Digital Audio Coaxial Splitter? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 03-27-2008, 07:45 PM - Thread Starter
DevonTT's Avatar
I have an antiquated audio system that has only one digital input--a digital coaxial (RCA-type) cable. This input has to share two sources, but I don't want to have to switch them manually.
One source is the cable box. The other is a PS3 (coming through an optical-to-digital converter). The two sources will never be used at the same time.
Is there a Y cable that will take a signal from both sources and pass through only the source that is on and supplying a signal?
DevonTT is offline
post #2 of 19 Old 03-27-2008, 07:52 PM
Liked: 62
I don't know of any splitter like that. There is this from Monoprice.
http://www.monoprice.com/products/su...01&cp_id=10112
It's a tad overkill, but does have the coaxial connections. I'm also wondering if a composite video switch would work.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #3 of 19 Old 03-27-2008, 09:19 PM - Thread Starter
DevonTT's Avatar
Can you run audio through a video splitter?
DevonTT is offline
post #4 of 19 Old 03-28-2008, 12:40 AM
Rupert's Avatar
You would need a digital audio switch, not a splitter.
Examples:
http://www.inday.com/da4x/da4x.htm
http://www.audioauthority.com/produc.../Digital_Audio
Rupert is offline
post #5 of 19 Old 03-28-2008, 07:37 AM - Thread Starter
DevonTT's Avatar
Thanks, Rupert.
DevonTT is offline
post #6 of 19 Old 03-29-2008, 12:41 PM
drunkpenguin's Avatar
Quoted: 1350 Post(s)
Liked: 1367
sure about that? i am successfully splitting digital audio in the opposit way he needs to. I have 1 source splitting to 2 seperate inputs on my receiver. (dont ask why but it had to be done).
Just 'cause you're right doesn't mean I'm wrong
drunkpenguin is offline
post #7 of 19 Old 06-09-2008, 05:12 AM
Spottedfeather's Avatar
Quoted: 17 Post(s)
I, too, am wondering about this. I'm thinking of getting a home theater system but the one I'm interested in has only one digital coaxial input. But I have a question about this. I thought that coaxial cable was like a regular cable like for cable television. But from the inputs on this switcher, it looks like coax is normal RCA cable. Which is it ?
http://www.audioauthority.com/produc...ital_Audio/5/1
Spottedfeather is offline
post #8 of 19 Old 06-09-2008, 10:22 AM
sivadselim's Avatar
Quoted: 266 Post(s)
Liked: 224
There is a difference between splitting and merging. Although what he is describing MAY work, OK.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #9 of 19 Old 06-09-2008, 10:25 AM
sivadselim's Avatar
Quoted: 266 Post(s)
Liked: 224
Examples:
I'm not certain, but all you may need is a cheap switcher that has RCA inputs/outputs. If analog audio ins/outs won't work, then component video ins/outs should.
post #10 of 19 Old 06-09-2008, 10:27 AM
sivadselim's Avatar
Quoted: 266 Post(s)
Liked: 224
Originally Posted by Spottedfeather View Post
But I have a question about this. I thought that coaxial cable was like a regular cable like for cable television. But from the inputs on this switcher, it looks like coax is normal RCA cable. Which is it?
They're the same thing. They simply have different ends. But both are "coax" cable. "TV cabling" can easily be converted to an "RCA cable" with male F to male RCA adapters.
post #11 of 19 Old 06-09-2008, 04:09 PM
Quoted: 17 Post(s)
Ah. Thanks for the help.
post #12 of 19 Old 06-09-2008, 08:44 PM
aymanme's Avatar
I don't know if it would work, but at the very least if you try this, you need to put some resistors in there. Basically, you don't want to couple the outputs of two drivers together. You could potentially blow the output amplifier in one of them. If you want to build a splitter and try it, you need to do something like this, where c is the common input, ZZZ is your resistor maybe 1K or so.
Input a ----ZZZ----c
Input b ----ZZZ----c
aymanme is offline
post #13 of 19 Old 07-16-2008, 10:56 AM
b_d0za's Avatar
I picked up a phono (RCA) splitter at radio shack that seems to work just fine.
I can't post a URL yet since this is my first post so I'll just post a couple more so I can.
b_d0za is offline
post #14 of 19 Old 07-16-2008, 10:59 AM
b_d0za's Avatar
I have a receiver with only one digital coax input and I have a DVD player and a cable box that both have digital coax out.
I use a logitech harmony remote so if I want to watch a dvd I hit the "Watch DVD" button and it turns on my DVD Player and turns off my cable box and if I want to watch cable tv I hit the "Watch Cable TV" button and it turns off my DVD player so only one is on at a time.
b_d0za is offline
post #15 of 19 Old 07-16-2008, 11:01 AM
b_d0za's Avatar
So far so good. It SEEMS like it is working just fine. I get DD 5.1 from both the DVD player and the cable box without having to get up and switch a switch or manually change the connections so...
b_d0za is offline
post #16 of 19 Old 07-16-2008, 11:02 AM
b_d0za's Avatar
Here is the splitter I am using:
http://www.radioshack.com/product/in...entPage=search
Does anyone know any reason why one should not do this?
I have been testing it out quite regularly every day just to make sure it's still working correctly and have had no problems after a week or so.
b_d0za is offline
post #17 of 19 Old 07-16-2008, 11:23 AM
sivadselim's Avatar
Quoted: 266 Post(s)
Liked: 224
If it works, that's great. If both devices are on at the same time, it MAY cause some problems, but in using the Harmony you will most likely avoid this happening. The issue is that the signal from one device may be shunted to the other device. And if both devices are on it could possibly damage the receiver's digi coax input and pre-amp stage.
post #18 of 19 Old 01-07-2009, 10:04 PM
TM2 Rampage's Avatar
Excuse me, but I'm going to bump this in case anyone wants to offer any more information. I, too, am thinking of using a Y splitter to connect by Blu Ray player and HD Cable Box to my receiver, because my receiver one has 1 digital coaxial audio input (and no digital optical ;__. I've already PMed b_d0za but I'm still gonna bump this...
Has anyone who tried this experienced damaged equipment yet?
TM2 Rampage is offline
post #19 of 19 Old 01-08-2009, 05:08 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
[quote=b_d0za;14303290]Here is the splitter I am using:
[quote]
Yes, but I can also explain why it will often work.
SP/DIF is an impedance-matched system, like a TV antenna. Unlike TV receivers, SP/DIF receivers expect an input signal that has at least a certain voltage level.
Your passive splitter is wrong on two grounds. It violates impedance matching, and it could violate the input voltage requirement.
As has been suggested, the splitter of choice for SP/DIF is a video splitter. Not an antenna splitter with F connectors, but instead an externally-powered video splitter with RCA connectors.
That all said, SP/DIF over short distances and with a small number of components has become fairly non-critical.
You say that your passive spitter works, and I don't doubt it.
If it is not broke, don't fix it!
If some day you move your components around and change the cabling and it stops working, then run right out and buy that video splitter or video distribution amplifier.
arnyk is offline
