AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Audio Theory, Setup, and Chat (http://www.avsforum.com/forum/91-audio-theory-setup-chat/)
-   -   Which best: "PCM ONLY","DOLBY Digital/PCM",or "STREAM/PCM" (http://www.avsforum.com/forum/91-audio-theory-setup-chat/1251727-best-pcm-only-dolby-digital-pcm-stream-pcm.html)
rlubocki 05-23-2010 03:54 PM
I have a older dvd player with these 3 options:
"PCM ONLY"
"DOLBY Digital/PCM"
"STREAM/PCM"
I am using a fiber connection for audio, and my receiver is top notch Elite series with all the dolby options. I am looking for best sound out of those 3 settings.. My speaker setup is 5.1, so most dvds will have dts the most, which one is for me?
BIslander 05-23-2010 07:21 PM
"PCM ONLY"
"DOLBY Digital/PCM"
"STREAM/PCM"
I'd guess STREAM/PCM, which would appear to be the setting that will bitstream both DD 5.1 and DTS. What does the manual say? What happens when you try each one?
rlubocki 05-24-2010 07:51 AM
Stream/PCM seems to be working the best. When playing DTS sources the first two play in 2 front channels, when Stream/PCM is chosen, all DTS materials play flawlessly. I guess experimenting is best way to learn thing or two. Thank you for the help!!
Rob
maverickrohan 05-24-2010 10:55 AM
"PCM ONLY" - The decoder on your DVD player decodes audio.
"DOLBY Digital/PCM" - The decoder on your DVD player will decode audio.
"STREAM/PCM" - The decoder on your AVR will decode audio.
The third option is the best.
rlubocki 05-24-2010 11:27 AM
That is the answer I was looking for! Thank you, finally plain English applied to everyday plain existance
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
