7.1 audio L&R immediate surround speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-24-2010, 06:18 PM - Thread Starter
fookoo_2010's Avatar
Quoted: 245 Post(s)
Liked: 84
I have a 7.1 HT system and have always found the output of the L & R immediate surround sound speakers to be reticent, when compared to the output of the rear most speakers. In calibration, the speakers all have about the same loudness of the test tone, one at a time. Or another way of putting it is that most of the surround sound comes from the rear most speakers. All of the surround sound speakers are 3 way with all of the speakers set to small, including the front speakers, deferring to the sub-woofer. This is especially true for 5.1 audio on a blu-ray disc. The rear most speakers are Infinity P362's while the immediate L&R speakers are an old pair of Infinity Qb's. Recently, I had four Polk R50's in those positions and still got the same type of output, in terms of volume. The Infinity speakers are a lot better, but then it is a three way speakers versus two way speakers with a dramatic difference in cost. I am curious as to the experience of those with full range, tower type speakers in the surround positions whether or not the immediate R&L speakers are also somewhat turned down, compared to the rear speakers assuming the same speakers in all four of the surround sound positions. Is it worthwhile to upgrade the Qb's to a pair of Infinity P362's?
fookoo_2010 is offline
post #2 of 5 Old 06-24-2010, 06:55 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 191
Any chance you've got your rear speakers wired to the surround outputs? I ask because with 5.1, you shouldn't have any sound coming out of the rears. With matrix processing such as PLIIx, the rears should not have most of the sound.
BIslander is offline
post #3 of 5 Old 06-24-2010, 07:49 PM - Thread Starter
Quoted: 245 Post(s)
Liked: 84
Always learn something new. I ignored the PLIIx button on the remote control of the Panasonic SA-BX500. I would assume that it is ON because the manual states: The technology enables you to play 5.1-channel Dolby Digital and DTS sources on 7.1 channels (when two surround back speakers are connected to the unit)....................
The overall sound is front dominant with the rear most speakers providing an amazing fill-in.
post #4 of 5 Old 06-24-2010, 08:22 PM
sivadselim's Avatar
Quoted: 265 Post(s)
Liked: 223
"All men are frauds. The only difference between them is that some admit it. I myself deny it."
sivadselim is offline
post #5 of 5 Old 06-25-2010, 01:06 PM
Roger Dressler's Avatar
Quoted: 1846 Post(s)
Liked: 978
The manual is not totally explicit.
a) You have to engage PLIIx if you want it to function.
b) >>when two surround back speakers are connected to the unit<< means the back speakers are present, in addition to the side speakers. The sides are "the surrounds" and in a direct 5.1 playback mode, they will be operating and the rears will be silent. Hence BIslander's question, since what you describe is the opposite effect.
Once you have confirmed each speaker is connected to the correct channel, then try PLIIx Movie mode and see if that helps.
Current: Deadwood II Theater
Previous: Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
