Do Audioquest HDMI cables provide higher quality audio? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 08-21-2010, 02:58 PM - Thread Starter
el pablo's Avatar
Do Audioquest HDMI cables provide higher quality audio that other HDMI cables?
Any input is greatly appreciated!
Pablo
el pablo is offline
post #2 of 17 Old 08-21-2010, 03:02 PM
William's Avatar
Quoted: 29 Post(s)
Liked: 50
Pablo
NO, Monoprice (or 99% of all other HDMI cables) will start with 01100101100 and pass 011001011000 exactly the same.
William is offline
post #3 of 17 Old 08-21-2010, 03:16 PM
Colm's Avatar
Liked: 94
I hope not...
HDMI audio is transmitted digitally. Just like video, as long as the signal is good enough, the sound will be exactly the same as with any other cable. If the signal isn't good enough, you will hear drop outs or pops. But you will never hear a difference in tone, clarity, "sound stage", or any of the other things that audiophiles worry about.
Colm is offline
post #4 of 17 Old 08-21-2010, 03:18 PM
IcemanDallas's Avatar
You got an extra bit in there.
IcemanDallas is offline
post #5 of 17 Old 08-21-2010, 03:33 PM
Ratman's Avatar
Quoted: 1271 Post(s)
Liked: 1022
No, actually missing one bit.
Ratman is online now
post #6 of 17 Old 08-21-2010, 04:25 PM
ChrisWiggles's Avatar
Pablo
No. Not if they're working. But they have a tendency to be overpriced and not work too well, so...
ChrisWiggles is offline
post #7 of 17 Old 08-22-2010, 05:13 PM - Thread Starter
el pablo's Avatar
Thanks for all your input guys! You verified what I believed was true.
el pablo is offline
post #8 of 17 Old 08-22-2010, 05:33 PM
Colm's Avatar
Liked: 94
Pablo, you always ask good questions. You are going to be an expert soon.
Colm is offline
post #9 of 17 Old 08-22-2010, 07:27 PM
ccotenj's Avatar
Liked: 101
not only that, but he actually LISTENS to the answers... nice to see that around here these days... doesn't happen nearly as often as it used to...
good on you pablo...
- chris
ccotenj is offline
post #10 of 17 Old 08-22-2010, 09:05 PM
opnly bafld's Avatar
Maybe you should consider using a coax cable for audio.
In the Feb 2009 edition of the Hi-fi News magazine Paul Miller measured the following jitter results for a few A/V amplifiers:
Denon AVR-3803A
SPDIF: 560psec
HDMI: 3700psec
Onkyo TX-NR906
SPDIF: 470psec
HDMI: 3860psec
Pioneer SC-LX81
SPDIF: 37psec
HDMI: 50psec
Yamaha RX-V3900
SPDIF: 183psec
HDMI: 7660psec
Lin
opnly bafld is offline
post #11 of 17 Old 08-22-2010, 10:11 PM
Colm's Avatar
Liked: 94
Jitter measured where?
What effect does even 8 billionths of a second jitter have on what we hear?
Colm is offline
post #12 of 17 Old 08-22-2010, 10:22 PM
scorrpio's Avatar
Oh, most profound. Armed with a knowledge that there *IS* a difference, audiophiles all over will start hearing 'tighter bass', 'wider soundstages', 'crisper highs' and 'crunchier middles'. On whatever piece of equipment that costs more $$$. I am not talking double blind, here, of course.
scorrpio is offline
post #13 of 17 Old 08-22-2010, 10:27 PM
scorrpio's Avatar
As to OP question:
Yes, Yes, YES!!!
The more people buy Audioquest cables, the better quality audio equipment can guys at Audioquest afford.
scorrpio is offline
post #14 of 17 Old 08-23-2010, 11:20 AM
jpjibberjabber's Avatar
It's possible that the better sound quality might result from the fact that it probably won't mechanically fail anywhere near as quickly as that Mononucleosis jobbie. After all, any sound is better than no sound
jpjibberjabber is offline
post #15 of 17 Old 08-23-2010, 12:04 PM
Ratman's Avatar
Liked: 1022
Mechanical failures typically occur from constant movement or hasty installations. Cables just don't mechanically "fail" without intervention of some sort.
FWIW...
I've been using a "Recoton" Toslink cable from 1996 without incident.
post #16 of 17 Old 08-23-2010, 01:55 PM
Denon AVR-3803A
SPDIF: 560psec
HDMI: 3700psec
Onkyo TX-NR906
SPDIF: 470psec
HDMI: 3860psec
Pioneer SC-LX81
SPDIF: 37psec
HDMI: 50psec
Yamaha RX-V3900
SPDIF: 183psec
HDMI: 7660psec
Lin
Right. Because it makes a world of sense to run a whole other cable that can only provide you lossy audio formats compared to the lossless high-res audio via HDMI, simply because of some inaudible and irrelevant jitter measurements which are anyway made entirely irrelevant if the audio format is DTS-MA or DD-THD because it's going to get uncompressed by the AVR anyway, so any clock problems like jitter are even doubly made completely irrelevant.
post #17 of 17 Old 08-27-2010, 03:43 AM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Damn, I have the Z7 which uses practically the same design as the 3900 (but supposedly has a lower jitter clock.)
Sounds ok though.
"But this one goes up to 11"
MichaelJHuman is offline
