XTZ room analyzer results, good or bad? - AVS Forum | Home Theater Discussions And Reviews
Old 09-24-2009, 07:52 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
I've been playing with the new XTZ program in Vista. These are my results. I'm using a SMS-1 in my system. I've ordered a AS-EQ1 but I'm wondering if it will be beneficial to my room. I have the sub, a Genelec 7073a, a bit hot.
I need to figure out how to link the waterfall plots, they're too large to upload here.
RT 60
125Hz .26s
250 .35
500 .29
1000 .26
2000 .31
4000 .27
I'm a total noobie to these measurements. How should they be interpreted and improved??
Room sub minus 12 [RTA].txt 0.39453125k . file
File Type: txt Room sub minus 12 [RTA].txt (404 Bytes, 34 views)
DaveN is offline
Old 09-24-2009, 08:16 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
RT 60
125Hz .26s
250 .35
500 .29
1000 .26
2000 .31
4000 .27
Save them in a form that will let you resize them.
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
Old 09-26-2009, 08:22 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
I manages to get one file converted. The real waterfall images are .frp extensions and I can't figure out which Mac program to manipulate them with.
Does this give enough data? The 3D waterfall show very slow decays at all frequencies.
DaveN is offline
Old 09-26-2009, 10:46 PM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 710
Use the File-->Export Screen Dump command to put the window onto the clipboard as a bitmap, then you paste it into various photo programs to crop and resample.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is online now
Old 09-28-2009, 05:10 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
I re-sized this image. When I work with the 3D screen dump it shows the curve but does not display the bottom 1/3 of screen waterfall.
Would I benefit greatly from equalization?
DaveN is offline
Old 09-28-2009, 08:07 PM
Quoted: 678 Post(s)
Liked: 461
The large waterfall shows a significant mode at 21Hz and some harmonics of it. You need something to deal with it.
Kal Rubinson
Old 09-28-2009, 08:23 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
Would a Neptune or Audyssey unit do the trick?
DaveN is offline
Old 09-28-2009, 08:26 PM
Quoted: 678 Post(s)
Liked: 461
Probably but if this is for a sub only, you can do it with a sub-only EQ.
Kal Rubinson
Old 09-29-2009, 04:17 AM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
I'll try to get another set of measurements with the SMS-1 set to flat tonight. I wonder if the SMS-1 is exaggerating the problem.
I have an SV-AQ1 on order and I had been intending to try it vs. the SMS-1. Reading all of the threads on EQ products and your columns in Stereophile, I am a longtime subscriber, got me thinking about various full range eq products to improve my system vs sub-only equalization.
DaveN is offline
Old 09-29-2009, 09:32 AM
fsrenduro's Avatar
Quoted: 33 Post(s)
Have you tried using the XTZ (with the SMS running flat) to give you rooms modes and recommended EQ stimuli? Plug those numbers into your SMS (rather than doing it by eye) and see how that reads on the XTZ. Cutting a 21hz peak with the SMS should be pretty simple but I don't know what filters you're already using when you took this XTZ measurement.
don't insult my intelligents
fsrenduro is offline
Old 09-29-2009, 11:40 AM
Quoted: 678 Post(s)
Liked: 461
Now, why didn't I say that? Great idea.
Kal Rubinson
Old 09-29-2009, 05:11 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
Here is the SMS flat plus using the suggested 22Hz filter plus a 120Hz 2.5boost 4.3 q trying to flatten upper end.
I will try for some waterfalls. Comments??
DaveN is offline
Old 09-29-2009, 05:23 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
My 3D waterfall screen dump reverts to 2D when I photoshop.
DaveN is offline
Old 09-29-2009, 05:43 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
Ful, range measurements with XTZ
DaveN is offline
Old 09-29-2009, 10:33 PM
fsrenduro's Avatar
Quoted: 33 Post(s)
hat frequency are you crossing over to your sub? Unless it is above 120hz I wouldn't bother trying to boost that high, what's the point.
You can always run XTZ again with the SMS set the way it is and see if it'll suggest any other EQing.
Depending on your crossover point you could try cutting those small peaks at 50hz and 75hz. Maybe just the one at 75hz could smooth it out if you mess with the Q. I'd say if you got that a little more in line you could also raise your overall sub level a little too, maybe 3-4 db.
Old 10-01-2009, 02:36 PM - Thread Starter
DaveN's Avatar
Quoted: 68 Post(s)
I was crossing over at 40Hz but I changed to 80Hz and tried the XZT suggested filters. I also exp erimented with phase perfect, Butterworth, and Linkwietz-Riley slopes. Butterworth had a very negative effect with similar curves using the other 2 Xovers. I played with it last night and the sound was better. I plan more listening and measuring over the next few days. I will try lowering the Xover to 63Hz and see what it does.
So far I am inpressed by the improvement that the XTZ made with my SMS-1. I'm very curious what a full range equalization implementation would do for my system.
DaveN is offline
Old 11-04-2013, 02:51 PM
Phillips751's Avatar
Hi for any one that is using the XTZ Room Analyzer with a Velodyne Digital Drive Sub or SMS-1 please follow these guidelines, works every time for me.
Whatever the XTZ Room Analyzer suggestions for PEQ, simply just halve the Q e.g. 35hz Q 8.0 Gain -5.0, enter 35hz Q 4.0 Gain - 5.0 into the Velodyne PEQ and this will be correct.
Also any manual alterations on the XTZ do the same.
Phillips751 is offline
