Acoustic panels hanging from the ceiling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 22 Old 03-27-2008, 11:35 AM - Thread Starter
InPhase's Avatar
I have been to a few home theater demonstration rooms that had what appeared to be acoustic panels hanging from the ceiling at an angle. What is the purpose of these? Should they be tilted towards the screen or away? Why don't they just attach them flat to the ceiling?
InPhase is offline
post #2 of 22 Old 03-27-2008, 11:54 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Originally Posted by InPhase View Post
... acoustic panels hanging from the ceiling at an angle. What is the purpose of these?
To absorb early / first reflections. More here:
http://www.realtraps.com/rfz.htm
When an absorber panel is mounted a few inches away from a surface it works to a lower frequency. The panel also behaves as if it is larger because sound striking the ceiling or wall near the panel can get into the rear and be absorbed. This assumes the panel is designed with an absorbent rear surface.
--Ethan
Ethan Winer is offline
post #3 of 22 Old 03-27-2008, 02:59 PM - Thread Starter
InPhase's Avatar
I understand the advantages of leaving room between the absorber panel and the surface. It is the angle that perplexes me. They were hanging at angle of around 25-45 degrees I believe. I don't see many here designing their home theaters with panels hanging at an angle above the listening position. Is this an old trick for less effective absorbers?
InPhase is offline
post #4 of 22 Old 03-27-2008, 05:13 PM
Harrypt's Avatar
Angles make the reflections (from walls or those not absorbed by panels) rebound at a greater or less than 90 degree angle. That way the reflection bounces around the room at odd angles and dissipates.
90 degree angles cause it to bounce back and forth repeatedly between two walls or from ceiling to floor. This allows it to build upon itself effectively sounding louder as the reflection passes the listener repeatedly in the same plane.
Harrypt is offline
post #5 of 22 Old 03-28-2008, 05:25 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
It depends on the type of panels. If they are fiberglass, then they will absorb sound on both sides. If you have the ceiling room (cathedral ceiing), these can make a very effective treatment option. I recently designed a very large home theater with 15 4x8 foot acoustical clouds and baffles hanging from the ceiling!
Hanging, angled reflective panels redirect sound, and improve diffusion. You find them in laboratory reverberation rooms, which need to be extremely "live" but also to have very diffuse sound fields.
Terry
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
post #6 of 22 Old 03-28-2008, 10:09 AM - Thread Starter
InPhase's Avatar
In a home theater, wouldn't you want to make the ceiling virtually disappear by using absorber panels instead of creating reverberation? Wouldn't this be more similar to recreating the very tall ceilings in real cinemas?
Terry, what is an acoustical cloud/baffle? That must be a huge room! Do you have any pictures of a theater with the panels hanging from the ceiling? I can't seem to find any pics of these.
InPhase is offline
post #7 of 22 Old 03-28-2008, 10:21 AM
Yes, some of my clients have very large home theaters.
I don't know if this is an official definition, but in my experience, a cloud is anything hanging from the ceiling either horizontally or at an angle, while a baffle hangs from the ceiling vertically.
Here is an example of an acoustic cloud:
http://www.allnoisecontrol.com/products/Clouds.cfm
Here are acoustic ceiling baffles:
http://www.enoisecontrol.com/baffles.html
Terry
post #8 of 22 Old 03-28-2008, 12:28 PM
Quoted: 264 Post(s)
Liked: 359
Yes, as long the panel is not backed with Masonite or plywood as is sometimes done.
Yes, and I have that in both my home studio and my living room HT (photos below). This works very well to avoid the focusing that can happen under a peak or curve.
--Ethan
post #9 of 22 Old 03-28-2008, 12:45 PM
dknightd's Avatar
Cute video Ethan
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #10 of 22 Old 03-29-2008, 09:48 AM
Quoted: 264 Post(s)
Liked: 359
Originally Posted by dknightd View Post
Cute video Ethan
post #11 of 22 Old 03-17-2009, 11:53 AM
jschlesi's Avatar
Has anyone used a drop a simple drop ceiling grid ( 2x2 tiles) in a 10ft by 10ft suspended 2 or 3 inches from an existing finished drywall ceiling? I figure the tiles will help with sound leak to upstairs. How does the metal/plastic in the grids affect sound?
In my head I see this a few inches suspended with maybe a LED rope tucked inside for a soft light effect.
Ideas?
jschlesi is offline
post #12 of 22 Old 03-17-2009, 12:29 PM
jschlesi's Avatar
Super cool, but I was just thinking something simple (and cheap) using a t-bar grid and tiles.
jschlesi is offline
post #13 of 22 Old 03-17-2009, 12:50 PM
Rutgar's Avatar
Terry
What about these? They don't look like they fit in either catagory.
Rutgar is offline
post #14 of 22 Old 03-18-2009, 06:49 AM
Clouds. Looks like they may be hard surfaced, in which case they could function as diffusers. Yes, diffusers can consist of just angled hard panels. This type of diffuser is commonly used in lab reverberation rooms.
What absorptive ceiling clouds and baffles have in common is that they treat a volume of air. They effectively create this volume themselves. The result is more available absorption surface than would otherwise exist in your room. Treating ceiling reflections is a bonus. They are great for controlling reverberation in rooms which have limited areas available for treatment.
- Terry
post #15 of 22 Old 03-18-2009, 07:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Yes.
Not so much. If you use acoustical tiles, the major effect will be on the room they are in.
If you want to reduce transmission, build a second ceiling on its own frame, that is as isolated as possible from the existing ceilng. Dry wall would be fine.
not so much
arnyk is offline
post #16 of 22 Old 03-18-2009, 08:42 AM
Rutgar's Avatar
- Terry
Thanks Terry. Approximately what range of frequencies do you think this setup addresses?
Rutgar is offline
post #17 of 22 Old 03-18-2009, 08:55 AM
Honestly, if those are reflective panels, then that particular setup looks dubious to me. It is common to use such hard ceiling panels angled so as to reflect sound from source to listener for live, unamplified music and speech enhancement in auditoria. It both strengthens the sound and provides a sense of spaciousness. I don't see what good it could be doing in a home-sized room for amplified sound.
post #18 of 22 Old 03-18-2009, 09:20 AM
Rutgar's Avatar
Well then, it's not just me! I've always wondered how this configuration is supposed to work, and on what frequencies. The picture doesn't show it, but the speakers are located to the right and the listening position is to the left. Which seems like higher frequencies would go into the 'open' end of the panels, and then reflect up to the ceiling thus bouncing around a bit and losing energy. I have no idea what influence this cavity would have on lower frequencies.
Rutgar is offline
post #19 of 22 Old 03-18-2009, 11:45 AM
Quoted: 264 Post(s)
Liked: 359
Agreed.
post #20 of 22 Old 03-06-2013, 01:52 PM
Rachel Ackley's Avatar
On this same subject we just built some panels using fiberglass covered in speaker cloth for our church. At this point we will be hanging them on the ceiling to help with a major echo problem we have. Would we be better off hanging them flat on the ceiling or at angles and if at an angle what degree? The plan is to use chain so they can be adjusted if needed and the ceiling is 24 ft high.
Rachel Ackley is offline
post #21 of 22 Old 03-06-2013, 03:48 PM
Quoted: 264 Post(s)
Liked: 359
Hang them parallel to the ceiling, a few inches down. The resulting air gap improves absorption.
--Ethan
post #22 of 22 Old 03-07-2013, 01:08 PM
Thanks Ethan, that is a great help and will make hanging them this weekend much easier smile.gif
