"LFE Level" and other question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-28-2010, 11:55 AM - Thread Starter
Shane R's Avatar
I have a yamaha receiver, and the highest LFE level is 0, everything else is -something, what is a common setting?
And under the settings, it says what the speaker distances are, does it matter what the sub is set to?
I have tried soooo many different settings the last few days, and am so frustrated that I can't get the sound I'm looking for, just wondering how important these 2 things are.
I'm a complete noob and am trying to learn, but right now I am completely lost.
Shane R is offline
post #2 of 7 Old 02-28-2010, 12:28 PM
lmacmil's Avatar
Quoted: 65 Post(s)
Liked: 41
You may find the answer or get a better response if there is a forum dedicated to your receiver in the receiver forum section.
Did you run the YPAO setup? That's probably as close as you can get to "optimum" settings. If you don't like the sound, then tweak settings until you do.
lmacmil is offline
post #3 of 7 Old 02-28-2010, 12:40 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
I have a yamaha receiver, and the highest LFE level is 0, everything else is -something, what is a common setting?...
The correct setting is the calibrated setting (this applies not just to the sub but all of your speakers). If your receiver doesn't have an auto calibrating system like Audyssey then you need a SPL meter (should have one anyway) like a Rat Shack.
...And under the settings, it says what the speaker distances are, does it matter what the sub is set to?...
Yes it does and distances should be measured and set again for all of your speakers.
William is offline
post #4 of 7 Old 02-28-2010, 12:56 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Shane R, there is no need to post this at three different thread. Others are trying to
help with recommendation and questions but there is no feedback from you.
Hardly any bass??
**Offical** Yamaha RX-V665 AV Receiver thread
JChin is offline
post #5 of 7 Old 02-28-2010, 01:05 PM - Thread Starter
Shane R's Avatar
Hardly any bass??
The receiver thread is a different receiver than mine so I decided to stay out of it.
I could not find the other thread, but now see it is back a page, clearly I am not very good on a message board either.
I appreciate all the input, I didn't post here because I wasn't getting any answers, just wasn't sure what happened to the other thread. Thank you guys....
My next question, I have a movie in, I hear music, but no voices. ugh
Shane R is offline
post #6 of 7 Old 02-28-2010, 01:39 PM
sivadselim's Avatar
Quoted: 162 Post(s)
Liked: 154
Set the LFE level to the default setting and leave it alone. The default setting for that receiver is probably "0". That setting is different from the subwoofer channel level trim and is only there for the (now) very rarely encountered old recording that has an incorrectly encoded LFE channel.
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is online now
post #7 of 7 Old 02-28-2010, 02:52 PM - Thread Starter
Shane R's Avatar
Thank you, it was weird to me that there were no positive settings, just negative like "-3", after all the input I received here I think I have it finally.
Thank you!
Shane R is offline
