Best optical cable switch box? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 05-20-2010, 11:20 PM - Thread Starter
pakostevens's Avatar
What's my best option to be able to plug in 3-5 optical cable into my receiver?
Ideally I want it to sorta blend in with the rest of my setup (not some plasticy toy looking thing) and be loss-less.
These are the only 2 I've been able to find.
http://www.google.com/products/catal...9984895721237#
http://www.audioauthority.com/produc...ital_Audio/5/1 - this ones too expensive probably lol
pakostevens is offline
post #2 of 8 Old 05-21-2010, 11:17 AM
HawaiianHDaddict's Avatar
This one is pretty ugly but you can't beat the price http://www.monoprice.com/products/pr...t=1#largeimage
HawaiianHDaddict is offline
post #3 of 8 Old 05-21-2010, 11:29 AM
ccotenj's Avatar
Liked: 101
clicky
- chris
ccotenj is offline
post #4 of 8 Old 08-13-2012, 04:24 PM
eaadams's Avatar
Quoted: 52 Post(s)
What did you end up using and was it successful?
eaadams is offline
post #5 of 8 Old 08-14-2012, 09:45 AM - Thread Starter
I ended up using this one http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=2946&seq=1&format=1#largeimage it is bulky and ugly but it's dirt cheap and just rests behind my tv stand. have 2 xbox360's and ps3 plugged into it.
post #6 of 8 Old 05-30-2013, 11:26 AM
tony1381's Avatar
I'm curious on if your optical switch still works, as the many reviews on Amazon indicate it stops working after a few months.
tony1381 is offline
post #7 of 8 Old 09-09-2013, 08:21 PM
rossdunn's Avatar
I bought that piece of crap and it never worked to any extent I would call worth even $1. Stay away from it! Just my two bits. I have yet to find one I like but I will do my best to post here when I find it.
Have anyone of you guys found a setup you like?
Ross
rossdunn is offline
post #8 of 8 Old 09-09-2013, 09:11 PM
JChin's Avatar
Quoted: 374 Post(s)
Liked: 210
Ross
Hi rossdunn, Cable To Go #28731 switch box has worked great for me, even has a remote which I programed into my Harmony remote.
JChin is offline
