Dont buy Home Depot speaker wire - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Closed Thread
post #1 of 146 Old 01-28-2010, 10:02 AM - Thread Starter
Benjiville's Avatar
I bought 12 gauge home depot speaker wire about a month ago for my new rear surrounds. About a week later I blew my right channel. I returned my rear surround as it was new and still under warranty. I connected the new speaker and sure enough the same thing happened a week later the right surround blew once again. I checked all the connections and everything was fine. I then ordered some canare wire from blue jeans cables. When I took the wire down I noticed that inside the wire was all green corrosion inside the wire. I replaced the speaker again with a new one changed the wires and I have not had any problems since. So dont take a cranky old mans advice and by cheap wire from home depot. Thank God my expensive surrounds were new! Just wanted to share my experience I would stay far away from cheap wire from the depot and some cranky old mans advice of buying home depot wire. Good luck
Benjiville is offline
post #2 of 146 Old 01-28-2010, 10:09 AM
Gizmologist's Avatar
Liked: 31
Since you indicate that "you blew your right channel" and blame the wire I would have to ask you how you think a wire with internal corrosion or not blew your speaker. There is nothing in a wire that has the capability to blow a speaker.
BTW HOW did it "blow"? Was the voice coil fried open? That would require and excess of power fro the amp or severe clipping. (chopped DC instead of audio frequency AC getting to the speaker)
Professionally speaking there was another cause that was falsely BLAMED on the wire and corrected subsequently either by you accidently OR there was a defect in the speaker of some sort.
Damage in a wire such as a short between conductors would have zero effect on the speaker but WOULD damage the amplifier.
Gizmologist is offline
post #3 of 146 Old 01-28-2010, 10:27 AM - Thread Starter
Benjiville's Avatar
Well the speaker is fine now and green corroded wires from Home Depot is not good! I do say that that was the problem I am running a good amp and paradigm studio 20's for my rear. I believe that was the problem I dont care what mumbo jumbo you preach... I am just want to warn others who may get conned into buying cheap crappy wires because some idiot says they are fine... Have a great day
post #4 of 146 Old 01-28-2010, 10:29 AM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 459
It is not mumbo-jumbo. He is stating the truth based on physics. If you choose to blame corroded wires for blowing your speaker, feel free to do so but we will also feel free to
Kal Rubinson
"Music in the Round"
Kal Rubinson is online now
post #5 of 146 Old 01-28-2010, 10:32 AM
wingzz's Avatar
No mumbo jumbo there he is just stating facts, there is no way for corrosion in a wire to cause a speaker to blow, that is always clipping or not as ofter over powering it, the corrosion would cause the amp to blow a channel if the cable shorted but nothing would happen to the speaker
"There are only two ways to live your life.
One is as though nothing is a miracle.
The other is as if everything is." Einstein
Now Format Neutral
wingzz is offline
post #6 of 146 Old 01-28-2010, 10:35 AM
bluesky636's Avatar
So why did you buy cable from Home Depot in the firstplace? Why didn't you notice the green corrosion when you first installed them? It is going to take a lot longer than one month for wire to corrode. And for the record, Giz is correct. A short in the wire (either internally or at the connectors) cannot cause a spealer to fail but it will cause an amp to fail in a heartbeat. Clearly you know very little about electricity or electrical signals.
bluesky636 is offline
post #7 of 146 Old 01-28-2010, 10:40 AM - Thread Starter
Benjiville's Avatar
Home depot wire sucks dont buy it.
post #8 of 146 Old 01-28-2010, 10:46 AM
wingzz's Avatar
one persons uneducated opinion
Now Format Neutral
wingzz is offline
post #9 of 146 Old 01-28-2010, 10:47 AM
David James's Avatar
Quoted: 40 Post(s)
Liked: 80
An, articulate, well researched and reasoned response.
What is it about speaker wire that does this to people?
By the way, I've been running home depot wire in my theater for almost 10 years now.
David James is offline
post #10 of 146 Old 01-28-2010, 10:48 AM
CruelInventions's Avatar
Quoted: 459 Post(s)
Liked: 593
Wow dude, you're a tightly wound bundle of reactionary nerve endings, aren't you.
CruelInventions is online now
post #11 of 146 Old 01-28-2010, 10:50 AM
bluesky636's Avatar
Ah! The light goes on. You're the guy who wanted to use solid core magnet wire for your speakers because someone told you it was better. Then you wanted to buy some unknown speaker cable off the Internet that was silver plated because someone told you it was better. Then you went out and bought corroded Home Depot speaker cable (which you apparently were oblivious to from the get go) and mysteriously had a speaker blow. Wow. You have quite a track record.
Well, at least you ended up with some decent cable. Hope you don't blow anything else up.
post #12 of 146 Old 01-28-2010, 10:51 AM
Easyaspie's Avatar
If it was the speaker wire that blew your speaker, why did all of your speakers connected with this wire not blow?
Easyaspie is offline
post #13 of 146 Old 01-28-2010, 10:59 AM - Thread Starter
Benjiville's Avatar
OK you go buy there crappy corroded wire then you must be really smart... and I had that wire only for my 2 surrounds before I began my quest for good wire.
post #14 of 146 Old 01-28-2010, 11:01 AM
wingzz's Avatar
well I guess I'm smart enough to not buy wire if it's corroded in the first place
Now Format Neutral
wingzz is offline
post #15 of 146 Old 01-28-2010, 11:07 AM
Bob Lee (QSC)'s Avatar
Liked: 25
+1 to what Giz, Kal, and others have said.
Wire cannot blow your loudspeaker.
Bob Lee
Technical Communications Developer
QSC Audio Products, LLC
Costa Mesa, Calif.
Fellow, Audio Engineering Society
Bob Lee (QSC) is offline
post #16 of 146 Old 01-28-2010, 11:08 AM
antwon412's Avatar
Quoted: 12 Post(s)
Brah - toss that crappy BJC garbage and upgrade to Monster brand speaker wire! At only ~$250/ft its an awesome deal that will give you better clarity and crisper sounding highs.
Then toss those speakes you have and upgrade to a Bose wave system. (or if you are obesely rich, the Lifestyle system)
I mean its costs waaaayyyyy more so its got to be better right?
(A/V)Ignorance is Bliss -------- sweet, cheap bliss
antwon412 is offline
post #17 of 146 Old 01-28-2010, 11:12 AM
J_Palmer_Cass's Avatar
Quoted: 393 Post(s)
Liked: 118
Green patina on copper is not corrosion. Patina prevents corrosion. Is the Statue of Liberty corroded because it has a green patina on the copper skin?
http://en.wikipedia.org/wiki/Patina
As long as the connection points between the terminals and end of the wire are clean, the color of the wire means nothing much at all.
J_Palmer_Cass is offline
post #18 of 146 Old 01-28-2010, 11:25 AM
Quoted: 393 Post(s)
Liked: 118
I looked at my 15 year old Radio Shack clear jacket speaker wire that I use between my speakers and my wall outlets, and they are not green at all. Perhaps the plastic insulation on the Home Depot wire is causing a chemical reaction with the copper.
I don't even use "speaker" wire for wire that is installed in my walls and ceiling. I use standard 2 conductor communication wire that uses tinned copper.
post #19 of 146 Old 01-28-2010, 11:41 AM
Easyaspie's Avatar
Again I ask, why did your other speaker that was connected with the same wire not blow?
post #20 of 146 Old 01-28-2010, 11:52 AM
schroedk's Avatar
He obviously can't answer that question, because he's decided that he knows what was wrong, despite reasonable responses to the contrary.
At this point, unless he comes back and just admits that there was some other possible cause for the speaker problems, he's just going to get piled on.
Two things are infinite: the universe and human stupidity. And I'm not sure about the universe. -- Albert Einstein
schroedk is offline
post #21 of 146 Old 01-28-2010, 12:03 PM
mylan's Avatar
Quoted: 176 Post(s)
Liked: 167
You know, its threads like this one that make me want to go out to Home Depot and buy speaker wire just to prove someone wrong.
mylan is online now
post #22 of 146 Old 01-28-2010, 12:29 PM
Easyaspie's Avatar
Then he shouldn't have posted something so utterly stupid.
post #23 of 146 Old 01-28-2010, 12:38 PM
Lhasa-lover's Avatar
Did it ever enter your mind that when your speakers blew and you replaced them the only connections that you changed were the connections at the speaker. Then when you went out and bought new wire you now had to re-do the connection at the receiver end where you most likely had a short to begin with? Have you even considered this??? Nawww why would you.
Lhasa-lover is offline
post #24 of 146 Old 01-28-2010, 12:42 PM
schroedk's Avatar
I'm not disagreeing with you, but pretty much everything he's posted on this thread has been utterly stupid (or more appropriately, ignorant and arrogant).
schroedk is offline
post #25 of 146 Old 01-28-2010, 12:54 PM
pterpm's Avatar
uh, someone got mad with home depot and starting the blame game here
pterpm is offline
post #26 of 146 Old 01-28-2010, 01:00 PM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
I've been using the same 14AWG speaker wire that I bought from "Home Emporium" (Kind of like Rickels... predecessors to Home Depot/Lowes) ~ 30 years ago.
Never blew any speaker. I love my green patina!
Only bad green thing in this thread that is bad... is the wire troll.
Oops... just saw a new post.
LOL!!! I was persuaded quite a few years ago to try MIT speaker cables (~$300 for an 8' pair) when I bought my new receiver. I was asked to give them two weeks of "break in". After three weeks and no improvement in sound, I returned them and reinstalled my green speaker wire and never looked back.
Ratman is online now
post #27 of 146 Old 01-28-2010, 01:27 PM
RonaldoCombs's Avatar
I'm worried that your wire may be touching the ground. Have you looked into cable lifters? You want to be sure to avoid ground loop issues.
Ron
RonaldoCombs is offline
post #28 of 146 Old 01-28-2010, 02:02 PM
Easyaspie's Avatar
I know, I forgot to add a smilely after my post.
post #29 of 146 Old 01-28-2010, 02:39 PM
Randy Bessinger's Avatar
Quoted: 209 Post(s)
Liked: 163
Corroded wire bad, me thinks I buy super wire....good.
Randy Bessinger is online now
post #30 of 146 Old 01-28-2010, 03:57 PM
bluesky636's Avatar
In reality, it was Monster Cable. Mine used to turn green too. It was absolute heck stuffing the wire back into the cable jacket after its weekly polishing.
Closed Thread Audio Theory, Setup, and Chat
