Cabling software, does it exist? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 03-17-2009, 08:36 AM - Thread Starter
Double-UA's Avatar
Dear AVS members,
I have a question with regards to connecting my newly bought Pioneer equipment.
Is there a software available that allows you to pick all your components and it will automatically generate a cabling diagram for you?
Thanks a lot for your help and tips!
Best regards, Werner
Double-UA is offline
post #2 of 2 Old 03-17-2009, 08:45 AM
penngray's Avatar
Liked: 47
No and there really shouldn't be since its not extremely difficult to connect all components together.
Every component has its own manual and it will have pictures to help you.
Sorry if that sounds too difficult but there are only so many ways to connect this stuff.
penngray is offline
