7.1 analog audio set up question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 11-30-2008, 06:34 PM - Thread Starter
Ssoto0055's Avatar
Picked up a blu ray player over the weekend which has the 7.1 analog audio outputs. Since my receiver is a few years old without HDMI and now is not the right time to upgrade receivers setting it up analog to get Dobly True HD and DTS MA is my only option right now. I'll keep the optical cable on for the regular DTS and DD audio, but for the HD audio I figure it's how I'll get it since my receiver has 6 channel input jacks. Now my question is do I need to buy 6 individual coax cables, or will some of my older cables that were composite and 2 channel mono cables? I know the cables I have carry analog and not digital signals like the coax cable may but the outputs are analog so I don't know. Thanks for the help guys.
Ssoto0055 is offline
post #2 of 16 Old 11-30-2008, 07:11 PM
Kal Rubinson's Avatar
Quoted: 685 Post(s)
Liked: 468
They should be fine. If not, you will know. ;-)
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 16 Old 08-09-2009, 02:58 PM
Mr. Met's Avatar
i have the same question, but your answer was so brief...
what type of audio cables should one use from a blu-ray player (LG 390) to an older non-HDMI receiver (yamaha 5660) that has analog audio inputs? regular old-fashioned red/white audio cables??
thanks much...
Mr. Met is offline
post #4 of 16 Old 08-09-2009, 04:18 PM
bluesky636's Avatar
Why are you keeping the optical cable for legacy DD and DTS? The player will decode those signals and pass them via the analog outputs as well. Plus it is one less cable junking up your equipment.
thanks much...
Yes, any sort of analog cable will work. Use what you have or treat yourself and buy some new ones. Go to
http://www.monoprice.com/
if you are cheap, or for a few extra bucks,
http://www.bluejeanscable.com/.
I buy all my cables from Blue Jeans Cable now.
bluesky636 is offline
post #5 of 16 Old 08-09-2009, 04:46 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Yes, it will, but perhaps his receiver has better digital processing tools for bass management and EQ. That's why I use analog for lossless and S/PDIF for legacy digital.
BIslander is offline
post #6 of 16 Old 08-09-2009, 06:39 PM
bluesky636's Avatar
That may be true but what is the impact on the listening experience between lossy and lossless? Do you really think legacy would sound worse through the multichannel analog outputs?
By the way, I have my system set up so that the HDMI output of my BD player handles all data (bitstream) for BD and DVD playback, but I use the optical output of the BD player for CD playback as it allows me to adjust the input trim for the optical input differently from the HDMI input to optimize Audyssey Dynamic EQ performance.
post #7 of 16 Old 08-09-2009, 08:22 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
It depends on your room and equipment. It turns out that I'm fine with analog or digital for most legacy sources on my equipment in my room.
But, I really appreciate having the digital connection for stereo sources, which allows me to apply PLII in my receiver. For most people with 7.1 systems, the digital path for legacy encodes is the only way to get audio to their rear speakers.
Yep. The extra cable and transmission path give you added options to fine tune your audio outputs.
post #8 of 16 Old 08-09-2009, 08:25 PM
Quoted: 685 Post(s)
Liked: 468
thanks much...
Yes. The color is not important.
Kal Rubinson
post #9 of 16 Old 08-09-2009, 08:46 PM
sdurani's Avatar
Quoted: 4540 Post(s)
Liked: 2948
If the analogue connections prevent you from applying room correction and other useful processing, then legacy will sound worse. Given the choice, would you rather listen to lossless using your player's crossovers and no room correction or listen to legacy lossy using your receiver's bass management and room EQ?
Sanjay
sdurani is offline
post #10 of 16 Old 08-09-2009, 11:08 PM
bluesky636's Avatar
I assumed the OPs AVR did not support any sort of room correction, given its age and lack of HDMI capability. Not all AVRs do (Rotel for instance does not. Not even the latest models do.). Not all older AVRs have sophisticated bass management capabilities either. Maybe that was a bad assumption, I don't know. But if it wasn't, the question is valid. Why would legacy sound worse through multichannel analog then through a digital connection?
post #11 of 16 Old 08-09-2009, 11:54 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
I assumed the OPs AVR did not support any sort of room correction, given its age and lack of HDMI capability. Maybe that was a bad assumption, I don't know.
Yes, a bad assumption, although it may be true. I have a receiver that fits the OP's description - a few years old without HDMI - but it features room correction.
Perhaps not sophisticated, but variable crossovers are quite common. And, that alone can make a difference.
The bottom line here: there are lots of good reasons to use a digital connection for non-lossless playback. The tone of your initial question made it sound like the OP had no good reason for considering such an approach.
post #12 of 16 Old 08-10-2009, 08:06 AM
sdurani's Avatar
Liked: 2948
If we dismiss room correction, then there is still the likelihood that the receiver's bass management and time alignment have greater flexibility and finer degrees of adjustment compared to the player. This would allow the user to better fit the crossovers to his speakers' capabilities and dial in speaker distances for a more cohesive soundfield.
OK, if we now dismiss differences in bass management and time alignment, then there's still D-to-A conversion and analogue signal path. Chances are that those are better on receivers than the typical player. Sending the signal via analogue cables means that, no matter how good the DACs and analogue stage your receiver are, you're ultimately listening to the DACs and analogue stage of the player (not to mention sending the signal through two sets of analogue circuitry).
Each one of these features alone may not make much difference. But taken cumulatively (bass management, time alignment, D/A conversion, analogue stage, room correction) the improvements can add up when letting the receiver handle the raw digital signal instead of the player.
Sanjay
sdurani is offline
post #13 of 16 Old 08-10-2009, 06:25 PM
bluesky636's Avatar
Sorry guys. I'm just not convinced that there would be that significant a difference. Guess its just the stubborn Polack in me.
post #14 of 16 Old 08-11-2009, 09:47 PM
Mr. Met's Avatar
you guys are waaaaaay ahead of me, so excuse the remedial question:
if i hook up both optical and 5.1 analog from LG BluRay player to yamaha receiver, do i have to specify in the player which output to use? or are both outputted by default? thanx...
Mr. Met is offline
post #15 of 16 Old 08-11-2009, 10:28 PM
sivadselim's Avatar
Quoted: 163 Post(s)
Liked: 154
Most average BD players have very poor bass and time management capabilities. Their analog outputs are usually not much more than an afterthought. And most AVR's multichannel analog inputs cannot be bass and time managed, nor EQ'd (if applicable). Nor can any other additional processing be applied to the analog inputs. For a 7.1 setup and a receiver with only 6-channel analog inputs (as opposed to 8), the ability to apply a further DSP (i.e. DPLIIx) is a necessity if one wants to achieve 7.1 sound. Given the choice, I would bitstream DD and DTS to the AVR every time in this instance. The AVR is going to be more versatile and more flexible. And will probably deliver higher quality.
Which begs the question, OP, how are you going to get 7.1 audio when using your receiver's 6-channel analog inputs?
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #16 of 16 Old 08-11-2009, 10:29 PM
sivadselim's Avatar
Quoted: 163 Post(s)
Liked: 154
You'll have to fiddle around. Most likely they are both output simultaneously.
