Bi-wire Stereo Speakers on a Marantz AVR? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-05-2008, 02:27 PM - Thread Starter
RequiemX's Avatar
I have two speakers that are made for bi-wiring. Each as a woofer, tweeter, and "super woofer". There are four wires on each.
I'm planning on picking up a Marantz SR5002 and am wondering if I can use these speakers on it if I flip that "Speaker C" switch.
Is that possible?
(It would only be temporary until I can save up for better speakers: my main need right now is to have multiple audio inputs...)
RequiemX is offline
post #2 of 9 Old 04-05-2008, 04:11 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Don't. Just connect a jumper between the speaker's + terminals and another between the - terminals. Then one set of speaker cables will do fine.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 9 Old 04-05-2008, 05:18 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Originally Posted by RequiemX View Post
..................... am wondering if I can use these speakers on it if I flip that "Speaker C" switch.
Could you explain a little bit more how you plan to wire things at both the receiver end and the speaker end of things?
What speakers, btw?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #4 of 9 Old 04-06-2008, 12:49 AM - Thread Starter
RequiemX's Avatar
The Marantz SR5002 seems to have a switch you can flip on the back called "Speaker C" [why it's called that, who knows...], that uses what are usually spare outputs for a pseudo bi-amp setup.
I was planning on using it with some Panasonic speakers that are designed for a Panasonic stereo that had a bi-amp setup. There are four wires attatched to each speaker. One pair is for highs and the other for lows.
I know they're hardly ideal speakers, but I desperately need multiple inputs right now and would just like to start with a good receiver so I can solve that problem and then pick up some good speakers in a month or two.
I guess I just wanted to make sure it was okay to use these speakers since they came paired with a stereo. The specs seem okay, though (6
Ω, but the Marantz should support that).
RequiemX is offline
post #5 of 9 Old 04-06-2008, 06:04 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1684
There is no benefit from doing what you propose to do. None. Zero. Follow Kal's advice.
FMW is offline
post #6 of 9 Old 04-06-2008, 07:06 AM
whoaru99's Avatar
Liked: 69
Might work, or it might not.
If the Panasonic speakers don't have crossovers and relied on the Panasonic stereo for real bi-amp setup (split high and low frequencies fed to the speakers), you'll probably blow the tweeters doing what you propose.
If not, then it'll work. But, if that's the case, it would work just as well with the high/low pair of wires from each speaker (connected in parallel) to just one set of speaker outputs.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
post #7 of 9 Old 04-06-2008, 09:03 AM
Quoted: 678 Post(s)
Liked: 461
Hold on. You didn't tell us that these were the infamous Panasonic biamp speakers!
These are simply unusable since they do not have any built-in crossovers and require an external one. You do not have one and the speakers are not worth the effort/cost to add one. Chuck 'em.
Kal Rubinson
post #8 of 9 Old 04-06-2008, 12:47 PM - Thread Starter
RequiemX's Avatar
Thanks for all the advice. I guess it's off to the speaker-collecting father in-law to see if he might be okay with a couple loaners…
Edit: Oh, and I didn't realize they were infamous! I'm amazed that anybody even knew these things existed.
RequiemX is offline
post #9 of 9 Old 04-06-2008, 06:59 PM
Quoted: 678 Post(s)
Liked: 461
You are not the first who has wanted to use these with a real AVR.
Kal Rubinson
