Audio problems with HDMI cable? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 12-16-2008, 12:39 AM - Thread Starter
Landmonster's Avatar
Quoted: 52 Post(s)
I recently ordered two new HDMI 1.3a cables, from Monoprice.com
I've connected these cables to my Playstation 3 and to my digital HDTV cable box, and I'm connecting these devices to my new Toshiba 1080p 120hz HDTV. The video seems OK (since these are the first HDMI cables I've tried), but the audio playback is sketchy.
Whenever these cables are attached, I get these "buzzing" sounds during music, and speech. I've played with all the settings that I can see from the menu in my TV, and nothing seems to make it better. This occurs on both the Playstation 3, and for HD cable, using HDMI inputs #1, and #2 respectively.
Previously, I had the HD cable box and Playstation 3 hooked up with red and white RCA cables, and the audio quality seemed fine.
Does this indicate a problem with my TV, or the cables?
Here are the cables I ordered: "High Speed HDMI 1.3a Category 2 Certified Silver-Plated Copper CL2 Rated (For In-Wall Installation) Cable (24AWG) - 6ft (Gold Plated Connectors)"
This is my TV: "Toshiba 52XV54OU"
I would post links, but the site won't let me.
Landmonster is offline
post #2 of 5 Old 12-16-2008, 04:53 PM
gooki's Avatar
Could be either, most likely the TV if it's a buzzing sound, but trying another HDMI cable to eliminate that as the cause is the easier.
International HDDVD Screenshot Archive (Full 1080p Images): www.hdmovies.co.nz
gooki is offline
post #3 of 5 Old 12-16-2008, 08:28 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Cable boxes are notorious for causing sound problems with HDMI. I wound up connecting my Motorola HD box with component cables, and it eliminated the sound issues, and the PQ is the same.
jdcrox is offline
post #4 of 5 Old 12-16-2008, 09:22 PM
Espo77's Avatar
Quoted: 179 Post(s)
Liked: 84
Component cables are used for video.....
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #5 of 5 Old 12-16-2008, 11:56 PM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Point being, that by using component cables for my video, I did not have an HDMI cable hooked up, hence I did not have the static/sound problems mentioned.
jdcrox is offline
