Using a component video cable for subwoofer cable? - AVS Forum | Home Theater Discussions And Reviews
Old 07-11-2008, 03:05 PM - Thread Starter
snappy_phd's Avatar
After switching to HDMI cables for my video applications, I find myself with a lot of component cables. Is there any problem using component video cables as subwoofer (LFE) cables? At least it will give me some use for them...
snappy_phd is offline
Old 07-11-2008, 03:09 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Will work just fine. They're probably ideal, actually. They're simply 75ohm cables.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
Old 07-11-2008, 03:44 PM
FoSheezy's Avatar
I bought some nice component cables specifically for my 2 subwoofers and buttkicker amp.
Cheaper in most cases.
They work perfectly.
FoSheezy is offline
Old 07-11-2008, 04:38 PM
Tulpa's Avatar
Liked: 61
Yeah, there's nothing special about component video cables. They're just three composite video cables bundled together, which are also digital coaxial, which are also marketed as subwoofer cables, etc., etc.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
Old 07-30-2008, 03:17 PM
cognitive77's Avatar
Thought I'd piggyback onto this. Just recently got my Klipsch RW-10d sub in and tried using my component (blue cable) as a sub cable. But am not getting any sound out of the sub.
My receiver is a Yamaha 663.
Any thoughts?
nm, I'm retarded. Fixed now.
cognitive77 is offline
Old 07-30-2008, 09:17 PM
whoaru99's Avatar
Liked: 69
Any thoughts?
Helps to turn it on, eh?
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
