Music too low....Sound effects too high - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 11-05-2009, 08:38 AM - Thread Starter
turismo8889's Avatar
I've got JBL speakers and a pioneer receiver with Auto EQ the I've had setup for a year now. It has always bothered me that the music volume is always a little low, but during an action scene the sound effects are ear blistering loud.
Is it possible to increase the volume of music, while keeping speech constant and lowering sound effects volume.
Chris
turismo8889 is offline
post #2 of 12 Old 11-05-2009, 08:56 AM
Ratman's Avatar
Quoted: 1290 Post(s)
Liked: 1030
How many speakers (two, three, surrounds)?
Using a surround mode (DD, DTS, DPL, DPLII, DPLIIx)?
What model# receiver?
All sources (DVD, BRD, cable, satellite, OTA)?
How are source(s) connected to the receiver?
Sounds to me as if you need to properly setup/calibrate your receiver/speaker settings.
Ratman is online now
post #3 of 12 Old 11-05-2009, 09:12 AM - Thread Starter
5.1, I use DTS when possible, vsx-816, source is ps3
post #4 of 12 Old 11-05-2009, 09:41 AM
Lhasa-lover's Avatar
Point being, depending on source the answer changes. It may be as simple as your speakers are not calibrated. DirecTV has a HD setting that allows you to change the background effects from low to normal to high. So perhaps you may need to change that setting. Also, most AVR's have a dynamic setting that can be engaged or dis-engaged that also changes the loudness of effects. You need to calibrate, and then look to your sources.
Lhasa-lover is offline
post #5 of 12 Old 11-05-2009, 09:52 AM - Thread Starter
PS3 is always my source in surround sound.....I used the MCAAC auto eq to calibrate speakers.
Chris
post #6 of 12 Old 11-05-2009, 09:53 AM
umr
umr's Avatar
Quoted: 39 Post(s)
Liked: 77
umr is offline
post #7 of 12 Old 11-05-2009, 10:07 AM - Thread Starter
Any tips on setting up manual eq.
Chris
post #8 of 12 Old 11-06-2009, 10:31 AM
Wayne A. Pflughaupt's Avatar
Quoted: 89 Post(s)
Liked: 67
By "Music" do you mean "front speakers," and by "sound effects" do you mean the rear speakers?
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #9 of 12 Old 11-06-2009, 10:35 AM
bluesky636's Avatar
Originally Posted by umr View Post
MCACC is not good. Set it up manually.
Declarative statements like this with no rationale to back them up are useless.
bluesky636 is offline
post #10 of 12 Old 11-06-2009, 12:02 PM - Thread Starter
I tested my surround sound with "Return of the King". The background music playing through front left and right speakers is a little quiet, but when a fight scene breaks out the clash of swords is obnoxiously bright and loud.
Chris
post #11 of 12 Old 11-06-2009, 01:09 PM
bluesky636's Avatar
Chris
Well, if your system is calibrated properly, that is probably how it is supposed to sound. It's called "dynamic range."
post #12 of 12 Old 11-06-2009, 02:34 PM
XanderMoser's Avatar
Do you have your center channel turned up so you can hear dialog better at lower volumes? Because if you do, music will be quieter because it is often sent to the L and R speakers more so than the center. Many sound effects will be centered with the dialog, and will thus be much louder. That is, if you do have it turned up.
Check your receiver for any dynamics controls. I don't know what Pioneer calls them. Something like night mode or whatever. Switch it back and forth to see if there is a difference.
Is your center speaker the same model as the L and R?
XanderMoser is offline
