The "Official" xtz Room Analyzer Thread - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #451 of 568 Old 12-29-2014, 12:34 PM
Wayne A. Pflughaupt's Avatar
Quoted: 111 Post(s)
Liked: 79
Originally Posted by westmd View Post
Wayne,
Could you advise how to achieve such a curve in XTZ room analyzer pro? I will have a 10-band PEQ in my Datasat LS10
I’ve never used XTZ. However, the concept will be the same. If the program will accept a house curve file which will create a target curve on the screen, then create one as outlined in the instructions and load it into the program. After that it’s just a matter of EQing response to reasonably track the target.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #452 of 568 Old 12-29-2014, 05:09 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
Originally Posted by Roger Dressler View Post
No. Try changing the delays (speaker distance). Add a few feet of distance to the subwoofer, then see if the notch moves. As you get closer to the correct timing, the notch will move to a higher frequency, and eventually disappear.
That was my first thought too, but if you look at Leo's equipment list, it doesn't look like he's using a subwoofer.
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #453 of 568 Old 12-29-2014, 05:36 PM
Roger Dressler's Avatar
Quoted: 1743 Post(s)
Liked: 884
I see an SVS SB12-NSD in the list.
Deadwood II Theater
Deadwood Atmos theater [HTOM]
SSP-800 PLIIx 7.4; Anthem AVM 60 7.4.4, MiniDSP OpenDRC-AN
Aerial Acoustics 7B/CC3B fronts, KEF Ci200QS surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
JVC RS520; Stewart Cima Neve 115"W x 49"H 2.35 screen
Roger Dressler is offline
post #454 of 568 Old 12-29-2014, 06:33 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
You're right. I didn't read close enough. In that case, your original advice is spot on.
Lombardi said it:
My System
post #455 of 568 Old 12-29-2014, 06:45 PM
Liked: 884
Whew! That saves him a bunch of money pushing the walls out!
Deadwood II Theater
post #456 of 568 Old 01-03-2015, 09:48 AM
westmd's Avatar
Quoted: 823 Post(s)
Liked: 286
Wayne A. Pflughaupt
As far as I understood XTZ so far is that the system is suggesting PEQ values to achieve a flat Curve.
In your first article about house curves you suggest PEQ values to achieve a curve from a flat response curve. Do you have any suggestion how to set the PEQ to achieve a 'perfect' curve from a flat curve?
westmd is offline
post #457 of 568 Old 01-03-2015, 01:05 PM
Quoted: 111 Post(s)
Liked: 79
Sorry, don’t know what you mean by “perfect curve.”
Wayne A. Pflughaupt
Equipment List
post #458 of 568 Old 01-03-2015, 06:19 PM
Liked: 884
REW let's you dial in a house curve, then will offer filters to get there. Not sure if XTZ lets you design a target curve like that. But since house curves are about getting a preferred sound, you can just dial in some changes. REW is also a very useful way to visualize what can be done with EQ filters. Then you can transfer those settings to your real EQ.
Deadwood II Theater
post #459 of 568 Old 01-04-2015, 01:21 AM
westmd's Avatar
Quoted: 823 Post(s)
Liked: 286
But can I use the XTZ hardware for REW? I read something about a needed calibration file?
westmd is offline
post #460 of 568 Old 01-04-2015, 06:55 AM
westmd's Avatar
Quoted: 823 Post(s)
Liked: 286
In the meantime I have got a quick and competent answer from XTZ, so I don't rhink I need REW!
We have a "drag" function(drag the curve to what you want) that allow you to create your own curve and then the system show the PEQ setting so its very flexible !!
Roger Dressler likes this.
westmd is offline
post #461 of 568 Old 01-04-2015, 08:20 AM
Quoted: 111 Post(s)
Liked: 79
Hats off to XTZ, that is very cool!
Wayne A. Pflughaupt
Equipment List
post #462 of 568 Old 03-30-2015, 02:14 PM
adidino's Avatar
Quoted: 362 Post(s)
Liked: 277
Anyone on this thread using XTZ PRO II? USB sound card connected, generic windows driver installs. However, XTZ software does not output any sound. Microphone seems to be working as I can see from RTA it's picking external audio but I can't get XTZ to generate any tones for room measurement.
What am I missing? Should be straight forward from what I can tell.
adidino is offline
post #463 of 568 Old 03-31-2015, 06:30 AM
SRT
DaveyMac's Avatar
Quoted: 606 Post(s)
Liked: 125
Can someone PLEASE give me a link to where to order this? US source ideally.
I will be using this for my home only, so I don't think I need the advanced version.
I used Craig's link in first post, but it went to website that is in some other language that looks like Viking words.
DaveyMac is offline
post #464 of 568 Old 03-31-2015, 09:52 AM
Kal Rubinson's Avatar
Quoted: 761 Post(s)
Liked: 526
http://www.xtzsound.com/en/products/...alyzer-ii-pro#
http://www.xtzsound.us/shop-en/measu...nalyzer-ii-pro
You do. It is worth the difference. (I have both.)
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #465 of 568 Old 03-31-2015, 01:34 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
http://store.acousticfrontiers.com/X...er-II-Pro.html
DaveyMac likes this.
Lombardi said it:
My System
post #466 of 568 Old 04-03-2015, 04:19 PM
SRT
DaveyMac's Avatar
Quoted: 606 Post(s)
Liked: 125
I purchased from this link and it cost $40 less than the actual mfr. site! Plus I emailed them if I could use my own fed ex label, and they happiy accommodated me. So I highly recommend this acoustics frontier place!
Question - right now I have both subs hooked up via wireless kits. They work great and I really need to use them for WAF.
However, because of the latency, one of them always gets set to 57 feet after Audyssey. Although my Denon seems to go to 60 feet max, when I open the distance screen - an error message pops up basically saying 'distance too far, reconfigure'. Then the damn AVR sets it to 30 ft automatically.
Do you think this program will allow me to adjust distances in such a way that will negate the deleterious effects the sub receivers are having on my setup? I'll go get super long sub cables if I really have to.
DaveyMac is offline
post #467 of 568 Old 04-04-2015, 05:15 AM
adidino's Avatar
Quoted: 362 Post(s)
Liked: 277
Turned out to be a bad Y cable.. all good
adidino is offline
post #468 of 568 Old 04-05-2015, 11:54 AM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
Posts 1 & 2 of the thread have been updated with all links fixed.
Craig
Lombardi said it:
My System
post #469 of 568 Old 04-06-2015, 02:45 PM
SRT
DaveyMac's Avatar
Quoted: 606 Post(s)
Liked: 125
Wow, good job with updating the first post. That was obviously a ton of work!
Can anyone who's seen lots of graphs give me ther opinion on how mine looks? Is it good, bad, outstanding, terrible?
The data in the 'found room modes' box - if I got a mini dsP, do I basically put that data in it somehow? And then my system would sound better?
My main complaint with my system is that it seems like there's no mid-bass punch. It just doesn't overly impress, and I feel like it should with the subs I have. I' used the Rta/sub crawl and I'm confident they are in optimal position. Will getting a dsP be a noticeable improvement?
DaveyMac is offline
post #470 of 568 Old 04-06-2015, 04:29 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
Were those two measurements taken with the mic in the same spots? The response from 300 Hz down looks quite a bit different in the 2 graphs. You have 2 STEEP nulls in the full range graph that don't show up in the RA graph. It looks like the mic was moved between graphs.
Can you tell us some more about your system, your room and the placement of the speakers, subs and the LP?
Also, do your Room Analyzer measurements with the smoothing set to 12 PPO. That will show more detail.
The RTA is only 1/3 octave resolution. I would not use it for final placement of the subs. Use Room Analyzer at 12 PPO. Also, focus as much on the Decay Time Spectrogram as much, or more, than the FR graph.
Lombardi said it:
My System
post #471 of 568 Old 04-19-2015, 09:32 AM
SRT
DaveyMac's Avatar
Quoted: 606 Post(s)
Liked: 125
I've finally achieved a decent response with the help of XTZ.
For those of you new to the program, I've picked up some techniques.
When you measure, set your AVR to dolby surround or multi-channel, if you want to graph all of your speakers.
If you only want to graph subs, set AVR to stereo and simply unplug LR speakers.
If you want to change curve on screen and have the appropriate filters listed for a minidsp - simply right click/drag the line to where you want it. The appropriate EQ adjustment/PEQ will then be listed in room modes box.
Often, it might not grap the line exactly where you wanted to. All you need to do is double click the room mode. A window will pop up that will allow you to modify the Q, DBs, and frequency. I found this very useful as any changes will change the tan result line instantly. Very often I found I could modify the Q, DBs or frequency it gave - and end up with a much better looking tan line/result.
If you go enter the room mode parameters that you liked into a dsP and then run graph again - it's pretty spot on.
Here is what I ended up with. I've given up on 130hz.
DaveyMac is offline
post #472 of 568 Old 04-20-2015, 10:41 AM
jmhenrie's Avatar
I have finally gotten my 5 channel amp back and installed for my 7.1 system. I calibrated all the speakers including the subwoofer with my Radio Shack SPL to 77 db A slow using the internal test tones from my Classe SSP800. then decided to check the calibration with XTZ, they all showed 74db except for the Subwoofer which showed 54db, the two db difference is probably just a calibration thing but the big drop in the subwoofer surprised me. Which reading should I go with? All readings were taken from my normal listening position.
Also for equalization purposes is it best to do each speaker seperatly or run all 7.1 at once. I listen to music about 40% of the time in two channel, and movie/TVs the rest of the time.
thanks for any help
Mike
jmhenrie is offline
post #473 of 568 Old 04-20-2015, 03:39 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
I don't recommend this. When listening to music or watching a movie, your speakers will generally be playing diferent content in each speaker. The CC will cary dialogue and sounds that are placed in the front center, as well as sounds that "pan" across the front soundstage. The L/R speakers will carry the left and right content, and what is on the left is virtually always different than what's on the right. The content in the surrounds will range from ambiance enhancement to directional sound effects. Bottom line, there will be virtually ZERO content that is shared by all the speakers. Therefore, why would you want to measure all the speakers at once playing the same signal? You should mesure individual speakers + subs to look for integration problems around the crossover frequency. Put the system in "Stereo" mode. Then disconnect the left speaker and measure the R speaker + subs. Repeat that with the L speaker + subs. Then put the system into PLIIx Cinema, (or Movie) mode. This will direct all the identical content in the L/R channels to the CC. Then measure just the CC and subwoofers. This will give you much better info about each speaker and how it iteracts with the room and LP.
Yes.
130 Hz is being reproduced by your speakers, not your subs. If this is a composite of all your speakers in Multichannel stereo, that 130 Hz trough may or may not exist in any one speaker. You need to be measuring each speaker individually to determine their individual responses.
Your bass response looks great!
Craig
Lombardi said it:
My System
post #474 of 568 Old 04-20-2015, 03:49 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
Put the SPL meter in C weighting.
https://www.noisemeters.com/help/faq...-weighting.asp
Are you trying to EQ the speakers? I'm not familiar with your pre/ro, but I don't suggest trying to EQ much above about 250 Hz. Do each speaker separately. See my post above this one.
Craig
Lombardi said it:
My System
post #475 of 568 Old 04-20-2015, 04:47 PM
SRT
DaveyMac's Avatar
Quoted: 606 Post(s)
Liked: 125
Craig
Uh oh, well You can see the dip at 83 hz and trough at 130. I actually got rid of both problems by adding 8db at 83hz and adding 10db at 123hz with a minidsp on subs.
So if my subs aren't supposed to play 123hz, should I undo that correction? I'm not sure how I even managed to get rid of it with just subs and minidsp. Everything does sound better but I still feel like everything doesn't sound quite right.
I thought 120hz are was mid bass and that's really important to me. I don't know how in the world I'll fix 123hz trough now. I guess I'll try adjusting toe in and physical distances of my mains. All I really care about in my system is how good the bass sounds for movies/tv.
But do you think I should NOT add DBs to subs at 123hz? Is it ok to add at 83hz?
DaveyMac is offline
post #476 of 568 Old 04-20-2015, 05:17 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
What crossover frequency are you using? I assumed you were using an 80 Hz crossover, but that may be incorrect.
I can't tell you whether you should be using those boost settings until I see measurements of the individual speakers + subs. However, I will say that 8 dB and 10 dB are large amounts of boost. That kind of boost eats amp power and driver excursion, which limits system headroom. I would look for other solutions before applying that much boost.
Finally, I asked a bunch of questions about your system in a post a few days ago. You never answered those questions. It would be much easier to help you if I knew more about your system.
Craig
Lombardi said it:
My System
post #477 of 568 Old 04-20-2015, 07:23 PM
SRT
DaveyMac's Avatar
Quoted: 606 Post(s)
Liked: 125
Craig
Sorry I had answered the question but had a lot of other questions I later figured out, so I deleted post.
80 crossover. Denon X4100w xt32 w/ multi sub eq. 5.2.2 front height. All HSU bookshelves for mains (aud puts them to 40, but I put them all to 80 and small) HSU center, dual VTF3 MK5's.
DaveyMac is offline
post #478 of 568 Old 04-20-2015, 08:22 PM - Thread Starter
craig john's Avatar
Quoted: 530 Post(s)
Liked: 751
How big is the room, and where is your seating located in it? How close or far from the room boundaries?
How did you end up dealing with the latency in the wireless kits?
Craig
Lombardi said it:
My System
post #479 of 568 Old 07-18-2015, 10:17 PM
SRT
DaveyMac's Avatar
Quoted: 606 Post(s)
Liked: 125
I have some folks helping me figure out my poor FR after Dirac Live.
I need to measure just my subs using XTZ.
Do I put AVR on stereo mode (with subs). Turn only one sub on. Unhook left and right speakers. And then measure? I'm assuming that's easiest way?
My crossovers are at 80hz in AVR. So when I run a FR, the line starts rolling off around 80hz. I'd like to to take a measurement of the full range of my subs. To do this do I just raise my crossovers in AVR as high as they will go?
DaveyMac is offline
post #480 of 568 Old 08-27-2015, 10:20 PM
Quoted: 17 Post(s)
Liked: 6
Site doesn't look too active lately. Hopefully someone can give me a link to download software for RA II Pro. Website just says "No software for this product" What's up with that?
Leotis is offline
