The Yamaha RX-V663 thread. HDMI 1.3 upconversion, TrueHD, DTS MA decoding. - Page 365 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #10921 of 11059 Old 01-27-2012, 04:03 PM
cavu's Avatar
Originally Posted by _Avarice_ View Post
Some of the house wiring is, indeed, quite old that the 15a outlet may not have been grounded at all.
Get a ground wire run from your AVR to the same location as the satellite! That will eliminate any issues.
"The greatest obstacle to discovery is not ignorance  it is the illusion of knowledge." - Daniel Boorstin
"Our lives begin to end the day we become silent about things that matter.
" - MLK
cavu is offline
post #10922 of 11059 Old 01-27-2012, 04:58 PM
_Avarice_'s Avatar
Liked: 24
Doing that is actually what introduced the "pop," as counterintuitive as that sounds. So the way I've left it the 14/2 wire that was used to ground the dish is still connected to the dish but disconnected from the common grounding rod.
Having done this, there is no more hum and no more pop......which is, well, odd.
Avarice
_Avarice_ is offline
post #10923 of 11059 Old 02-20-2012, 02:49 PM
theruckman's Avatar
I have the 663 of course...just replaced my 26" Polaroid TV in the MBR with a Haier 32"....my MBR is pretty close to my liv rm (location of the 663). I pop out of my Tivo, hit a cheap HDMI splitter, one goes to the 663, the other about 50ft 22AWG HDMI cable to the MBR TV. Here's the deal: the OLD Polaroid TV had NO ECHO prbs @ all! But this NEW Haier 32" has a slight echo (delay from liv rm). It is driving my wife (and I) nuts. I am really surprised this "newer" TV processes the HDMI a hair slower apparently. I am assuming I am screwed on this but wondering if there is any other setting on the 663 I could try to adjust? I just installed another (nicer) Yamaha for a client and there was a lip sync adjustment. On mine I tried messing with the "speaker distance" adjustment but it did not help. Totally bummed here. I realize Haier is super cheap, I just thought it would be better than a CHEAP polaroid from like 2003!
OH btw, I ran a 50ft component with RL audio, SAME ECHO??? So analog the Haier still processes the audio slower....unreal
any help thx
Scott
theruckman is offline
post #10924 of 11059 Old 02-20-2012, 03:54 PM
rdgrimes's Avatar
Quoted: 2343 Post(s)
Liked: 1673
Is the video and audio in synch on the new TV? Sounds like it may not be. 50' is a huge distance for HDMI signals, but it shouldn't cause any time lag. Assuming the BR TV is using it's own speakers, it's probably synching the audio with it's video, so look for video processing that would cause a lag. The most common is "motion adaptive" type stuff, 120Hz video processing and the like. But anything you do in the HT will throw the audio out of synch with the video there, so you need to focus on the BR TV.
rdgrimes is online now
post #10925 of 11059 Old 02-20-2012, 07:01 PM
theruckman's Avatar
yea, the menu GUI on the Haier is VERY limited...no adjustments for that...bummer...again, this is the SAME EXACT setup as I had before, just replaced the Polaroid TV with this newer one....really stupid...and yes the AV sync looks fine on both TV's, just one is getting to the other one faster...thx for the help...
post #10926 of 11059 Old 03-03-2012, 09:05 PM
ks_ks's Avatar
Hello,
I have "Trondheim Solistene Divertimenti" Bluray audio disc. It contains:
- DD 5.1 48kHz
- LPCM 2.0 192kHz
- LPCM 5.1 192kHz
- Dolby TrueHD 5.1 192kHz
- DTS-HD MA 5.1 192kHz
My Dune HD Max is hooked up with Yamaha RX-V663 amp via HDMI.
When I was playing this disc last time (about six months) ago, Yamaha was displaying "192 kHz" for all audio tracks. During these six months I've upgraded Dune AND Yamaha with the latest firmware: "120202_1544_beta" for Dune and "C051E 4.07r2" for Yamaha. Now, when I play DTS-HD MA track, Yamaha is displaying "96 kHz" (the rest is ok: "192 kHz"). Is upgraded Yamaha failed or Dune ? Could someone please check if any DTS-HD MA 5.1 192kHz audio is recognized by any DTS-HD MA capable amp correctly when played from media tank, PC or BD player via HDMI ? I need to know if I should downgrade Yamaha or not and if it's even possible to downgrade it. Thanks in advance. Cheers,
Krzychu
ks_ks is offline
post #10927 of 11059 Old 03-04-2012, 04:54 AM
rdgrimes's Avatar
Liked: 1673
96KHz is the max for most DTS decoders, I'm not sure about the 663. (Assuming you're bitstreaming from the player.) IF you have any additional decoders engaged, like PLIIx, you might also force the down-res. In any case, assuming you're getting DTS-MA and not the lossy DTS core, I wouldn't give it much thought.
post #10928 of 11059 Old 03-04-2012, 05:43 AM
ks_ks's Avatar
No additional settings. Just plain bitstream from the player. I'm 100% positive that RX-V663 is DTS-HD MA 192kHz capable. Please, anyone ?
ks_ks is offline
post #10929 of 11059 Old 03-04-2012, 04:07 PM
UndersAVS's Avatar
Quoted: 18 Post(s)
Liked: 35
I don't have a definitive answer, but assume you're checking the resolution using the Yamaha's "Signal Info" feature. Since this information is supposed to reveal the signal received by the Receiver for the selected input, it would seem that the problem is in the player. Regardless whether you change the Receiver settings to other surround formats, like DTS Neo or Pro Logic, "Signal Info" will still display the original source.
I've checked a couple of my CD's that claim to be remastered in 24/96 resolution with the Rx-v663 and a Blu-ray player set to output up to 192kHz through hdmi, and the Yamaha indicates they are standard CD 44.1 kHz. Who knows which is more accurate, the CD claims or the Receiver.
UndersAVS is offline
post #10930 of 11059 Old 03-09-2012, 06:29 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
Hi Guys,
I did a search in this thread but couldnt find what I was looking for.
I am thinking about buying a used 663, and have a question. If I have the cable running through the receiver via HDMI, will the signal pass through to the TV when the receiver is turned off?
Its a requirement from the girlfriend to be able to watch TV without the surround sound (for late at night).
kgallerie is offline
post #10931 of 11059 Old 03-09-2012, 09:33 AM
Plasmacat's Avatar
Quoted: 20 Post(s)
The answer is no - the 663 does not have pass through.
Work around -Hook up your TV source (cable?satellite?) to the 663 by optical and hook up your source directly to the TV by HDMI. Broadcast TV only has Dolby Digital, not advanced codes found on Blurays.
Never signs up for anything
Plasmacat is offline
post #10932 of 11059 Old 03-09-2012, 10:03 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
Thanks Plasmacat. The way you described is how I have the current receiver hooked up, so I will have to do the same with the 663.
Thanks again!
post #10933 of 11059 Old 03-12-2012, 06:19 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
So I picked up the 663 this weekend. The only problem I am having is that i can't figure out how to get the OSD to show on the TV.
I have the HDMI out from the receiver going to the HDMI2 input on the TV. When I switch the TV to the HDMI2 input and bring up the menu, it shows up on the front of the receiver, but the TV screen is black.
Any suggestions?
post #10934 of 11059 Old 03-12-2012, 06:33 AM
WhatHappend's Avatar
Any suggestions?
Does your TV support 480i over HDMI? That is needed for the OSD to show up. It is not a required HDMI resolution/scan rate.
What happens if you are passing your Bluray play through one of the 663 HDMI inputs to the TV via the 663 HDMI out? Does the Bluray players output route to the TV fine?
If so bluray video shows up, when you press the 663 menu button what happens? Does the screen go black or a solid color? If so, that seems to indicates your TV doesn't support 480i over HDMI.
WhatHappend is offline
post #10935 of 11059 Old 03-12-2012, 07:35 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
That is a great question. The TV is very new so it may not support 480i over HDMI. I will try the DVD player tonight to see if that works.
I will also hook up the video RCA connection from the receiver to the TV. That should work.
post #10936 of 11059 Old 03-12-2012, 09:04 AM
celmendo's Avatar
I don't have the manual with me but I seem to remember the onscreen menu only working through the s-video out (prob. the RCA too) Edit: That's correct. Use the monitor out connections which are only RCA and S-Video.
celmendo is offline
post #10937 of 11059 Old 03-12-2012, 10:15 AM
rdgrimes's Avatar
Liked: 1673
The 663 may be restricted to analog video for the OSD, which would include component outs. IF the 663 has conversion to HDMI available (I can't remember), then that would need to be turned on for the OSD to be seen on HDMI.
post #10938 of 11059 Old 03-12-2012, 10:20 AM
dbldare's Avatar
It does have up conversion built in. I'm at work now so I can't remember where the setting is in the menu, but I'll check later tonight.
dbl
Let's all go to the lobby
....Let's all go to the lobby
dbldare is offline
post #10939 of 11059 Old 03-12-2012, 10:46 AM
cavu's Avatar
You HAVE TO USE an analog output. No OSD on HDMI.
" - MLK
cavu is offline
post #10940 of 11059 Old 03-12-2012, 11:22 AM
djginwis's Avatar
I have an RX-V663 with HDMI only to my Philips TV, and I get the OSD just fine. And yes, I have all up conversions enabled.
djginwis is offline
post #10941 of 11059 Old 03-12-2012, 11:38 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
ok.....great. Thanks for all the help and advice! Sounds like the easiest way is to hook up the analog RCA cable. I already have one hanging out of the TV from the last receiver.......
i dont know why I didnt just connect it when I had the TV and stand pulled out yesterday
Hmmm.....the DVD player is pretty old, so I'll probably want the up conversion anyway....maybe I'll just turn on the up conversions and see if that works......
Thanks again!
post #10942 of 11059 Old 03-12-2012, 06:27 PM
Plasmacat's Avatar
Quoted: 20 Post(s)
This. On the remote be sure to press the amp button and then the menu button. The menu should show up
post #10943 of 11059 Old 03-12-2012, 06:35 PM
THAT IS WRONG.... The 663 has OSD menus over HDMI. I have been using it that way since it has been released.
Just like I stated earlier, your HDTV has to support 480i over HDMI for the OSD menus to show up over HDMI.
post #10944 of 11059 Old 03-13-2012, 05:04 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
I didnt have much time last night, so when I got home, I just connected the RCA analog out from the receiver to the TV and it worked.
Thanks again for all your help! The rest of the setup should be much easier now not having to do it on the front of the receiver
post #10945 of 11059 Old 03-16-2012, 08:57 AM
gloco's Avatar
OSD over HDMI works for me.
So I have two issues. I recently purchased a pair of Rega RS5's and have them plugged into front A. They sound great. My Rega RS-Vox is plugged into the Center connector, sounds great too. My Rega R1's to the Surround Back and well, they are kinda quiet. I went into the menu/Speaker level and set up the volume bar all the way up and the R1's are still kinda quiet. What gives? Should I switch them to Surround?
Second issue: When I switch to True HD on The Dark Knight Blu-ray the R1's stop transmitting sound entirely. What gives?
Any help would be appreciated!
Sources: Oppo DV-980HD (sacd/dvd-a playback), LG BD-570 blu-ray player
Speakers: Rega RS5's, Rega R1's, Rega RS-VOX
Receiver: Yamaha RX-V663
gloco is offline
post #10946 of 11059 Old 03-16-2012, 09:31 AM
First, Surround back is only for 7.1 speaker setups. If you have 5.1 setup, you use surround outputs.
Did you re-run YPAO after connecting the speakers? If turning them all the way up is still not right, your have to turn down all the other speakers until they are balanced. YPAO will do that for you.
Currently you have the speakers on surround back, so you must be using Dolby Pro Logic2x (D PLIIx) to change TRUEHD 5.1 to 7.1. This mapping only works with newer FW and doesn't work for DTSHD with any FW. But when you properly connect your 5.1 speakers you will be fine as you won't be using the surround back outputs and YPAO will disable them.
post #10947 of 11059 Old 03-16-2012, 11:31 AM
gloco's Avatar
Currently you have the speakers on surround back, so you must be using Dolby Pro Logic2x (DPL2x) to change TRUEHD 5.1 to 7.1. This mapping only works with newer FW and doesn't work for DTSHD with any FW. But when you properly connect your 5.1 speakers you will be fine as you won't be using the surround back outputs and YPAO will disable them.
Excellent! No, I haven't run the YPAO and it sounds like I should...I totally blanked out on that. Thanks again!
gloco is offline
post #10948 of 11059 Old 03-17-2012, 06:03 AM
tbielowicz's Avatar
Quoted: 21 Post(s)
Is anyone have "out of phase" issues after running YPAO? My center keeps coming up that way but it is wired correctly. Others have said that YPAO has a tendency to do this.
Family Room 7.1 setup: KS8000 / Energy RC Micro / Mirage BPS 150 / Pioneer SC-1323k
Home Theater 5.4.1 setup: Benq W1070 / SVS Prime Satellites / SVS SB12-NSD / Denon x4300h
tbielowicz is offline
post #10949 of 11059 Old 03-17-2012, 07:11 AM
caper_1's Avatar
Liked: 26
if you are sure the wiring is ok, ignore that error
HT: Yamaha RX-V565 | 3 X Energy Take FPS, 2 X VS Surround, 2 X Take LCR | DIY Subs: SDX12 APR15 & TRIO12 Dual APR 12's | 47" LCD
Music: Yamaha RX-V863 | 2 X Energy RC-70 | MA RXw12 Sub
Bathroom: 2 X Energy Take LCR
Car: Sony Xplod HU, Xplod 6X9s, Kenwood 4"s, Alpine 12" Type-S, Rockford Amp,...
caper_1 is offline
post #10950 of 11059 Old 03-17-2012, 08:46 AM
kgallerie's Avatar
Quoted: 63 Post(s)
Liked: 85
So I tried using the DVD player through HDMI last night, and the audio was playing through the receiver, but the video was not passing through. I tried playing with a bunch of settings (including upconversion) and nothing worked. When I went to the video signal info menu, it displayed:
HDMI SIGNAL
HDMI -> ___
HDMI RES
1080P -> ___
ANALOG RES.
480/576i
So it appears that nothing is being sent to the HMDI output. Any suggestions on how I might get to work?
As an alternative, i ran the HDMI from the DVD player to the TV, then the optical out from TV to the receiver. Would this method of connection have any effects on the sounds quality or surround modes vs. using the HDMI pass through on the receiver?
Any advice would be appreciated.
