Multiple Subwoofers EQ DSP Help... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 04-10-2010, 01:52 AM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Either I don't know what to look for (probably the case) or there isn't a simple explanation of this anywhere on the entire internet (unlikely)
Say I want 3 or more subs in a room (5000?), I've got an AVR/Processor (Denon 3808A). It has one sub-out.
I understand I need some sort of EQ for this?
Could someone please explain what bits of gear I need and how it all plugs together.
Also if I could get some recommendations for gear that would be useful (budget, mid range and ultra high).
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #2 of 33 Old 04-10-2010, 03:35 AM
gooki's Avatar
All you "need" is 3x RCA cables, and daisy chain your subs together.
Now if you want to tweak each subs performance, then you'll want type of dsp but this depends on what type of adjustments you want to make. The easiest solution would be to buy subs with a built in dsp with the features you want.
International HDDVD Screenshot Archive (Full 1080p Images): www.hdmovies.co.nz
gooki is offline
post #3 of 33 Old 04-10-2010, 04:56 AM
vesa's Avatar
vesa is offline
post #4 of 33 Old 04-10-2010, 05:56 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
Elill:
What kind of gear do you have to measure room RTA, SPL, FFT etc?
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #5 of 33 Old 04-10-2010, 06:19 AM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Hi Dennis, nothing as yet - well nothing that isn't room eq and a cheap mic, just want to make sure I provision for everything pre/during build and not finish the room and go "gee I wish I had done that"
Peter the Greek
Elill is offline
post #6 of 33 Old 04-10-2010, 07:58 AM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
I run four 15's. The amps have a parallel out to daisy chain amps together. The only EQ is a variable LT ( the subs are sealed ). I use Audyssey to smooth out any problems, Does the 3808A have Audyssey ?
The nice thing about Audyssey is that it looks for the knee of the subs rolloff and tweaks down that low. My LT gets me down to about 8hz. I measured it with Truerta and sure enough flat down to 10hz and the F3 is about 7or8hz.
Plus it will EQ all your speakers too !!!
KG
As of Jan 2017, im still looking for (1) Outlaw M-200 mono amp, and a used Marantz 7010
kgveteran is offline
post #7 of 33 Old 04-10-2010, 08:39 AM
umr
umr's Avatar
Quoted: 39 Post(s)
Liked: 77
I would focus on room treatment and proper placment before electronic correction, but this product is a good design for multiple subwoofer EQ http://www.jblsynthesis.com/products...=us&Region=USA. I would manually adjust the sound and not use Audyssey if it was my system.
umr is offline
post #8 of 33 Old 04-10-2010, 03:16 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
I use Audyssey all the way after trying the Anti Mode 8033, SMS-1, and some treatments (they can be more expensive than electronic EQ units). I use Audyssey Pro for the speakers and Audyssey Sub EQ for two subs (Conquest and MFW-15 together). The Audyssey combo got me the SQ that I was looking for.
Bill
bsoko2 is offline
post #9 of 33 Old 04-10-2010, 05:17 PM
Quoted: 64 Post(s)
Liked: 100
1. proper placement
2. proper planning and acoustic treatments
3. no Audyssey
4. you need a good mic (better, four mics), and the ability to individually set levels, PEQ, and, only as a last resort, individual phase control (always, always, always start with all subs in the same phase! You need to turn on each sub individually, set levels, then reset with all subs running then start the marathon with your QSC DSP322.
post #10 of 33 Old 04-10-2010, 05:46 PM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
Looks like I'm going to need to enlist the help of a pro on this front.....QSC is not an option at A$7500 each.....unfortunately, bah its all too complicated
Peter the Greek
Elill is offline
post #11 of 33 Old 04-10-2010, 05:55 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Originally Posted by Dennis Erskine View Post
1. proper placement
3. no Audyssey
All you guys that do Home Theaters really hate Audyssey and other room EQ programs. Electronic room EQ is getting better and better (like Audyssey Pro and Audyssey Sub EQ) so there is really no need for the little guy on a budget to hire you. This cuts into your livelyhood and the guy with a bedroom HT gets more bang for the buck.
Bill
bsoko2 is offline
post #12 of 33 Old 04-10-2010, 07:22 PM
kgveteran's Avatar
Quoted: 363 Post(s)
Liked: 130
Bill
I have to agree. I've been a tweakaholic for years and really gave it up once I saw, and heard the results of Audyssey. I'm sure you guys can shoot small holes in the results that Audyssey provides, but for now Bill hit the nail on the head, on a small budget Audyssey does it cheaper and better than I could do, unless you guys are offering Pro bono system calibration, where I would then say "Hell to Audyssey" !!!!!!
post #13 of 33 Old 04-10-2010, 07:46 PM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
I wouldnt say I'm building a "bedroom" HT, well it might be buy your standards, but its costing the same as a pretty darn good family car (they're not cheap here), so I want to make sure my investment is going to work -
If that means throwing a couple of grand at someone to calibrate things so be it. I just want to make sure I've got cables in place for every possible scenario and get an idea as to what equipment might be needed and cost.
So getting a little of track here, with the exception of a daisy chain, how else are multiple subs wired and controled?
Peter the Greek
Elill is offline
post #14 of 33 Old 04-10-2010, 08:28 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Nice room and setup. You can use "Y" splitters off the back of the LFE on the receiver. Your Denon does use Audyssey and I assume that you can have Audyssey Pro installed by an installer ($500 including software key cost of $150) on it. That will give you a good sub EQ with the Pro. To go further, if you can not have Pro installed, then go with Audyssey Sub EQ ($799) and you will be able to do 2 subs or 4 in multipules of 2. I did Audyssey Pro all the way and bought my own intaller kit for $550 so it all cost me $1500 to get the SQ that I was after. Or, go cheaper with an SMS-1 (can do 2 or more subs), Anti Mode 8033 (can do 2 or more subs and is fully automatic) or the cheaper version of the Audyssey Sub EQ, SVS EQ1 for $700 or so. Bite the bullet and get the best as far as Audyssey or go cheaper, the SQ that you want is up to you. I'm sure that others will chime in and sift through the info and make a choice, cost vs quality sound.
Good luck, Bill
bsoko2 is offline
post #15 of 33 Old 04-10-2010, 09:27 PM
penngray's Avatar
Liked: 43
You can go cheaper with this mic
http://www.parts-express.com/pe/show...number=390-801
download the free REW from here
http://www.hometheatershack.com/foru...ease-read.html
Use a PC, measuring your room and find a used DCX2496 for under $400. It has all you need and more.
penngray is offline
post #16 of 33 Old 04-11-2010, 06:36 AM
Terry Montlick's Avatar
Location: State of Rhode Island and Providence Plantations
For auto-EQing multiple subs, a single-sub system like Audyssey is not optimal. Ideally, subs should have separate equalizers. EQ one sub, then leave those settings. EQ the second sub, with the first sub playing with its fixed EQ settings. Leave those second settings on the second sub. EQ the third sub, with the first two subs playing with their fixed EQ settings.
- Terry
Terry Montlick Laboratories
Home Theater Acoustics
Critical Listening Rooms
Design, Evaluation, Alpha Certification®
www.tmlaboratories.com
Terry Montlick is offline
post #17 of 33 Old 04-11-2010, 07:09 AM
penngray's Avatar
Liked: 43
Correct and that is why something like the DCX is perfect. It has the ability to control up to 6 subwoofers. along with phase, delay and sub sonic filter capabilities.
penngray is offline
post #18 of 33 Old 04-11-2010, 07:27 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
- Terry
Why would separate EQ's for each subwoofer be "ideal"? Since you only *hear* the combined result of all the subwoofers, why wouldn't a single EQ curve applied to the combined result not be as good, (or better than), separate EQ's curves for each sub?
For example, I am currently using Audyssey MultEQ XT to EQ my system, (3 Seaton Submersives placed randomly and at unequal distances to the LP.) Here is the result:
That is a 3-position measurement, averaged across the 3 primary LP's. How could this be improved upon by using separate EQ's for each subwoofer?
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #19 of 33 Old 04-11-2010, 07:30 AM
Subs have phase interactions. You can get better correction if these are taken into consideration. This cannot be done with one setting for all subs.
In your case, you got lucky!
post #20 of 33 Old 04-11-2010, 08:21 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
I don't think it was luck. I spent an enormous amount of time and effort to get that response. Here's what I started with, (this is with all 3 subs lined up in the front of the room):
Here's what the response looks like with the subs in their current positions, but without Audyssey MultEQ XT:
To make it easy to see the progression, I'll re-post the response with Audyssey MultEQ XT:
You and Dennis and umr can poo-pooh Audyssey all you want. I've had nothing but excellent results... and it's certainly not just *luck*.
Craig
Lombardi said it:
My System
post #21 of 33 Old 04-11-2010, 08:23 AM
penngray's Avatar
Liked: 43
and Geddes
btw, craig can you do phase measurements with that software? Does phase really matter that low? couild you also tell me what the resolution is on your measurements? 1/6th octave?
penngray is offline
post #22 of 33 Old 04-11-2010, 08:26 AM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 67
Haven’t done this myself, but I know people who painstakingly EQd each separate sub, only to find that response was a mess when a measurement with all of them was taken. Since the combined output of all subs is essentially heard as a single source, there’s no reason why equalizing them in the same manner won’t work. So maybe Craig didn't just get lucky.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #23 of 33 Old 04-11-2010, 08:26 AM
Incorrect interpretation. I do not "poo-pooh Audyssey." It is an excellent device when used within its limitations.
post #24 of 33 Old 04-11-2010, 08:43 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
and Geddes
The resolution is 1/6th octave. The software doesn't do phase measurements per se. It does some time domain measurements. The small chart in the upper right corner of each graph is a 2D frequency/time/level chart. You can see the improvement in the time domain provided by Audyssey. The software also does 3D waterfall charts which I did, but did not save.
http://www.xtz.se/uk/products/mearur.../room-analyzer
Craig
Lombardi said it:
My System
post #25 of 33 Old 04-11-2010, 09:46 AM
LINEARX's Avatar
1. proper placement
3. no Audyssey
Dennis just set the GOLD STANDARD for speaker setup.
If you want to take a short cut or don't have the money for the equipment there are some easier, less expensive, less time consuming alternatives . . . . and less effective.
LINEARX is offline
post #26 of 33 Old 04-11-2010, 10:18 AM
fsrenduro's Avatar
Quoted: 33 Post(s)
The reality is that even here on AVS I would estimate that at least 70% of us don't have dedicated rooms for home theater. That pretty much eliminates the ability to put speakers and/or room treatments wherever we want (i.e. in all the ideal locations). If you can't use the best speaker (or sub) placement and can't have all the first reflection absorption, diffusion and low frequency absorbers that are needed what are you left with?
This argument of what's better Audyssey (or other room correction) vs. custom calibration too often turns into an apple and oranges fight. Without question a room designed, built and calibrated for home theater is better. The argument should always be about 'under the circumstances'.
My room is well over 8000 cu ft open to the entire downstairs of my house, and while I've done some aesthetic wall panels and a floor to ceiling bass trap of OC705 I'm limited in my subwoofer placement. Audyssey Pro has done a tremendous job in helping correct problems in my room that couldn't otherwise be addressed and still be functional as a family room. By this rationale I would argue that Audyssey is MORE effective than spending thousands more on a custom calibration.
don't insult my intelligents
fsrenduro is offline
post #27 of 33 Old 04-11-2010, 02:04 PM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
My room is over 5000 cu ft with opening to other parts of the house. Audyssey Pro and Audyssey Sub EQ has done more for my living room HT than MCACC, Anti Mode 8033, SMS-1, by themselves or in any combination. Audyssey does it all better without 1000's spent on room corrections or some designer/installer coming in and tweaking it all for me. The 1500 that I have spent on Audyssey was a good investment and I got the SQ that I was after. Click on http://www.polkaudio.com/forums/show...p?userid=76775 and see how much area I have to fill.
Bill
bsoko2 is offline
post #28 of 33 Old 04-11-2010, 04:24 PM - Thread Starter
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
This has been most useful - thanks especially to Terry and penngray.
I didn't really want this thread to get into an Audyssey v the world argument.
Just wanted to know how to hook up multiple subs and run them - in a dedicated room. So I'll be going down the path recommended by Dennis/Terry/Penngray, just with a cheaper EQ. I'll need a couple of DIY subs, but that shouldn't be an issue.
I run Audyssey in our living room and it does a great job......FWIW
Peter the Greek
Elill is offline
post #29 of 33 Old 04-11-2010, 07:32 PM
Quoted: 64 Post(s)
Liked: 100
If the Basis/Rave DSPs are out of reach down under, see what your local pricing is on QSC DSP4 you'll need three. [Sub out to DSP4 number one, split into two channels. Each of those outs to DSP4 number two and number three. One of the final DSP4's will have two subs and the other just one sub with a spare port for sub number 4 in the future.]
In the US they are in the area of $350 to $400 each.
post #30 of 33 Old 04-11-2010, 07:36 PM
Quoted: 64 Post(s)
Liked: 100
Don't use a Chevy Nova to pull a 100' yacht on a trailer.
