Whats better 12awg or 14awg wire? - AVS Forum | Home Theater Discussions And Reviews
Old 12-03-2008, 02:18 PM - Thread Starter
ducatigsx88's Avatar
what speaker wire is better 12 gauge or 14 gauge and does this look like a good sub wire replacement http://www.monoprice.com/products/pr...eq=1&format=2?
ducatigsx88 is offline
Old 12-03-2008, 02:28 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Neither, for runs of less than a few dozen feet.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
Old 12-03-2008, 02:31 PM - Thread Starter
ya its gonna be run at least 20ft or more...and idk if that sub cable is the right kind to buy either
Old 12-03-2008, 03:09 PM
Ratman's Avatar
Quoted: 1290 Post(s)
Liked: 1030
Sub cable is fine. 14AWG is fine.
Ratman is offline
Old 12-04-2008, 10:23 AM
ChrisWiggles's Avatar
12 gauge. Bigger is better. But how far are you going, what are you powering? You may not need it.
ChrisWiggles is offline
Old 12-04-2008, 11:42 AM
Ratman's Avatar
Liked: 1030
@ 20 - 30' 14 AWG is adequate. I'd assume he's powering speakers.
Bigger may be "better", but not always necessary.
Ratman is offline
Old 12-06-2008, 10:02 PM
Agree. Thus what he's powering, and that was intended about the speaker impedance. The two main variables are distance, and the impedance you're driving. Really low impedance, or long distance and you need a very large gauge wire, which is why in very large distributed audio systems it's usually a constant voltage system with transformers at each speaker since it's way more efficient that way and you're not forced to run absurdly large gauge wire everywhere.
Old 12-06-2008, 11:15 PM
RXPorlando's Avatar
You should notice right away if it's quality wire wheather it's 14-12 gauge.
It should have more strans witch in turn are softer and much thinner then cheap stuff.
This provides a lower resisistents and thats what your paying for. In return your amp won't work as hard resulting in a cooler running amp
RXPorlando is offline
Old 12-06-2008, 11:49 PM
jarrod1937's Avatar
Quoted: 95 Post(s)
Liked: 42
As far as i know, strands only assist in flexibility.
jarrod1937 is offline
Old 12-07-2008, 05:16 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Totally agreed. Wire gauge is based on the cross sectional area of copper. Conductivity is based on the same.
Contrary to popular belief, stranding does not have much to do with the ability of wire to handle high frequencies. And, high frequency signal handling such as it may be affected by wire, is not an issue in the lengths of cable commonly used in home audio systems, or even within a house.
arnyk is offline
Old 12-07-2008, 05:17 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Agreed, and by implication resistance to breaking. However, cable breakage is primarily determined by how strain is relieved at bending points.
arnyk is offline
Old 12-07-2008, 06:34 AM
Ratman's Avatar
Liked: 1030
Yup. And typically, most home speakers are rated at 8 Ohms. Most receivers/amps are rated to drive 8 Ohms (or 6 Ohms based on how the manufacturer wants to enhance their specs). The impedance rating is an "average" and not a constant. Impedance can/does change depending on the the driven signal(s).
Ratman is offline
