Hardwood flooring for audio room: glue-down or "floating" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 12-20-2008, 11:37 AM - Thread Starter
aletha's Avatar
I am planning on getting hardwood flooring installed (over concrete) in my audio room. I have two choices of installation: "glue down" or "floating". Do you think the "floating" method would result in vibrations from the bass? The "floating" method is significantly cheaper than the "glue down".
Yes, I know, carpeting may be better than hardwood for audio, but I will be putting in additional treatment such as rugs, etc.
aletha is offline
post #2 of 12 Old 12-20-2008, 04:44 PM
AV Doogie's Avatar
Quoted: 12 Post(s)
Probably will not make much difference. The floating floors provide a great deal of mass along with tight interconnections. You will have bigger problems with the reflections off of the floor if you don't add rugs etc.
My Home Theater Site:
DJ-Theater
AV Doogie is offline
post #3 of 12 Old 12-21-2008, 05:58 PM
soundlovr's Avatar
My personal preference with hardwood on concrete is to glue down 6mm cork underlay. It's not that expensive and eliminates sound transmission of any sort to the concrete. The people under you will be thankful. I would glue down the hardwood as well, but there's really not much difference compared to letting it float. Acoustically, the glue is your better option.
soundlovr is offline
post #4 of 12 Old 12-26-2008, 07:56 PM
hmmm5's Avatar
of course depending on where your audio room there are other important considerations that come into play that have little to do with audio performance. for example if below grade than you'd be remiss to not go with floating (and put a thick mil of plastic down underneath the cork/sound barrier/etc.), but that's talk for a different forum i'm sure...
hmmm5 is offline
post #5 of 12 Old 05-17-2011, 04:10 AM
dbx123's Avatar
Originally Posted by amyehayes3 View Post
you should definitely glue it down to decrease vibrations in hardwood flooring.
I think he already made his decision.....3yrs ago
But...welcome!
dbx123 is offline
post #6 of 12 Old 05-17-2011, 05:13 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Originally Posted by hmmm5 View Post
of course depending on where your audio room there are other important considerations that come into play that have little to do with audio performance. for example if below grade than you'd be remiss to not go with floating (and put a thick mil of plastic down underneath the cork/sound barrier/etc.), but that's talk for a different forum I'm sure...
Based on my experience with a floating floor we installed in a bedroom several years back, claims of non-resonance based on the mass and interconnectedness of the surface ring true. This floor was laid over an existing highly damaged oak floor with no resilient interface, so it is probably a worst case implementation.
I wouldn't put much hope in attenuation of vibration being transmitted through the floor even if a resilient interface were used. Studio floors with that feature achieve it by vastly different means.
Floating floors attenuate well, but only above their resonant frequency. Getting a floor suspended so that its resonant frequency is at a sufficiently low frequency takes a lot of mass and a very soft suspension. The foam sheeting used for this purpose with so-called floating flooring is IME way too stiff given the minimal mass that each square foot of it suspends.
arnyk is offline
post #7 of 12 Old 05-17-2011, 12:57 PM
dbx123's Avatar
Ahem...and beside this thread being 3yrs old....you usually choose the "type" of flooring based on your substrate's properties, not on your speakers . But that's a whole different subject . A floating floor is essential when movement from moisture is inevitable...and flooring in a basement is usually a situation where this is necessary.
dbx123 is offline
post #8 of 12 Old 05-19-2011, 06:58 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
That's a very good point(s) there Arnyk. Many just leave the floor connected to the slab so as not to introduce a compressible layer and the inherent resonance that comes from that. Avoids opening a can of worms.
__________________
Ted
The Soundproofing Company
Ted White is offline
post #9 of 12 Old 05-22-2011, 07:10 PM
sebberry's Avatar
Quoted: 28 Post(s)
Liked: 31
Are you suggesting that using some sort of "quiet step" underlay between the hardwood floor and subfloor can make things worse?
sebberry is offline
post #10 of 12 Old 05-23-2011, 06:37 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Resonance is introduced when you have to mass layers with a compressible element between them. Could be a common air cavity, or a rubber layer. Either will compress and therefore have a corresponding Mass-Spring_Mass resonance introduced.
This is a helpful necessary evil with footfall noise on wood floors. Less value on a slab
__________________
Ted
post #11 of 12 Old 05-23-2011, 08:15 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
Not at all.
I'm just saying that when people are serious about reducing the sound transmission by a floor, they introduce something that is very massy and compliant such as a slab that is suspended.
arnyk is offline
post #12 of 12 Old 05-24-2011, 03:59 AM
Elill's Avatar
Quoted: 109 Post(s)
Liked: 91
Forget all that, timber floors are rotten for acoustics.....unless you can add a lot of treatments to all other surfaces. I have a live living room with hard surfaces everywhere (floor, walls, open plan kitchen, light weight blinds), fixing it is going to be hard/impossible....and we've got lots of big absorptive sofas and a rug.....still doesn't remove the echo.......just something to keep in mind.
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
