22 Tips to Obtain Better Sound in a High End Audio System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 66 Old 08-11-2008, 02:52 PM - Thread Starter
nonamehifi's Avatar
Özhan Atalay
Introduction
Basically accepted only thing in audiophile world is that it almost impossible to achieve the best sound by just combining only the best equipments. Much cheaper but properly selected and tweaked audio system may sound better than its expensive brothers. This is called system synergy in audiophile world. System synergy is not only about combining the best equipments but it is a kind of long and enjoyable way to maximize their performances.
The precautions and principles may be seen absurd and meaningless for someone who does not have solid understanding what the hi-end is.
Within last twenty years, I spent considerable time, money and efforts to achieve best sound (...Or what ever the best is). I wrote a couple of important points from my own perspective. Most of these points may be known by the audiophiles anyway if not implemented. More important, below points consist of my own observations merely. There are so many known different tweaks and techniques. I avoided not including here the points that I did not try and/or the points did not work well with me. I believe below mentioned points will step up someone's system to a higher level by using the same equipments.
The only certain truth I learned after twenty years is that "there is no one absolute truth in Hi-End" Most of the truths in High-End can not be proven by scientific measures. Very sensitive human ear hears a lot, interpret, evaluate and decide. In a listening session of three audiophiles, what is probably going to happen is one of the persons will find the bass insufficient, the other may find it so much and excessive, but the system owner will think it is fine, not less, not more. That phenomenon is called "brain reference". (See for more details) Brain reference is a kind of prejudice comes out of our own system's timbre and tonality. This phenomenon sometimes causes conflicts with someone who compares better equipment versus his own equipment and may not like the sound of the other in spite the other was clearly better.
Most of the points stipulated below will depend on the capabilities of the system but more important, depend on the experience of audiophile. A poor system will not differentiate the points or less experienced ears may not pick them up either. That's why some of the points below may not be regarded by everybody. I will be delightful if someone who reads that article picks up one or two points.
1- Listening at Night; Critical listening or equipment testing should be done in the night hours. This rule obviously applies to one who lives in a big city. Not noticeable city noise affects our hearing and we are basically not able to hear what our system delivers to us during the day.
Due to city noise is several times lower in the night, all hidden aspects in hi-end appear in the night and the system delivers its full potential. For more information, please check Noise (see for more details)
2- Heat and Humidity; Humidity and heat have serious influences on sound. Systems can not generate their best sound, power and dynamics in a warm and damp weather. I am not sure why this happens but it happens. There may be two reasons: The damp air is heavier in such circumstances, thus the loudspeakers are not able to pull enough air into the room. Or the loudspeaker materials may soften and behave differently in warm weather. To cool the listening environment prior to listening session eliminates that effect.
3- Darkness; Music should be listened in dark room. Particularly, the loudspeakers and the system should be kept in dark and the original recording venue should be imagined while listening.
The main objective of a good quality hi-end system is to depart from the hardware and to go into the recording environment. Listening music while watching the hardware will physiologically demolish the virtual environment that we intent to be in. The most inconvenient part of a hi-end system is in existence of visual imaging. The reality sense is so different when participating to a live concert or listening/watching from a DVD player via a surround system.
If the listening environment is not dark, the speakers will be perceived as the sources of the original sound.
4- Finding the Correct Listening Distance; the sound is spread in waves called frequency. The volume of every frequency will be different in connection with the distance from the speakers. In terms of the volume, frequencies will be up and down when the distance is changed. Especially higher mids and treble sections will vary between 20-5 centimetres. Such frequency peaks can be easily recognized by listening.
a - Listen a test CD containing different test frequencies. For instance start with mono 1000 Hz at the listening chair. Then stand up and walk very slowly through your system. (Preferably with your eyes closed). You will immediately realize that the signal will have ups and downs in volume while you are moving as if somebody was turning on and off the volume control.
b - The main frequency of the music and the one which is closest to human sound is 1000 Hz. 1000 Hz is your starting point. 1000 Hz will be at its peaks so many times in connection with the distance of your listening chair. Find the closest distance to your current listening chair that the 1000 Hz is at peak. The ups and downs in that band should be changed around 50-70 centimetres. This is the best location to hear the middle frequencies but it is not the best location yet to achieve the best frequency spectrum. It is just the starting point.
c - Stick a rope to back wall that may come through your shoulders. Now close your eyes and listen different frequencies such as 300-500-1000-2000-5000-10.000 Hz etc, move top of your body (while sitting) forward and backwards. Mark the peak points of every frequency you listened on the rope. Our aim is to find a particular point that most of the frequencies are at their peaks. If you are not successful and these points are not closer each other, move your speakers 10 centimetres to front (or your listening chair to 10 centimetre front or rear) and repeat the same exercises till you find a certain point that most of the frequencies are at their peaks.
It is not an easy task, time consuming but free of charge. Once you have the point, you will be very surprised with the improvement of the sound of your existing system.
5- Room Acoustics; Room Acoustics is the most known but the least considered part of Hi-End. A conventional speaker may throw % 40 of the sound directly to listener; rest of the sound comes through the walls by reflections. Reflection means the timing difference of the original signal, hence an additional acoustic which does not exist in the original record. Within such a complexity of reflections, a part of the original signal will come late due to the front wall or ceiling or etc, a part of the original signal produced by the left speaker will come as if coming from the right speaker and vice versa. Such a complex listening environment will demolish the stereo imaging and channel separation.
Some audiophiles are happy with this case due to speakers are seem to be better disappeared and soundstage is wider and deeper. Some producers add additional mid/treble units to the back side of the speakers (dipoles) to emphasize such effects.
One thing should be considered that such reflections do not exist at the original sound. If something is produced by the system/room in addition to the original sound should be named coloration.
If the aim of a good hi-end system is to reproduce the original sound, such reflections should be avoided as much as possible. Especially ribbon and electrostatic speakers will suffer a lot from such reflections.
Carpet on the floor is a must to lower the reflections (standing waves) between the floor and the ceiling. Thicker curtains will help to lower the reflections of the windows. Glass covered photos and such stiff furniture should be avoided.
This article is not intended to give recommendations how to make a room tuning, lots but lots of information may be found on internet. But it is just to emphasize the importance of room acoustics.
6- Precise Focus and Loudspeaker Placement; this is also another known but the least considered part of Hi-End. It is critically important to locate both speakers at the exactly same distance to achieve precise focus. Distances should be very carefully measured and both of the speakers should be placed exactly to the same distance through listener.
OK but why such important!
Sound signals are distributed in waves as explained in section five. The people who tried the settings in section five will realize that, the peaks of frequencies vary in conjunction with the distance from the speakers. Especially the treble frequencies will vary a lot by only one centimetres of a change. In such cases, if one speaker is just one centimetre closer to the listener, some frequencies will be heard a lot from one speaker but will not be heard from the other speaker. If the upper harmonics of the human sound consist of such upper frequencies, (it is!) this is obvious that the sound will move from the middle to left or to right. Moreover, within that case, some frequencies will be collided in full phase and will be exaggerated, some others will be collided by inverted phase so are destroyed.
This is the exactly the same effect of loosing bass when connecting one speaker out of phase.
7- Mechanical Vibration of Electronic Units; Quite a lot of vibration absorption feet and platform kinds exist in the market. They are to be placed under the electronics/speakers. Such materials have two intentions;
a- To eliminate the external vibration coming through the unit
b- To eliminate the vibration of the unit itself (CD driver motor, speaker cone vibrations etc)
Most popular ones are the cones (spikes). I believe the proper usage of spikes is not known very well. Rather than being a vibration absorber, spike is a kind of transmission material that transmits vibration from one point through the other point. In other means, vibration is condensed to one point and mechanically carried to other platform by the spike but not eliminated. If the connection surface is stiff (for instance marble, granite, etc) such vibrations are passed to that surface. Underneath of such a stiff platforms (marble, MDF, glass, granite) must be covered by an elastically material such as cork, mouse pad, neoprene rubber or similar.
The vibration can not pass from a stiff platform to an elastically platform and will be transposed to heat between.
Direction of the cone is also critically important. The direction should be in conjunction with the intention of vibration transmission.
May be the last thing about the cone is the cone should be in touch with the chassis of the component directly. If any kind of rubber, double sided band, blue tack or such an elastic material is put between cone and the unit that material will try to transpose the vibration and the cone will not work.
8- Marble Under the Loudspeakers: A marble platform under the speakers eliminate most of the unwanted resonances of the speaker. The thickness of the marble should be at least 3 centimetres and the size should be at least 10 centimetres bigger then the edges. Underneath of the marble has to be covered by an elastic material such as cork, mouse pad, neoprene etc.
How does it effect the sound is, you have more powerful but more clear and tight bass, relaxation at the mid and top frequencies.
The speaker has to be connected to the platform via a cone, not by an elastically feet. The sharp end of the cone has to direct the marble but not to the loudspeaker.
9- Grounding the Metals for Static Electricity; especially in wet weather and in fully carpeted listening environments, static electric become an issue. The carpet is charged with static electric which can be passed through the electronic equipments via the rack and/or via human touch. Static electricity on the carpet is such powerful that when checked in the morning before somebody walks on it, can be clearly seen by simple tools sold in Radio Shack
In order to eliminate the effect, the loudspeaker stands and the equipment racks should be connected to earth by a thin wire. Moreover, the loudspeaker cables and interconnects should be lifted away from the floor due to the same effect.
What benefits you may expect from this tweak is I don't know why but less blurry and more tide lower bass.
10- Loudspeaker Distance from the Front Wall; Loudspeaker producers generally recommend the distance of the speaker by the front wall (the wall behind the speakers). Generally speaking, the speaker should be located as far as possible from the front wall. (Side walls as well) If they are so close to the wall, bass standing waves will be reinforced (explained in article five) and mid/treble band will be compressed due to excessive bass energy.
Some audiophiles find the desired bass volume by placing them closer to front wall which is not correct. One thing should be considered that such bass increase is not due to the original sound but it is the consequence by the room response called coloration.
11- Auto former / Transformer Passive Line Stages; The new developed technologies in hi-end industry made the pre-amplifiers questionable.
Before end, the reason of a preamplifier was stipulated in four basics;
a- To connect more then one unit together
b- Recording to tape from some sources
c- Low volume output and inverted polarity signal of turntables (as the only source component)
d- Bass, treble adjustment requirements
Nowadays, CD, SACD units can provide 5-8 Volts of outputs which are more than enough for the power amplifiers. Audiophiles are not interested in tone adjustments but focused on simplicity anymore. Dedicated phono stages are in common usage, hence, the majority of the requirements are not valid anymore.
The main and the only basic job of a modern pre-amplifier is to lower the volume level, not step it up!!
Just try to imagine a pure signal from a CD, or DAC through the power amplifier, then cut this link, add four plugs, four female plugs, a pair of interconnects, lots of resistors, capacitors, tubes, transistors and all that stuff in the link. How can you keep the signal purity and can you make something better then its original!
An active line stage demolishes the neutrality and the purity of the original sound. Such a corruption may not be so evident in most of the lower resolution systems or disregarded by some people on purposely. Every active line stage has its own tonality and coloration. As a matter of fact, audiophiles generally use line stages to balance their tonality problems in systems. For instance, a tube line stage is used to calm down a firm sounding solid state power amplifier or a treble rich line stage is used to compensate the treble poor power amplifier and vice versa. If this is the case in a system, fully natural line stage and lack of coloration will not be regarded by the audiophile.
Following me, the consideration should be to change the power amplifier till finding the desired sound rather then playing with pre-amplifier. In other words, deal with original problem rather then trying to mask it.
It is almost in consensus that using a very simple volume pot adds so much neutrality and purity to sound. But in such cases, some other problems appear. A volume pot which is either a potentiometer or a stepped alternator works with the resistance principals. Every volume step adds different resistive path to signal, thus lowers the volume. Due to the complexity of the music signal (20 Hz-20 kHz), such a resistive load will act like a barrier for different frequencies. For instance when turning down the volume level, the treble is lowered and the bass is condensed or when you increase the volume, mids are excessive or vice versa. Not to forget to mention is the lack of dynamic range as well. A line stage eliminates these problems.
Due to these facts, volume control pots or analogue volume controlled CDs can not be used stand alone as line stages
By the new technology, new auto former and transformer passive line stages are developed for volume control.
Such units do not work with resistance principals and do not add resistance to the signal path. The only resistance of such amps is approximately 200 Ohms due to the cable in windings.
Transformer passive line stages consist of two transformers, one for the left channel, and one for the right. They have one primary winding and multiple (12-24 steps) of secondary windings. Their principal is to lover the volume by changing the volts, rather then adding resistance. Up to my knowledge, there are only three producers of such line stages. I used two of them. Both of them are providing extra ordinary natural, calm and undistorted sounds.
I heavily modified the Antique Sound Lab myself which is very good product and quite cheap too, (don't underestimate its price) but Audio Consulting's Silver Rock made of pure silver is something else.
It should be also mentioned that such a passive line stages can not be suitable for every system. In such a case, input impedance of power amp should be driven directly by the output stage of DAC or CD player. Input impedance of the power amp should be as small as possible. The best way to learn this case is to write the impedance values to producer and request assistance prior to purchasing.
12- Good Tubes (NOS Tubes); is it logical to pay 100 USD to and old tube while the new one costs 10 USD.
I believe it is. A good tube can change the characteristics of a tube electronic as if you replaced the entire unit. Nos tubes are not easy to find, quite expensive but worthwhile to use. Especially the upper frequency hiss is quite lower with Nos tubes.
13- Very Easy Polarity Finding Method; Generally speaking, European (German) standard AC plugs do not have the signal direction. US, UK, Swiss AC plugs have one way to connect to AC, so + and - phases can not. So in such cases, it is not easy to find out the correct polarity.
All electrical and electronic components will work properly regardless of the polarity. But why the AC polarity is quite important in Hi-Fi!
Electricity arrives from (+) passes the electronic circuit and departs from (-). Generally the mains current arrives in the power supply of the unit first then reduced to desired voltage by of the electronic circuits. At this case, mains is automatically filtered by the power supply section. The transformer of the power supply section behaves like isolation transformer, input and output currents are physically separated. If the polarity is not correct, the mains will arrive to system directly from the back door and will carry all the pollution like RFI/EMI into the unit. Due to the fact, it is important to find out the correct polarity.
Most of the electronic' polarity is similar. If the unit has detachable power cord and IEC kind of input, the right hole should be the (+) mains when do you look at the plug front the front face (as seen below?)
Another simple method is to check the mains fuses. If the unit is equipped with an exterior protection fuse, release the fuse and check it by an electricity check pen while the unit was connected to mains. It should be (+) signal. If not, reverse the AC plug from the wall
14- Listening Volume Level; it is for sure nobody's business to tell you that what the correct listening volume setting is. Some audiophiles like very low listening level, some turn on the volume till the windows are broken.
If the outcome is to achieve the ambiance of the recorded venue, volume level should be adjusted accordingly but not more or not less. This case is applicable to acoustic instruments only but not to electronic music, jazz or disco etc.
What ever the listened record is, correct volume setting should be the one which does not enlarge or shrink the original instrument. Higher volumes, for instance a guitar should be played with the original volume of a guitar by correct volume setting. If volume level is increased, the body of the guitar will became bigger in obsolete terms, on the other hands; full body of a Mormon chorus will not be so realistic at low volumes
15- Warming Up the Speakers and Cables before Critical Listening; Apart from the theory that "Solid state electronics provide their best sound for a few minutes till the transistors became warm. All audio equipments need a warm up time. This time is at least 1/2 hour or even 1 hour in spite the manufacturers recommend less. Up to my knowledge, the reason behind this is the specifications of the resistors, capacitors, tubes and other stuff vary if they are cold or warm. Manufacturers make final settings when the units are warm, otherwise they would play perfect for the first half an hour and worse after warmed up.
That principal is applied by every audiophile for the electronics but not always for the speakers and the cables.
Speakers are quite important since their passive components should be warmed up such as crossover resistors. Their voice coils should be warmed up as well. The cables are also important. Warm up term may not eligible for the cables but the cables should be run for sometime till their dielectrics are charged.
As a result, the warming up time should be completed by playing (may not be listening) the entire system.
16- Proper Loudspeaker Selection for Listening Room; Loudspeaker should be selected in conjunction with the listening room dimensions. Unfortunately the general tendency in audiophiles particularly in US is "the bigger is better"
It is like some new starting skiers that choose the best ski equipments prior to learning and facing with so many problems afterwards.
Big loudspeakers are difficult to position, difficult to drive, affected more from the room boundaries. If the speaker is bigger for the room, excessive bass energy will diminish rest of the sounds. The bigger speaker means bigger problems. Driving big speakers requires challenge, experience, sources, time and money.
17- PS Audio Power Plant; Principally I avoid giving specific brands in my non commercial web site. But PS Audio Power Plant is such a special product that similar components do not comparable with. It is a kind of power regenerator powered by electricity. P300 actually regenerates new AC for the audio gear. This regenerated AC is of much better quality than filtered AC because of the stabile voltage and near perfect AC waveform. It also removes 70 dB of EMI and RFI noise from the AC line!
Not all friends are agreed with me but according to me, it is very special equipment that lifts up the entire system to a higher level.
What would you expect from it is much relaxed sound, more layered deep and wide soundstage, crystalline treble and more inner details. Improvements are immediately apparent. Take care to use with power hungry amplifiers. (I am not sure about this currently Note: 2005)
18- CD Surface Treatments; There is several kinds of CD surface treatments in the market. They shine the surface of CD, thus laser picks up more information. What can be expected from a surface treatment is the high frequencies are cleaner and more extended. The easiest and the cheapest method of CD surface treatment is the one that used by pipe lovers .That is the human oil on the skin of face.
I apologize for that ugly tweak but our systems are personal and private anyway don't they. Human oil has the perfect thin viscosity and can be absorbed by CD surface very easily and effectively. Listen your CD first, smear the CD throughout your forehead and spread the oil with your finger and listen it again.
Don't forget to spread the oil by your finger every time prior to listen that CD.
19- Objective of the Third Dimension; the objective of a stereo system is to achieve 3.rd dimension via two channels. All the hi-end or hi-fi equipments have own character, timbre and tonality. For instance a titanium tweeter will have different tonality then a silk dome tweeter. Two different brands of loudspeakers will have different tonalities as if they use the same drive units. The tonality of high end equipment mostly depends on the listening preferences of the designer. We will most probably not like if hear different tonalities from our own equipments even though the other system sounds much better. This case is so often faced; most of the audiophiles don't like the sound of somebody else's system despite it is a better system. This case is also evident when buying or testing new equipment at homes. We sometimes test better equipment at home but feel something is still missing compared to our own equipment.
I remember very well, when Sony introduced the first 20 Bits CD player, most of the people found the sound harsh, edgy and coloured. People used to listen dark sounding CD players up to that time and hearing more inner details disturbed them.
I also remember very well that when I modified my old B&W 801 Matrix II monitor speakers and cancelled their protection units, the new sound had disturbed me a lot. I was such unhappy by the new sound and could not have listened at my system for several days. At that time, the manufacturer expressed that "the protection units were needed due to the speakers were designed mainly for recording studios". They also told to me that the new sound must be clearly better due to the crossover resistance that affects especially the lower mid and upper bass was lowered fairly. After several days of listening them, the sound became better and better. Eventually the sound was surprisingly perfect after few weeks. Actually the sound was the same but perception was changing. (My brain reference was changing)
If this is the often case, how do we distinguish the better unit by listening! There are several ways of it but for me the main method is third dimension capability. This is not the only case for sure but generally speaking, if two units are compared, the better one is the one delivers bigger soundstage, more dept and more height.
This is also the theory of Peter Quodrup from Audio Note UK and I am hundred percent agreed with him.
The distortion of an electronic device is does not effect the tonality of the equipment but mainly effects the inner details. Soundstage dept and height are such hidden factors in inner details that they will be affected first. If the unit provide lower distortion, more precise soundstage, especially more dept will be provided.
20- The Least Powerful Ring of a Chain; Hi-Fi is a kind of chain. Strength of a chain depends on the least powerful ring. Assume a water hose consists of variety of wideness. Derived water capacity will be in accordance with the thinner part.
A system should consist of similar level of equipments. If you add the best CD transport to a standard level of system, there will be some changes but not as expected. Also a poor digital cable will compress the entire sound quality of a very good system.
A long term plan should be prepared before setting up a system and the pieces should be purchased in time. Hurried purchases may come as replacement expense within one or two years.
21- Don't Immediately Judge a Unit, Give a Chance; every system can sound well in time. System synergy is a kind of time dependent factor that sometimes takes months, even years. Sometimes we make quick decisions and quick prejudices for good products and immediately make unfair observations. According to me, the main element of the hi-end chain is the loudspeaker. If tonality and characteristics of the speaker is generally fine, or if the overall tonality of the entire system is generally fine, the system can be carried up for several further steps by playing with cables, tweaks, locations, tubes etc.
22- Critical Adjustments should be done by Listening Symphonic Music or Chorus Music. Once we decided about the main components of our system, we play with cables, tubes, tweaks and other accessories till finding the desired tonality. Adjusting the tonal balance of a system by listening single instruments or jazz trios may mislead us.
Upper mid and the treble bands of a sound is easily disappeared if somebody is far away from the original signal. This is the case, if we listen at a live concert or listen at a hi-end system. If this is the case, such instruments like saxophone, guitar, violin, even a human voice are darker and distant if we listen at a very good live record. Whenever we increase mid/treble band of the system by tweaks, such instruments became more open, detailed and dynamic. But one thing should be in mind that we may add a subtle amount of coloration to sound unconsciously. If a system is trimmed by listening small trios or single instruments, singe voices, this risk is really big. Such a system may not play a classical music performed by a big orchestra. If such symphonic music is listened, the system may reveal harshness and brightness.
Best regards with lots of music...
Ozhan Atalay
President
NonameHifi High End Audio Pages
January 2004
http://www.audiophile.org
Free High End Audio Classifieds
nonamehifi is offline
post #2 of 66 Old 08-12-2008, 12:35 PM
Zaluss's Avatar
Human skin oil? Hmm..
Zaluss is offline
post #3 of 66 Old 08-12-2008, 12:49 PM
gandalfthewhite's Avatar
Pretty much given when the topic is "22 tips for ".
gandalfthewhite is offline
post #4 of 66 Old 08-12-2008, 01:09 PM
Easyaspie's Avatar
That is weird. I always thought you needed to clean smudges off of the CDs. Now this guy intentionally puts zit juice on them?
Seriously though, I've heard of surface treatments, not sure why they would work, but skin oil?
Easyaspie is offline
post #5 of 66 Old 08-12-2008, 01:46 PM
Ratman's Avatar
Quoted: 1289 Post(s)
Liked: 1028
Originally Posted by Easyaspie View Post
Now this guy intentionally puts zit juice on them? .... but skin oil?
I can think of a few other "slick" recommendations that would be even more disgusting and less "scientific". Hopefully... no one tried this.
Ratman is online now
post #6 of 66 Old 08-12-2008, 01:54 PM
ccotenj's Avatar
Liked: 101
the sad part is that he's got a few things right... but the others are off in la-la land somewhere...
- chris
ccotenj is offline
post #7 of 66 Old 08-12-2008, 01:56 PM
Leadsalad's Avatar
Most of this list seems pretty hocus pocus though. Why would you lubricate a CD? They spin slowly when reading music from them, 1-2x, so the laser isn't really going to miss any of the 0s and 1s unless you've put a significant scratch on the substrate top surface where the label is or a nice gouge in the plastic the laser reads through and thus distorting its path. You'd have tons of problems with computers if this was the case since they read at 32-52x speed.
1. Hmm, this should just be "Critical listening should be done in an acoustically sealed room." However I will admit I don't really have a bunch of free time to just sit and listen to music. It feels weird to do nothing but focus on a piece of music to me, I need to multitask and music ends up being my background noise.
9. Aren't most electronics already grounded by the simple act of pluging them in? I work on my PC with the hard switch on the PSU off but the plug still in so the chassis is grounded.
13. Does any end result electronic actually run off of AC voltage? They convert to DC before using the power so I don't understand how small variances will ever see your end electronics unless the power supply is hideous quality.
15. Cables don't warm up (if they did then you have a real problem as you'd have a very obvious source of resistance and a fire hazard), and a speaker breaks in <1 second after the cone moves for the first time and then when you turn it off it settles back down.
16. This generalization is a bit much, speakers are a personal thing and you can't categorically say that a bigger speaker is more inappropriate for something than a smaller speaker. Sure, I'm not going to listen to my music in my room on a PA system (that's just the wrong speaker for the job because of their separate purposes).
Leadsalad is offline
post #8 of 66 Old 08-12-2008, 02:03 PM
Korleone's Avatar
Interesting read, and it does have some good tips (others seem like snake oil, or should I say human face oil)... But it's kind of a difficult read with all the typos. I figure English isn't your native tongue so we'll have to give you some credit, but this could really use a little clean up.
Korleone is offline
post #9 of 66 Old 08-12-2008, 02:39 PM
Ratman's Avatar
Liked: 1028
Originally Posted by Korleone View Post
... this could really use a little clean up.
LOL... yeah, a shovel and Proactiv skin care products.
post #10 of 66 Old 08-12-2008, 03:01 PM
WallyWest's Avatar
Not really. If it's a two prong plug then no, you've got no ground. But he's talking about static electricity and I doubt that HT gear is going to be damaged by that. Grounding is designed to keep you from being electrocuted if something shorts inside the device. You usually only see it on high power amps. My subwoofer amp is the only device in my whole system that has a ground plug.
You'd be surprised how many power supplies are hideous. It's a popular thing to skimp on since most people have no clue what it does. But even then small issues in the AC source won't make a bit of difference, it has to be really bad.
These lists are always amusing. You go along nodding your head at a few things and then BAM, what the @$*%??? lol
WallyWest is offline
post #11 of 66 Old 08-12-2008, 04:36 PM
dknightd's Avatar
Before I bother to respond, is this something you wrote, or, is it something you copied and pasted from someplace else?
Everything I say here is my opinion. It is not my employers opinion, it is not my wife's opinion, it is not my neighbors opinion, it is My Opinion.
dknightd is offline
post #12 of 66 Old 08-12-2008, 04:43 PM
Ratman's Avatar
Liked: 1028
post #13 of 66 Old 08-12-2008, 05:07 PM
speco2003's Avatar
Not completely correct. If it was a 3 prong plug and you broke off or defeated the ground then your screwed. If it was gear designed to be used with a 2 prong polarized plug then it is grounded.
http://www.newton.dep.anl.gov/askasc...9/eng99158.htm
speco2003 is offline
post #14 of 66 Old 08-12-2008, 05:37 PM
Leadsalad's Avatar
After I posted I began to think about this in more detail. I remembered a certain distinction from my AC - DC classes and that some 2 prongs were grounded regardless of missing the 3rd separate grounding prong. My computer PSU is 3 prong, my AV stuff is 2 prong polarized, and my iron is 2 prong non polarized. I wasn't 100% sure when I posted, thanks for clearing it up.
post #15 of 66 Old 08-12-2008, 05:49 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 816
I guess he didn't try love juice or KY Personal for lubing his CD's.
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #16 of 66 Old 08-12-2008, 06:24 PM
ccotenj's Avatar
Liked: 101
probably would give him a much smoother response on the high end...
- chris
ccotenj is offline
post #17 of 66 Old 08-12-2008, 08:29 PM
WallyWest's Avatar
Yeah, the terminology is confusing.
Neutral is considered a grounded conductor because, well, it is. But it's called neutral because grounded wire vs. grounding wire is a little too confusing even if you know which is which. Neutral is the return path for the circuit. It can be a safety ground for low power things like your article states. But if a high power appliance shorts out that won't cut it. You touch the chassis and present a nice short path to ground and get hit with the full 120v. Ouch. Which is where the grounding wire (third prong) comes in. It present a low impedance alternate path straight to earth/ground. Which makes it virtually impossible to electrocute yourself even if the appliance shorts out.
I wouldn't consider something grounded unless it's connected to the grounding wire.
post #18 of 66 Old 08-12-2008, 08:54 PM
LessisNevermore's Avatar
Slick solution.
LessisNevermore is offline
post #19 of 66 Old 08-18-2008, 12:50 PM - Thread Starter
nonamehifi's Avatar
Thank you guys
I am here to answer to questions if some of above points are not clear
regards
OA
post #20 of 66 Old 08-18-2008, 01:31 PM
shumi_9's Avatar
Quoted: 12 Post(s)
nonamehifi,
interesting thread indeed. I would be interested in your opinion re. the process I use to optimize speaker performance. I have used this process on the Dunlavy SCIVa speakers I own which, as you probably know, are very accurate, but difficult to place. I use TRUERTA as the software package. I place a dedicated Behr EMC8000 microphone powered by the M-Audio Mobile Pre in my seating location (which was already identified as best compromise). I then proceed to place one of the speakers while monitoring 1/6 Oct response for as flat of a response as possible from 20hz-20Khz. For the Dunlavys, it is recommended that the speakers be spread aggressively without jeoperdizing focus.Once the first speaker is placed, I place the second speaker symmetrically in the other corner.While monitoring 1/6 Oct in the 1000hz-20,000hz, I then tweak the position of only one speaker to maximize in-phase output as shown on the TrueRTA freq. response. I find that this gets pretty darn close. Finally, I will listen to an excellent female vocalist to validate imaging. Usually, this requires slight tapping of one speaker to gel everyting together.It still amazes me how small tweaks of less than 1/8" can make an audioble difference.
shumi_9 is offline
post #21 of 66 Old 08-18-2008, 02:53 PM - Thread Starter
nonamehifi's Avatar
I listened few Dunlavy SC-IVs but not SC-IVAa. What do I remember is SC4A has lower bass goes down to 20 Hz compared to its predecessor. This means that it will need bigger room and far placement from the back wall (wall behind the speakers) to reduce bass boom. I hope your room is bigger than 40 m2.
I don't remember which software we used but we also passed the similar test you made at my listening room and result was astonishing. My Avantgarde Uno speakers have active crossover adjustment possibility, so we adjusted trims properly according to tests.
I guess you will do this by changing the speaker placement from the back wall and trying to find out the best listening seat location according to your mic/signal tests
Best regards
http://www.nonamehifi.com/ContentDet...&ID=3679&arc=0
post #22 of 66 Old 08-18-2008, 06:01 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
What a waste of time.
WilliamZX11 is offline
post #23 of 66 Old 08-18-2008, 08:15 PM
shumi_9's Avatar
Quoted: 12 Post(s)
Yes, you are right the SCIVa are rated lower for bass response. In order to get down to 20Hz you must strike a compromise between boominess and corner loading....
shumi_9 is offline
post #24 of 66 Old 08-19-2008, 06:39 PM
DougWinsor's Avatar
In that list of 22 tips I see a lot of typical snake oil.
DougWinsor is offline
post #25 of 66 Old 08-19-2008, 07:41 PM
speco2003's Avatar
For someone who claims to know so much his room is sure not setup for great sound. Hardwood, glass, etc.
post #26 of 66 Old 08-20-2008, 07:41 AM
Rutgar's Avatar
The one about the skin oil really bothers me. I take great care to not get fingerprints or smudges on my CD's and DVD's. Same as I have done with LP's many years ago.
Rutgar is offline
post #27 of 66 Old 08-20-2008, 10:29 AM
lwien's Avatar
Skin oil? Of course there's no mention of all the grit, grime, dead skin cells, salt and other stuff that may be floating around in that oil that could muck up your CD's.
Ah hell, I'll just rub my cd's on my ballsack after a hard workout at the gym. Just gotta make sure that it's Alicia Keys and not 50 Cent.
lwien is offline
post #28 of 66 Old 08-20-2008, 11:51 AM
sdurani's Avatar
Quoted: 4484 Post(s)
Liked: 2904
Dude, you owe me a keyboard. Sprayed hot tea all over mine after reading your post.
Sanjay
Sanjay
sdurani is online now
post #29 of 66 Old 08-20-2008, 11:55 AM
ccotenj's Avatar
Liked: 101
gee, THAT was a great visual right after lunch...
could build an *interesting* marketing campaign around it though...
- chris
ccotenj is offline
post #30 of 66 Old 08-20-2008, 12:44 PM
rynberg's Avatar
Wow...so you show up on our website to promote yourself and your own website...and do so by spouting a bunch of ridiculous nonsense. Jeesh.
Thanks Chu and lwien for making this thread worthwhile.
rynberg is offline
