci and did not find any significant improvements on a sound quality with these upgrades. I hope that additions that are offered with newer models are real step up. I'd like to find out if that really that better because I really interested in sound quality improvements only.
vladc77 is offline
Denon Avr 3808ci Receiver , Denon Avr 4308ci Receiver , Denon Avr 5308ci Receiver
Gear in this thread - 5308ci by PriceGrabber.com
