Audio Sync Issue: Samsung LED TV and Samsung Home Theater System - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-23-2010, 04:32 PM - Thread Starter
hengbokdl7's Avatar
Hi everyone, I just wanted to go to all the experts here.
I have a Samsung LED UN55C8000, and a Samsung HT-6600 home theater system. Very simply, no matter what I'm plugging into the HDMI in's on the theater system, there is a delay, there is always a delay on it, even if I'm playing a Bluray film on the receiver itself.
I set the audio sync to 0ms, and the video still comes in first, and the audio is still delayed. I am using HDMI 1.4 cables.
I've literally tried everything, even sending the inputs to the TV first, then using the TOSLINK... still a delay.
When I play things on my HD-DVR, which is also directly connected to the receiver, it still causes a delay. I don't understand how video takes more hops compared to the audio which is directly connected via HDMI from the sources, and STILL the audio comes in delayed. It makes no sense to me that the video has to travel farther than the audio, and still the audio is delayed.
Any thoughts? Thanks.
hengbokdl7 is offline
post #2 of 13 Old 08-31-2010, 08:42 AM - Thread Starter
hengbokdl7's Avatar
is there anyone out there that can help me with this?
post #3 of 13 Old 08-31-2010, 09:06 AM
stang323's Avatar
Check if your tv also has video sync? Maybe it's way off
stang323 is offline
post #4 of 13 Old 08-31-2010, 09:16 AM
Ratman's Avatar
Quoted: 1276 Post(s)
Liked: 1024
http://www.samsung.com/us/info/contactus.html
Ratman is offline
post #5 of 13 Old 08-31-2010, 12:44 PM
JEFFakaMAX's Avatar
I have the same TV and have never experienced this. How much delay are we talking about here?
Sec 42-30
It is unlawful to make any loud music, in a manner that the same is heard on the public streets or sidewalks to the annoyance of persons or cause a disturbance of the peace. Pfft- whatever!
JEFFakaMAX is offline
post #6 of 13 Old 08-31-2010, 12:47 PM - Thread Starter
hengbokdl7's Avatar
Thanks for the replies. I've got the Samsung UN55C8000, and the Samsung HT-6600 3D Bluray home theater surround system.
No matter what I'm playing, the audio always LAGS to the video, meaning the video happens, and the audio lags. Very strange, since everyone has the opposite issue. All Audio Sync for both the TV and the receiver are set to 0ms.
Even when I play BluRay movies FROM THE RECEIVER itself, the audio trails the video. This is interesting since the audio has ZERO hops it just gets sent straight to the speakers. The video if anything should be laggy, since its getting sent to the TV via HDMI, but it's not, the video always comes first, audio trailing.
post #7 of 13 Old 08-31-2010, 12:52 PM
Ratman's Avatar
Liked: 1024
What advice did Samsung support provide? I'd think they could provide better insight since both your TV and BR player/receiver are Samsung products.
Ratman is offline
post #8 of 13 Old 09-01-2010, 08:32 AM
bluesky636's Avatar
How do you have the system configured? Do you have both audio and video input to the AVR with video then output from the AVR or do you have video going directly from the source to the tv with only audio going through the AVR? If the latter, you will always have sync issues between audio and video. If the former, then you most likely have an equipment problem and should contact Samsung as Ratman suggested.
bluesky636 is offline
post #9 of 13 Old 09-01-2010, 08:35 AM - Thread Starter
hengbokdl7's Avatar
The receiver is the Bluray player itself, so it's already strange that there is audio lag from there, since it only has to go directly to the speakers.
As for everything else, my cable, and game system are all patched into the receiver, both audio and video via HDMI cable. The only thing connected to the TV is the HDMI out from the receiver.
post #10 of 13 Old 09-02-2010, 08:34 AM
bluesky636's Avatar
Then as Ratman suggested, contact Samsung.
post #11 of 13 Old 09-02-2010, 09:41 AM
Ratman's Avatar
Liked: 1024
Connect your game system and DVR directly to the TV (bypass audio system).
If there's no delay, then that pretty much determines that the HTiB is the probable cause.
Ratman is offline
post #12 of 13 Old 09-03-2010, 09:03 AM
Big Tasty's Avatar
I have a Samsung Plasma (PC50C6400) which had the same issues, I enabled the Anynet+ feature and it seemed to fix the issue. Not sure if their LED have the same feature.
Big Tasty is offline
post #13 of 13 Old 12-10-2010, 04:07 PM
mettikoman's Avatar
Hello hengbokdl7!
just do there jobs!
turn off your TV!
then press: Info>Menu>Mute>Turn on button on your Remote control!
you will see secret menu of your LED TV!
just go to Control page and then Sound and start to sync your delay sound time of your TV!
Default number is 100!
change it between 100 to 50!
Enjoy!
mettikoman is offline
