help!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-09-2009, 08:08 AM - Thread Starter
blues_bleu's Avatar
hello guys, i intend to get a home theater and maybe also good for music.
here is the speaker and amp i have found.
can anyone tell me if this will work.
B&W CWM LCR7 - L/R & C
B&W CWM 6160 - the rear
B&W PV1 - Subwoofer.
i would like to go with the yamaha dsp-z7 or the pioneer SC LX-82.
thanks in advance........
blues_bleu is offline
post #2 of 4 Old 12-09-2009, 08:11 AM
Ratman's Avatar
Quoted: 1487 Post(s)
Liked: 1191
Yes, it will work.
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is offline
post #3 of 4 Old 12-09-2009, 08:23 AM - Thread Starter
blues_bleu's Avatar
Originally Posted by Ratman View Post
Yes, it will work.
thanks ratman.
so which amp is better??
if budget is not a concern here?
post #4 of 4 Old 12-09-2009, 10:52 AM
Ratman's Avatar
Liked: 1191
Both are decent/adequate. Choose the one that suits your requirement(s) for features/functions.
Ratman is offline
