Sound Card and Receiver question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-28-2008, 09:07 PM - Thread Starter
tc2007's Avatar
Hi
I just bought a Asus Xonar DX sound card (my mobo only has PCI-E 1X open no PCI).
My question is: Do I still need a dedicated receiver like an Onkyo etc, to hook up 5.1 speakers (not PC Speakers but real ones )
OR
Can I just use a decent amplifier?
I think the receiver will make the sound card an overkill.
Any suggestions will be highly appreciated.
tc2007 is offline
post #2 of 3 Old 09-29-2008, 02:50 PM
jwatte's Avatar
If you run analog multi-channel cables (a "snake") from the card analog outs to the receiver, then you just need a good multi-channel amp (and speakers).
If you run digital out (Dolby Digital Out) then you still need a receiver that can decode Dolby Digital.
jwatte is offline
post #3 of 3 Old 09-29-2008, 05:24 PM - Thread Starter
tc2007's Avatar
If I run the Digital Out and let the Receiver decode it, then what is the point of an expensive card? Can I just use one of these?
Ebay Id: 180294893604 (sorry cannot post url)
Thanks for the reply.
tc2007 is offline
